Well, I finally got my replacement head, turns out it was shipped to the wrong address and it did not have enough postage so I had to pay another 5 bucks to pick it up. Unfortunately that’s where the “good” news ends. The head that arrived is all banged up, dented and scratched. I put it on my light and it doesn’t work. I have three fresh, fully charged cells in it that work fine in other lights but I’m getting a low battery indicator on the light, it flickers on and off and the interface is unresponsive…
So I give up, this light is a complete waste. I’m done with Fireflies, their service is terrible and their lights do not deliver on what they promise.
That sucks. It seems weird that two heads in a row would have been faulty.
The only suggestion I have, which maybe you already tried, is to put a thin shim of some kind between the battery carrier and the tailcap. Some people had problems with the battery carrier not being pressed into good contact with the head.
What batteries are you using? Are they the same set you had in when you fell into water?
His post history indicates that the carrier was working fine before he submerged his last head into water, and they were nice enough to send a replacement.
I have a rot66, trying to remove the bezel but it doesnt budge. Anyone have the secret key to remove this thing? It is just taking a heat gun to the rim?
It’s possible it is just really tight, and maybe a strap wrench would help. However, it is probably glued. Try heat, but whether that works depends on what glue they used.
Sorry, missed these messages, I got pretty fed up with the flashlight and have pretty much written it off.
No, I don’t believe it’s a bad carrier, nor bad cells, I don’t generally use protected cells and I’ve tried multiple different ones. The original head that got wet is sort of working, it has a couple dead LEDs but otherwise it works as normal since it dried. The new head still has the same issues. I’ve tried getting them apart to see if I can fix anything but they are glued quite tightly.
It’s now just sitting in a drawer with some crappy laptop cells acting as an emergency backup light.
Also, just to clear things up, while I definitely do admit to getting the light wet, the light is advertised as being IPX8 rated which means it should survive being continuously submerged in 1 meter of water. I fell into the shallow end of a pool (3 feet) with the light and it immediately filled with water. I would consider that a warranty problem since it clearly did not live up to it’s claimed ratings and not fireflies just being nice about replacing it. It was like pulling teeth to get a replacement.
That is 100% possible.
You may have had a bad carrier.
I really hope his problem comes from protected cells, and not something else.
Yup either protected cells or maybe one is really damaged and has high internal resistance from shorting in the water.
This is what my second head does. First had two defective leds. This one is clearly shorting something out on the driver side.
I’m currently assembling the riders of the apocalypse to be released upon FF.
Sent a mail regarding the issue two months ago, no reply. PM’ed them on BLF a month ago. No reply…
One dead PL47 and two defective ROT66’s later, and I’m about to loose my sh.
EDIT: Finally got a reply, they are shipping a new head. So fingers crossed
Got mine (that was glued) off, by using brute force. Make sure you protect the bezel when forcing it off.
Mine have some scratches from the procedure
