Today I have a Convoy C8+ in the new Sand color to take a look at. The C8+ has a deep smooth reflector and works as a great budget thrower. For those of you who don’t know Convoy they have a reputation of providing great quality lights for very low prices. This sand colored C8+ was provided to me by Gearbest (Affiliate Link) to take a look at and I thank them for that.
Full Image Gallery: Convoy C8+ Review - Album on Imgur
YouTube Version of this Review:
Packaging
Packaging is pretty much non existent. My C8+ came in a white cardboard box that got got crushed a bit during shipping.The light doesn’t come with any accessories other than a lanyard that was already attached. Nothing on mine was tight either so make sure you tighten up the front lens and body/tail caps prior to first use.
Construction
The C8+ is made of aluminium and is anodized with a color they call sand but it’s pretty close to the Cerakote color Burnt Bronze which I happen to really like. Starting at the tail cap you have a black rubber clicky button. It does full click and momentary. There are lanyard holes on both sides and the light will tail stand. Threads are ACME cut and were lightly greased on the rear. On the body tube the knurling is pretty deep and aggressive. I like the diamond pattern.
The head itself has lots of cooling fins milled into it. It gets larger to accommodate the large and deep reflector which is what gives allows this light to throw. The front bezel has very shallow crenulations. It’s very easy to remove, allowing the smooth reflector to come out and access to the emitter circuit board. This is an easy light to mod.
In the hand I find it’s mostly comfortable. It’s a little short with the larger head unless you grip up on it, it works pretty well in a cigar grip.
Length was measured at 142mm, diameter of the body tube is 25.2mm, diameter of the head is 44.5mm and empty weight is 145 grams. No claims about water rating was made but it has orings everywhere I would expect so it should be pretty decent. It survived a brief sink test.
LED/Runtime
This light uses a Cree XPL HI LED that’s available in 4 different color tints. (6500k, 5000k, 4200k, 3000k). Mine is in 4200K which I quite like as a neutral white. I don’t notice any tint rainbow to it. Beam pattern is consistent with a deep reflector thrower. Small, hot center, with minimal spill and a hard cut off. High mode is listed as 1100 Lumens.
For my runtime test I used a 3500mAh NCR18650B battery. Light fall off started to occur pretty fast and it was a very linear drain for the first 80 minutes down to about 45% relative output. At this point the light started taking larger decreases down to where it shut off at 130 minutes.
UI
This light is using revised UI from Convoy. It’s a little hard to describe in words as there are several modes, so ill include the Diagram that Convoy Publishes. The light has 12 mode groups that you can switch the light into by entering configuration mode by doing a bunch (10+ taps or until the light stops turning on and you will be in config mode) By default from what I can tell I believe the light I received ships in mode 1 which contains 0.1, 1, 10, 35, 100, Strobe (Fast then Slower, then fast), Biking (Steady on at about 50, with super fast strobe every second), and then a battery check that counts out voltage. The light does have memory and momentary. The good thing is between the 12 modes offered there is just about something for everyone and it’s not too hard to switch if you have the directions handy.
Pro’s
- I love that the C8+ comes in a wide variety of tint options, make sure to pay attention when ordering.
- It’s great value for the money, for under $30 shipped it might be the best thrower for the money.
- Moddable - Lots of mods exist for Convoy lights, I think I will do the glowing tail cap for this one.
Con’s
- While I love the new “sand” or burnt bronze color it does feel a little chalky to the touch, and I know some people dislike this.
- On the larger side of things, not EDC-able in a front pant pocket (Works ok for a coat)
- Barebones packaging, no extras, or manuals included.
Conclusion
The Convoy C8+ is a great bargain 1x 18650 cell thrower. For under $30 shipped to the USA it’s hard to find a better thrower with as many tints as the Convoy C8+ offers and as many operating modes. I love that it comes in 2 main tints (Black and Sand) and that the light is pretty moddable. This Convoy is pretty well built and is a nice value. If you don’t mind waiting for overseas shipping this is a great value thrower.
Gearbest has provided a coupon code of “ConvoyC8” to allow you go get this C8+ in Sand for $19.99 at https://goo.gl/VckBeo (Affiliate Link)
Up Next I have several lights (Thrower, Headlamp, and more) so make sure you are subscribed to my Youtube Channel so you won’t miss the next review.
