quality charger.. 1-2 cell, 110v input
I see all sorts of good chargers , but this is for a beginner…
I see a lot of these lower priced chargers using USB Input…
I need something that plugs into the wall… But hopefully under $20….
The nitecore i2 or d2 could work for you. A bit slow charging, which could be a positive if you don’t trust the final user to charge a cell too fast.
That said, I don’t know why using a usb charger would be any harder than one that plugs into the wall.
I dunno…I like the idea of a dedicated charger. This will be for a guy in construction…Not sure what phone he uses so that would be an issue in terms of plug…
You could get a separate usb brick and tell him to use that one.
Regardless, both the i2 and d2 connect to the wall ajd are dead simple to use
