Test/review of Miboxer C8 Smart charger
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 hours 18 min ago
DSC_0696
DSC_0488
DSC_0695
This is a large charger from Miboxer that can handle up to 8 cells, each with automatic current selection and lots of information. The charger supports NiMH and 3 LiIon chemistries with support for many battery sizes.
DSC_0423 DSC_0425
DSC_0424
I got the charger in a cardboard box with specification on it.
DSC_0483
The pack included the charger, a power supply and a instruction sheet.
DSC_0494
The charger requires 12V 3A power.
DSC_0490
The user interface is two buttons and a large display.
A short press on the SLOT button will switch between slots, holding the button down will select all slots.
A long press on the MODE button will allow adjustment of charge current for the selected channel (with short presses).
To adjust chemistry double click MODE button and then select with short presses.
The interface is easy to use and fairly logical.
DSC_0688
All segments are shown during power on.
DSC_0687
Display when the charger is idle without batteries.
DSC_0689
A NiMH battery is put into slot #4, the charger has not calculated internal resistance yet.
DSC_0690
Internal resistance is calculated and charger has selected 0.25A as initial charger current, it might be adjusted later on.
There is two numbers that toggles: The first is internal resistance and charge current (mOhm/A), the second is charged capacity and charge time.
DSC_0692
A LiIon battery in slot #5 with 105mOhm internal resistance.
DSC_0491
Specifications are listed on the back of the charger with small black letters.
DSC_0492DSC_0493
The charger has the usual slider construction. It can handle from 28mm to 74mm, this means even the longest cells.
supportedBatteryTypes
supportedBatterySizesDSC_0705
DSC_0706DSC_0707
Measurements charger
  • Power consumption when idle is 0.3 watt
  • Without power it will discharge a LiIon battery with about 2mA
  • Without power it will discharge a NiMH battery with about 0.2mA
  • At 0V battery voltage the charger will charge with 1.5mA and report “Err”.
  • Up to 1.9V the charger assumes NiMH
  • Above 2V the charger assumes LiIon
  • The charger will restart when a battery is inserted or power is cycled.
  • The meter is within 0.01V and works from 0.02V
Charging 4.2V LiIon
Manual charging current: Auto, 0.1A, 0.2A, 0.3A, 0.5A, 0.6A, 0.8A, 1A, 1.2A, 1.5A
Maximum actual current depends on number of batteries, charger can only deliver 1.5A with up to 4 batteries and 0.8A with 8 batteries.
Miboxer%20C8%20auto%20%28SA18650-33%29%20%231
I let the charger automatic select current here, it started at 1A and increased to 1.5A, the termination is at about 50mA after a nice CC/CV charging.
Display shows 3016mAh in 3:12, 64mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%232
Display shows 3194mAh in 4:40, 80mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%233
Display shows 3177mAh in 5:00, 93mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%234
Display shows 3275mAh in 3:36, 76mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%235
This time there must have been some contact resistance, the current was selected very very low and after a day and a half the charger stopped, but the battery was not fully charged (But nearly).
Display shows 3188mAh in 33:44, 407mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%236
Display shows 2984mAh in 7:42, 119mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%237
Display shows 3162mAh in 10:20, 146mOhm
Miboxer%20C8%20auto%20%28SA18650-33%29%20%238
Display shows 3234mAh in 13552, 197mOhm
Miboxer%20C8%201.5A%20%28SA18650-33%29%20%231
Manually selecting 1.5A gives a fast charging and is within specifications for all newer 18650 cells.
Display shows 3222mAh in 3:36, 95mOhm
Miboxer%20C8%201A%20%28PA18650-31%29%20%231
Display shows 2891mAh in 4:39, 113mOhm
Miboxer%20C8%201A%20%28SA18650-26%29%20%231
Display shows 2606mAh in 4:08, 205mOhm
Miboxer%20C8%201A%20%28BE18650-26%29%20%231
With manually selected current all batteries are charged nicely and as fast as possible.
