9x CREE XPL High Intensity Emitters / 9x Nichia 219B SW45K R9080 High CRI Emitters
Made of 7075 aluminum alloy
Body color: champagne color or Black color
HAIII Anodising Surface Finish
Stainless Steel bezel;
Max Brightness: 10 000 Lumens (9xCREE XPL Hi CW V3) / 5000 Lumens( 9x Nichia 219B)
3x18650 battery carrier
25 degree angle TRI lens
98% AR coating glass lens
Digital current regulation on lower brightness
IPX8 waterproof , underwater 2 meters
Size: 110mm x 47mmx45mm body
Weight: 240gram
That is not a bad firmware, but I was hoping to find out things like: is this light using a combination of linear regulators and a field effect transistor (common 7135+FET drivers) or if perhaps the battery carrier puts the cells in series so as to use a buck driver, or maybe the cells are in parallel but the leds are in series and a boost driver is used. I worry that a FET would not be good for the 219b version.
I suppose once the sample reviews come out I will find out either way.
The springs are a good indicator, but not absolute, which is why I asked. Yeah, that seems likely but I sure don’t like the idea of FET and 219b, even when it’s 3:1. Seems likely that a bit too little resistance could be an issue.
Wow I havent seen anything that got me this excited in a long while! Is it really 219b 9080? Becaise from my understanding Nichia discontinued them a long while ago. Only Virence.com sells them but with very limited quantities left. If it is really 9080, I will definitely buy one or maybe two if performance is good. Thanks and really looking forward to learn more about this light
