Imalent unveils R70C – R90C – MS12
245 posts / 0 new
AgentWhiteBread
Last seen: 2 weeks 1 day ago
It wouldn’t be an imalent light if you could replace stuff yourself!
JasonWW
JasonWW's picture
Last seen: 6 hours 26 min ago
mortuus wrote:
So it’s using 1 fan only, that explains why it can’t run the highest that long. Doesn’t look like u can replace it yourself either?
What a strange choice in fan. That type of fan is designed to spin clockwise and pull air towards it’s center. I don’t see how it’s going to blow any hot air out. In order to be effective, the air has to flow into and then out of the light.
Does anyone here see how that fan is going to produce flow through the light?
JasonWW
JasonWW's picture
Maybe it works similar to the FB1 since it uses a similar fan shape.
If this were the case, the MS12 heatsink would have to be divided in the middle of the vent, like this. Cold air goes in the top part and hot air exits the bottom.
It’s possible they got clever and added ducts inside so that the inlets and outlets are a little further apart.
The issue I see with both designs is it sucking in and recirculating hot air from the exhaust vent. You need to space them as far apart as possible.
Anyway, maybe we will get a better look at the cooling system later.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 18 min ago
These types of exhaust fans are pretty popular with laptops. Draws heat in and exhaust out the side. https://www.walmart.com/c/kp/laptop-cooling-fans?offset=40
KB1428 “Live Life WOT”
JasonWW
JasonWW's picture
I think your overlooking the obvious.
This style of fan is like a turbo. The air going in is at a 90° angle to the air going out.
This fan pulls air in along its outer diameter, but where does it go then?
KawiBoy1428
The exhaust side where the sticker is…the intake is the fan side, like the blower on a house furnace, draws in from the side, cold air intake, and blows out the exhaust side across the heat plenum into the ducts.
mortuus
mortuus's picture
Last seen: 3 min 7 sec ago
It does look kinda cheap just stick a small fan inside that host and thinking it will do magic? yea i guess it wont, not with that amount of watts of power the leds together will generate on turbo… Not like small fans like that are meant to withstand hundreds of watts of power but it will be interesting see some review tests see how it will perform.
Like compared graphics cards that can get very hot too when playing games, usually its a fan that blows the hot air at the end of card from the heatsink, works usually good.
...where Frugal meets with Flashlight!
JasonWW
JasonWW's picture
There is no sticker.
Are you talking about your computer fan picture? I’m pretty sure you got it backwards. The hole in the middle is the intake. You can see the dust build up. It slings the air with centrifugal force out the side. This is how most all laptops work. Intake on the bottom, exhaust out the side.
Going back to the MS12. Regardless of the fan rotation, clockwise or counter clockwise, there is only an intake and no exhaust or only an exhaust and no intake. Do you see my point?
DB Custom
DB Custom's picture
Last seen: 16 min 32 sec ago
If air is going in, air is also going out. Pretty simple there.
I love the idea, not so much of the 12 XHP-70’s but the fan cooling. They should use that on the 9x XHP-35 and I’d be on the edge of my chair with my hand in the penny jar.
Still, the idea of a massive head with 9 35’s just appeals to me, the stop sign in the middle maybe encourages me to GO! Big Smile
DB Custom
DB Custom's picture
Store:Shenzhen NuoSenDa Electronics Ltd.
US $836.63 / Set
Discount Price:
US $426.68 / Set -49% 16h:13m:53s
Get our app to see exclusive pricesBulk Price
Interesting, AliExpress is not the cheapest place to buy one huh? lol On the other hand, Lightmalls shows $380 at a discounted price from the $409 suggested retail.
Gonna have to sign up for the group buy just to see how many penny jars gotta go. Silly
JasonWW
JasonWW's picture
No, that’s not how air flow works. If a fan tries to push air in and there is no path for it to exit, air pressure builds up and air stops going in. It’s all about creating a pressure differential.
Think of a laptop. It’s fan pulls cool air in from the bottom and exhausts hot air out the side. Now cover the side exhaust. The air stops flowing and the temperatures start increasing.
In the MS12, I think the air must be flowing like one of the two pictures I drew. I don’t think it’s design is anywhere near as good as the cooling setup we see on the Acebeam X70 which had clear intakes and exhausts.