Display shows 2283mAh in 4:58, 213mOhm
Miboxer%20C8%20auto%20%28AW18350-IMR%29%20%231
This old and worn down cell I tried automatic on and it charged the cell nicely.
Display shows 208mAh in 2:20, 632mOhm
Miboxer%20C8%200.5A%20%28KP14500-08%29%20%231
A smaller cell where I manually selected the current is charged fine.
Display shows 736mAh in 1:57, 237mOhm
Miboxer%20C8%201.5A%20%288xSA18650-33%29
Here I selected 1.5A current, but the charger reduced the charger current due to the number of cells. The charging looks fine.
  1. Display shows 3241mAh in 5:16, 67mOhm
  2. Display shows 3137mAh in 4:49, 43mOhm
  3. Display shows 3305mAh in 5:01, 35mOhm
  4. Display shows 3429mAh in 5:01, 61mOhm
  5. Display shows 3308mAh in 4:56, 33mOhm
  6. Display shows 3053mAh in 4:46, 36mOhm
  7. Display shows 3310mAh in 5:03, 34mOhm
  8. Display shows 3221mAh in 4:56, 45mOhm
    Miboxer%20C8%201.5A%20%284xSA18650-33%29
    With four cells I could use 1.5A charge current.
  9. Display shows 3279mAh in 3:35, 64mOhm
  10. Display shows 3204mAh in 2:49, 39mOhm
  11. Display shows 3236mAh in 2:55, 35mOhm
  12. Display shows 3220mAh in 2:52, 40mOhm
    Miboxer%20C8%201.5A%2012V%20%288xSA18650-33%29
    The charger uses up to about 2.5A from 12V when charging at full current.
  13. Display shows 3264mAh in 6:00, 181mOhm
  14. Display shows 3135mAh in 4:54, 43mOhm
  15. Display shows 3301mAh in 5:06, 32mOhm
  16. Display shows 3283mAh in 5:03, 44mOhm
  17. Display shows 3327mAh in 5:04, 32mOhm
  18. Display shows 3108mAh in 4:57, 40mOhm
  19. Display shows 3264mAh in 5:06, 41mOhm
  20. Display shows 3206mAh in 4:55, 44mOhm
    Temp5704
    M1: 31.0°C, M2: 33.2°C, M3: 33.8°C, M4: 34.6°C, M5: 35.1°C, M6: 35.2°C, M7: 34.4°C, M8: 32.9°C, HS1: 44.7°C
    With 8 batteries the temperature is fairly low.
    Temp5705
    HS1: 42.5°C
    Temp5714
    M1: 41.0°C, M2: 45.9°C, M3: 45.6°C, M4: 42.2°C, HS1: 63.4°C
    With 4 batteries both the batteries and the charger gets hotter.
    Temp5715
    M1: 49.3°C, M2: 47.6°C, HS1: 53.5°C
    PoweronLiIon
    The charger uses a internal resistance check to decide the charge current and will then ramp the charge current slowly up.
    CurrentChangeLiIon
    It is possible to override the current setting at any time.
    ChargingLiIon
    The charger turn the charge current off the check the voltage.
    Charging 4.35V LiIon
    Miboxer%20C8%201A%20%28LG18650-30%29%20%231
    The high voltage LiIon looks fine.
    Display shows 2931mAh in 3:32, 113mOhm
    Charging 3.6V LiFePO4
    Miboxer%20C8%201A%20%2818650-LiFePO4%29%20%231
    Display shows 1256mAh in 1:51, 82mOhm
    Miboxer%20C8%200.5A%20%28SO14500-LiFePO4%29%20%231
    LiFePO4 is charger to 3.6V and the charger stops when the battery is full, this looks fine.
    Display shows 576mAh in 2:03, 113mOhm
    Measuring Internal Resistance LiIon
    RiLiIon
    The results looks good and the consistency is also fine (I was a bit lazy and only checked 4 slots).
    Charging NiMH
    Charging current: Auto, 0.1A, 0.2A, 0.3A, 0.4A, 0.5A, 0.6A, 0.7A, 0.8A, 0.9A, 1A
    Miboxer%20C8%201A%20%28eneloop%29%20%231
    The NiMH charging uses -dv/dt termination, here I used manual current selection. There is no top-off or trickle charge and none is needed.
