LG 18650 MF1 2200mAh (Purple)
Official specifications:
Nominal voltage: 3.65V
Nominal capacity: 2150mAh
Minimum capacity: 2050mAh
Standard charge current: 1075mA
Standard charge cut-off: 50mA
Maximum charge voltage: 4.2V
Maximum charge current: 2150mA
Maximum discharge current: 10A
Discharge end voltage: 2.75V
Cycle life: 500 cycles to 70% at 2150mA charge/discharge current.
Operating temperature: charge: 0°C ~ 45°C, discharge –20°C ~ 60°C
Storage temperature: 1 month: –20°C ~ 60°C, 3 months: –20°C ~ 45°C, 1 year: –20°C ~ 20°C
This is a older high current cell (Datasheet says 2011).
The discharge curves has a good match.
Conclusion
In its time it was a good high current cell, but compared to a modern cell it is not very impressive anymore.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