DB Custom
DB Custom's picture
Seriously Jason, I’m not an idiot. (Well, sometimes I’m not! LOL ) When air flow gets backed up it stops going in, doesn’t it? And then of course it’s not going out or it’s building pressure to make something blow. Air going in, air goes out. Really really simple.
I put a computer fan on top of an amplifier heat sink mounted to a 6” disc of 1” thick 6061 aluminum to cool 5 Cree COB’s. At first I mounted the fan pushing air away from the sink, pulling it in from the sides through the fins. Didn’t work well and was noisy. Then I flipped the fan and have it now blowing down into the heat sink, air out through the open sides of the fins… at 60W (3A at 19.1V actual readings at the fixture) the aluminum disc doesn’t even make it to 100ºF, running 12 hours a day.
Computer programming If/Then rules…. IF air is going in, THEN air is going out. Even without an exit point it’s only a matter of time. Wink
Without knowing how they built it, but seeing diagrams showing cool air in on one side and hot air out the other, we are left to assume they actually knew what they were doing. Drawing conclusions without factual evidence is really an exercise in futility…
DB Custom
DB Custom's picture
Some more If/Then… IF you supply enough power to a fan that can sufficiently cool the head for long run times, THEN you’ve drained your battery pack and don’t have long run times anyway. Wink
Compromises, always about the compromises…
thijsco19
Last seen: 23 min 17 sec ago
I have to agree with DB but Jason is also not wrong. It does need a nice path for the airflow. But if air is getting in it is also getting out.
Though, the picture from imalent doesn’t make much sense.
However it does show the power of a big manufacturer, you can just make a custom fan to implement. For my design that uses a fan I have to use a standard type of fan and that limits the possibilities.
JasonWW
JasonWW's picture
The power the fan draws from the battery is so small it’s negligible.
JasonWW wrote:
I was asked about the triple fan power consumption of the X70 in another thread, so I figured I’d post it here, too.
No one actually knows the size of the fans in the X70, so judging by the video I guess they are about 40mm. The typical 40mm fan uses about 1.2 Watts of power, so three of them would be 3.6 Watts. Compare that to the 350+ watts the emitters are drawing on Turbo and the fans are only using about 1% which is not significant at all. I’d say it’s negligible.
JasonWW
JasonWW's picture
I’m trying to understand this picture, but I think it might be BS.
They may have given the picture to an artist and told them to represent cool air going in and hot air going out. So the artist just drew some simple blue and red arrows. I don’t think there’s any way you can get air flowing into the left half of the head and have hot air leaving out the right half as it is seen in the image.
KawiBoy1428
I think the top vertical ports/slots are the intake ports and the bottom port/ slots are exhaust, with a shelf in between, with a large inlet hole in the center or multiple holes in it to create the draw from the outside.
DB Custom
DB Custom's picture
That’s what I was implying though, without some factual input it’s just not possible to decipher what’s going on there. They may have creatively implemented a plastic subdivider for the fan compartment that does indeed shift air across. I know Nitecore has done some amazing plastic dividers in their lights that work but seem to have made their lights overly complicated. Something like that here could, hypothetically, create a pathway for the air movement. Won’t know until we see one I guess.
DB Custom
DB Custom's picture
Are we talking about 360W here? 4416 lumens to 12 emitters, what’s that, 5A x 6V? 30W each x 12? Powered by 8 20700 cells, that’s a heck of a load on cells! And to cool that, we can’t even think about a puny little computer cooling fan pulling tiny current at 12V, no, that’s not gonna get the job done here! We need a serious fan! So yeah, the fan will indeed cut into the battery pack, as if the emitters weren’t already kicking it’s arse!
BlueSwordM
BlueSwordM's picture
Last seen: 21 min 59 sec ago
360W is nothing for 8×20700s. If the cells are rated for 30A, being Sanyo NCR20700A/C, running at 25A, that would mean 3,5Vx25Ax8 cells = 700W max draw pack.
The main problem as you said is power dissipation.
I think they should have just taken a Threadripper sized air cooler with a massive head and a 120mm fan. Would that be overkill? No, not at all. Although I don’t think anybody would like a 1,3kg heatsink/3 pound heatsink, but in this light, that would be liked.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
DB Custom
DB Custom's picture
What is the capacity of a high discharge 20700 cell? 3000mAh? You see the problem? If those 8 cells are in 2S4P, which they likely are, you effectively have 4 8.4V batteries at 3000mAh to run the 12 emitters. I can’t see run time being very long at all, and the heat of course would overpower whatever fan they could cram in there. It’s all well and good that a cell can do 10C, but the simple reality is run time is relegated to mere minutes at this kind of discharge rate. Believe me, I know! I actually used 3 pounds of copper for the head of a light, and then some, and with only 3 70.2’s pulling 48.6A from 2 Samsung 30T 21700’s the effect is fairly devastating, both in heat and cell drain. That’s “only” 20,000 lumens…
More less-efficient emitters, more less-effective cells, less heat sink with the addition of a fan, I don’t see it boding well for the monies spent…
Edit: Some might see my comparison as irrelevant, but 12 × 6V emitters run by 8 cells is still 3 6V emitters run by 2 cells, just 4 times in one light. If the heat in my single light with 2 cells and 3 emitters is bad, imagine it multiplied x 4?
JasonWW
JasonWW's picture
I think it’s over 500 watts.
DB Custom
DB Custom's picture
I was recalling that the L6 makes around 4000 lumens with a ~5A draw, so I did simple math to get 30W per emitter. 5A x 6V = 30W in the L6. Multiply that times 12 and it’d be some 360W. I’m probably overlooking something as I usually do.
53,000 lumens divided by 12 emitters would require each emitter to make 4416 lumens, or effectively 12 Convoy L6’s running in a single head.
BlueSwordM
@DB Custom, don’t forget your 20k lumen load was spread out across 3 emitters, and not 12. XHP70.2s are very efficient below a 5000 lumen load.
Also, do you have a thread of you making that 21700 light? I would love to see it.
DB Custom
DB Custom's picture
XHP-70 emitters make more fuss about being pushed hard. Wink Times 12. Still, it’s not all about the heat, power consumption is problematic for the limited power supply. The number of places that require compromise is the real issue.
Even with 9V MTG2 emitters, 4 of them make a lot of heat. I have a TrustFire TR J-20 that uses 3 32650’s to power 4 9V MT-G2’s in parallel and again, in spite of a ludicrous amount of additional heat sink the light does get hot pretty fast. And it “only” makes around 14,000 lumens. This light is monstrous, with very deep fins and a LOT of them. Insufficient. Big power is just difficult to do on battery packs that we can hand hold. We need to use the flashlight to house the cooling system and a belt mounted battery pack to supply the power, this would remove the pack from the heat of the operating light and allow for much higher efficiency. Keeping the cells so close to the heat source is just folly, when maximum lumens is the game.
My big light, or the triple 70.2, is my 5th scratch built light… hence DBC-05. I started this literally the day before I blew out 2 discs in my neck, finished it (as a different plan) after neck surgery. It was satisfying coming back and achieving the results I saw. Wink I don’t take pics while on the lathe, sorry. I’m not a machinist, I’m a photographer… I do NOT want my equipment out in the shop and I DO want to keep all my fingers…
DB Custom
DB Custom's picture
Blue, remember that Imalent is using the older XHP-70 in the big light. Wink
BlueSwordM
Ok wut. Why? XHP 70.2 are quite a bit better than XHP70s, except for tint shift obviously.
Perhaps they have a problem with their source of cheap XHP70.2s not passing quality testing at such high power levels, or maybe they want higher profit margins by using old XHP70s left by streelight/big light manufacturers since they are way cheaper.
DB Custom
DB Custom's picture
Martin says that he was told the 70.2 have some issues so they went with the more reliable 70 series. I am not sure what they were referring to but that’s what they told him. Obviously, it’s not going to be easy to push the 70.2 to challenging levels when using 12 of them, and at under 5,000 lumens per emitter there just isn’t a problem. The use of 70.2’s in this light would yield even more than what they’ve tested, if indeed the 70’s do 53,000 then the 70.2’s would do more than that without changing anything else.
Now, are we going to pay $600 for a flashlight then buy 12 new emitters at over $12 each to upgrade it? Well, somebody here might. Somebody with deeper pockets than mine…
Edit: Several of us here have pushed the 70.2 to over 9000 lumens in lights like the L6, maybe even in the GT…
M4D M4X
M4D M4X's picture
Last seen: 19 min 44 sec ago
Big Smile
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
DB Custom
DB Custom's picture
LOL! That’s giggleworthy for SURE!