    Display shows 1782mAh in 2:14, 51mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%232
    Display shows 1715mAh in 2:08, 63mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%233
    Display shows 1707mAh in 2:10, 79mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%234
    Display shows 1705mAh in 2:04, 90mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%235
    Display shows 1783mAh in 2:12, 185mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%236
    Display shows 1681mAh in 2:18, 105mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%237
    Display shows 1775mAh in 2:11, 66mOhm
    Miboxer%20C8%201A%20%28eneloop%29%20%238
    Display shows 1743mAh in 2:15, 148mOhm
    Miboxer%20C8%201A%20%28eneloopPro%29%20%231
    Display shows 2258mAh in 2:50, 69mOhm
    Miboxer%20C8%201A%20%28leise25%29%20%231
    The two high capacity batteries is charged fine with a -dv/dt termination.
    Display shows 2293mAh in 2:55, 55mOhm
    Miboxer%20C8%200.5A%20%28eneloopAAA%29%20%231
    The AAA is charged fine.
    Display shows 666mAh in 1:53, 92mOhm
    Miboxer%20C8%200.1A%20%28eneloop%29%20%231
    Here I selected a very low charge current, this means a -dv/dt termination will not work. The charger terminated anyway and at about the correct time.
    Display shows 1725mAh in 18:43, 100mOhm
    Miboxer%20C8%201A%20full%20%28eneloop%29%20%231
    With -dv/dt termination the charger will be slow to termination on a full cell, here it took about 15 minutes.
    Display shows 60mAh in 0:14, 53mOhm
    Miboxer%20C8%20auto%20%28eneloop%29%20%231
    The automatic current selection can also be used for NiMH.
    Display shows 1744mAh in 4:01, 71mOhm
    Miboxer%20C8%201A%20%288xeneloop%29
    With NiMH the charger can charge 8 batteries with full current at once.
  21. Display shows 1890mAh in 2:24, 110mOhm
  22. Display shows 1794mAh in 2:13, 52mOhm
  23. Display shows 1880mAh in 2:14, 47mOhm
  24. Display shows 1847mAh in 2:12, 51mOhm
  25. Display shows 1750mAh in 2:07, 54mOhm
  26. Display shows 1766mAh in 2:07, 37mOhm
  27. Display shows 1890mAh in 2:14, 35mOhm
  28. Display shows 1870mAh in 2:13, 41mOhm
    Miboxer%20C8%201A%2012V%20%288xeneloop%29
    The charger uses about 1.8A from 12V
  29. Display shows 1844mAh in 2:13, 101mOhm
  30. Display shows 1834mAh in 2:12, 40mOhm
  31. Display shows 1905mAh in 2:14, 34mOhm
  32. Display shows 1879mAh in 2:15, 38mOhm
  33. Display shows 1724mAh in 2:03, 34mOhm
  34. Display shows 1813mAh in 2:09, 38mOhm
  35. Display shows 1869mAh in 2:12, 29mOhm
  36. Display shows 1847mAh in 2:03, 64mOhm
    Temp5730
    M1: 41.4°C, M2: 46.3°C, M3: 46.7°C, M4: 47.6°C, M5: 49.6°C, M6: 48.3°C, M7: 48.3°C, M8: 43.8°C, HS1: 70.2°C
    8 NiMH batteries gets warmer than 8 LiIon batteries when charging at full current, but it is acceptable.
    Temp5731
    M1: 49.7°C, M2: 48.5°C, HS1: 55.9°C
    PoweronNiMH
    CurrentChangeNiMH
    Current can be changed at any time.
    ChargingNiMH
    As is common with all NiMH chargers the current is turned off to measure the NiMH voltage.
    Measuring Internal Resistance NiMH
    RiNiMH
    The results looks good and the consistency is also fine.
