Fireflies ROT66 Flashlight
973 posts / 0 new
teacher
teacher's picture
contactcr wrote:
TK and her color deficient mafia controlling the narrative on tint. It’s all coming together. Steve
Big Smile .. Thumbs Up .. I like that!!
We just have different priorities of what is really important to us.
And hey…. somebody is going to control the narrative…… Wink
Bob_McBob
Last seen: 8 hours 51 min ago
I didn’t have a problem with the holster but I am a little bummed at how cheap the lanyard attachment is. It feels like it would break off if I actually used it. Too bad other doesn’t just have a milled attachment point.
leaftye
Last seen: 1 month 1 week ago
I feel the same way about almost every milled attachment point. There’s so little material retaining the lanyard, even on bigger lights. With some wear, tear and abuse, it’s not going to last as long as I’d like, especially if the lanyard is attached with a steel or titanium clip. At least the threaded attachments can be replaced.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
teacher
teacher's picture
/\ . . Good point leaftye…. .. Thumbs Up
Newlumen
Newlumen's picture
I am about to order some 18650 flat top for the rot66.. which one i should get ? Sony vtc6 or sony vct5a ?? Please input. Thanks.
chinooker
chinooker's picture
Last seen: 2 hours 44 min ago
Well, the VTC6 that I have work fine (I know they might bump a little) in both of my BLF Q8s and my ROT66 XP-L.
And they are not PINK! Ughh
SKV89
Last seen: 59 min 52 sec ago
Why not VCT5D instead of VTC5A?
Newlumen
Newlumen's picture
Thank you chinooker… i just check illumn and they were out of sony vtc6.. i guess i will have to go with sony vtc5a for $5.99 each..
Newlumen
Newlumen's picture
I have sony vtc5d from illumn.. expensive as hell.. cost $9.99 each… they perform like vtc6.. not worth it..
SKV89
I like VTC6 the most too. It measures about 250-300mah more than the VTC5D and the performance advantage of the VTC5D can only be seen with a lumen sphere measuring a high power FET light. You can get the VTC6 for $5.99
https://liionwholesale.com/products/sony-vtc6-3000mah-15a-30a-battery-ge...
twisted raven
Last seen: 5 hours 12 min ago
I ordered sets of VTC6 from liionwholesale. I chose VT6 because of the combination of capacity and high drain performance. My predominant usage of the ROT66 is in the 50-1400 lumen range. I hardly ever use the 5-6000 lumen turbo blast.
Newlumen
Newlumen's picture
I dont know man.. i have a rot66 xpl hi from skylumen ( to test it out )… xpl hi version is not much better than sst20…
Rot66 sst20 with sony vtc5d.. 7000 lumen
Rot66 xpl hi 6500k. Sony vtc5a. 7000 lumen
Xpl hi step down quickly..
twisted raven
How does throw compare though? SST20 still have the domes on their emitters, although they are very small LEDs.
SST20 4000k 95 cri seems pretty bright too.
Newlumen
Newlumen's picture
They both throw the same. I can tell xpl hi have extra kick into it..
twisted raven
Does the XPL HI have a ‘hotspot within a hotspot’ effect to it, or is it a nicely filled spot like the SST20?
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 56 min ago
The recent 3500 mAh cells are probably a good fit… maxed-out capacity with plenty of power for 3000 lumens or less. In this light, high-drain cells are basically only relevant for turbo mode.
Frumious
Those were my two top choices also. As either provides more amperage than the Rot66 can take advantage of, I went with the Vct6 for its 20% greater run time.
klrman
klrman's picture
Last seen: 1 day 6 hours ago
Does the XPL HI have a 'hotspot within a hotspot' effect to it, or is it a nicely filled spot like the SST20?
Don't know if this will help as I have a cheap camera, but here is a pic I took  yesterday of the XPL Hi from from the ROT66 compared to the BLF Q8.
contactcr
Last seen: 9 hours 29 min ago
My vtc5d are not that low resistance and they are $10/ea
SKV89
Don’t know if this will help as I have a cheap camera, but here is a pic I took  yesterday of the XPL Hi from from the ROT66 compared to the BLF Q8.
damn that XP-L HI beam looks perfect! I’m glad I have the XP-L HI 3A on the way! Big Smile
klrman
klrman's picture
damn that XP-L HI beam looks perfect! I'm glad I have the XP-L HI 3A on the way! :D
Here's a better shot by itself that I just took.  It's such an awesome NW, I'm really impressed and the evenness of the beam is amazing.  I took a chance ordering the XPL HI V3 3A NW hoping it would really be a solid NW, but I never expected it to be that good.
teacher
teacher's picture
Thanks for the picture klrman. The ROT66 looks to have a very nice beam too.
And I love the fact that it appears to be a ‘True NEUTRAL White’!!
Q8 on the left & ROT66 on the right…. correct?? Wink
The ROT66 has NO ‘Yellow tint’ that puts in in the Warm White category (as far as I am concerned) of the Original Q8.
TRUE NEUTRAL WHITE….. FF got it right!!! . Thumbs Up
klrman
klrman's picture
@teacher, yes Q8 on the left.  The ROT66 XPL Hi V3 3A NW is the real deal, it's what I have been always hoping for
Newlumen
Newlumen's picture
klrman wrote:
@teacher, yes Q8 on the left.  The ROT66 XPL Hi V3 3A NW is the real deal, it’s what I have been always hoping for
Ok. I just measured the rot66 xpl hi 6500k. I got 7000 lumen with the sony vtc5a.
SKV89
I was hoping for 8-9k lumens but I guess 7k lumens is still impressive for the size.
contactcr
Seems like it could do more on paper. Anyone do spring bypasses or other mods yet?
Newlumen
Newlumen's picture
Daytime shot.
D4-FE2-D87-BF94-48-A0-877-D-79125789098-C
fast image hosting
Rot66 sst20 cw
02988-CD1-4102-4-E2-F-9-CA5-118-D27-CB2-EF4
Rot66 xpl hi 6500k
B129-C0-BC-72-D6-46-B0-8579-0-E7376-E4-DE1-A
Rot66 Samsung 4000k
3-A843-E0-F-E242-4297-B3-B2-98-EEA29-A263-F
teacher
teacher's picture
klrman wrote:
@teacher, yes Q8 on the left. The ROT66 XPL Hi V3 3A NW is the real deal, it’s what I have been always hoping for Thumbs Up
Thumbs Up Gotcha, I was pretty sure it was. Wink
That is really nice too… a “neutral white” that is actually ‘Neutral White’, not WW with a ‘Yellow Tint’ that is called ‘neutral’.
I love it!!! Thumbs Up
klrman
klrman's picture
teacher wrote:
klrman wrote:
@teacher, yes Q8 on the left. The ROT66 XPL Hi V3 3A NW is the real deal, it's what I have been always hoping for Thumbs Up
Thumbs Up Gotcha, I was pretty sure it was. Wink That is really nice too... a "neutral white" that is actually *'Neutral White'*, _not WW with a 'Yellow Tint' that is +called+ 'neutral'_. I love it!!! :THUMBS-UP:
I know what you're saying    I recently got another ....... cough cough....... "NW"   light, that is yellow as a banana!
teacher
teacher's picture
Newlumen wrote:
Rot66 sst20 cw
Rot66 xpl hi 6500k
Rot66 Samsung 4000k
Thanks Newlumen!!
  • 1. What is the color of that house?? Off white, beige, or light yellow???
  • 2. Are any of those three ‘High CRI’??