    Conclusion
    The charger works fine and has a good user interface. For NiMH and 4.2V LiIon the charger is very easy to use, just put the batteries in and it will do everything, the automatic current selection may not select the best current, but it will not cook batteries.
    To get a more controlled charge current it is easy to set charge current for one or for all slots, it is also fairly easy to select 4.35V or 3.6V charge voltage.
    Some people like to see a percent, some a voltage, this charger shows everything at the same time including internal resistance, but only for one cell at a time.
    I will rate it as a good charger.
    Notes
    The charger was supplied by Miboxer for review.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 26 min 25 sec ago
Thanks for the review.
It looks really good but i don’t see much advantage over the C4-12 unless you need to charge a bunch of smaller cells. 0.8amps is fairly slow charge for a 18650/26650. The 1amp @ 8 cells comes in handy for NiMH batteries.
anoeri78
Last seen: 3 months 4 weeks ago
Hi
Thanks a lot taking the effort to provide such a detailed review!
I just bought this charger but it does not behave as I expected. The charger is not automatically increasing the current when charging 4 Li-ion cells. It stays on 0.1A all the time and after 4hrs of charging I do not see a significant charge. I use 4 Panasonic NCR18650B with button head and PCB (assembled by evva-tech.com).
Is this behavior normal? Does the charger not work well with batteries including a PCB?
In this situation, should I set the charging current just manually then?
Thanks a lot for your help! I appreciate your advice.
Regards,
Andreas
Sillen
Sillen's picture
Last seen: 2 days 17 hours ago
Automatic current is effected by resistance so unless you have low double digit resistance, it won’t ramp up to 1.5A for 4 cells. Only a few of my batteries will get 1A+ on auto so I use manual most of the time and my high resistance batteries go in the Lii500
angerdan
angerdan's picture
Last seen: 5 hours 12 min ago
It’s interesting to see the display of percent for NiMH batteries!
Do you know which charger do offer this function too?
And which would you recommend for displaying the charge level in % for NiMH cells?
I’d find this chargers:
Gebe
Last seen: 5 hours 13 min ago
I’m by no means the brightest bulb in the room concerning technical data and I like this charger.
It’s strange though because when I charge my cells, (either Li-Ions or Eneloops), and let the Miboxer C8 do it’s thing and set charging current, when the cells are full, the charging ceases.
Then after the C8 has read that they’re 100% full, I’ll put them in my Xtar SV2 Rocket charger and the Rocket will show they’re only at 86%-88% and will continue to charge them at 1 amp for an additional 15-20 minutes more until it states they’re now at 100%.
Wonder which one is correct?
HKJ
HKJ's picture
With NiMH cells it takes between 5 and 30 minutes for a charger to detect a full cell and it will show show full before, I do include a test with every charger on how fast it detects a full cell (This is not very precise, but gives a guideline).
With LiIon there is difference in charge voltage and termination current in addition to a voltage drop when the cell is removed from the charger, all this together may also mean some extra charge time. With LiIon try checking the battery with a voltmeter after you remove the same battery from C8 and SV2.
Gebe
Thanks for that HKJ!
ZoomieFan
ZoomieFan's picture
Last seen: 52 min 53 sec ago
How well do 21700 cells fit in this charger?
Yep, I did read the specs and they fit… it’s just that my LittoKala fits 21700 too, but a crowbar and hammer are needed to get the cell in its slot Smile
Chargers: 1xBasen BD01 5/5,1xDodge Charger, 1x Gyrfalcon All-88, LiitoKala: 3x100 4/5, 2x202 5/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: BLF Q8 4/5, Convoy BD04 5/5, DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Sofirn C01 BLF 3200k/5600k, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5.
Waiting for: (DQG Tiny) 21700 EDCs. Xtar powerbank that (also) takes 20700, 21700, 26650
HKJ
HKJ's picture
ZoomieFan wrote:
How well do 21700 cells fit in this charger? Yep, I did read the specs and they fit… it’s just that my LittoKala fits 21700 too, but a crowbar and hammer are needed to get the cell in its slot Smile
I would say they fit easily into the charger, the gray cell is a 21700 and there is some space left behind it:
