I purchased the ODF30C thinking they did away with the solid negative terminal in the tail cap and they did, but to my surprise, they have that solid terminal now at the positive end instead of a spring. It seems to put a lot of pressure on the batteries and dents them. Is there any reason they did this instead of using a spring?
Nobody thinks not having a spring at the positive end of the ODF30C is a bad idea?
It is a bad idea.
Electrically, it is the best bet to get the highest current out a cell at the lowest voltage drop possible.
Mechanically, it is a bad idea just to use a small button. One fall the and the positive terminal could collapse.
It also restricts the types of cells you can use inside of a light.
The problem is most companies don’t want to spend the additional money to design and make a high current spring, and don’t even think about it.
A few Nitecores have no + spring either.
Shouldn’t be a problem i.m.o.
unsubscribed
I have less interest in Lumintop than they have in their customers
This could be a good case to test your new springs if we use two of them? It's a great little light. Just about everyone I showed it to today wanted it, but I prefer having springs on both ends.
It’s still going to be worse than a direct brass contact, but it would be a nice experiment to do.
I wish lumintop use spring on the negative contact point… look what happened to my odf30. I have to bend the tab to work for turbo mode… now it is broken.
I am not the only one who have problem with turbo mode. Other People from Facebook report about the turbo mode problem too.
Ok what. They are brass plates on both sides?!
What kind of idea is this?
If it's going to be worse electrically I should leave it alone then really. Other than my faulty switch or driver, it's a keeper.
No, they just switched the brass plate from the negative terminal to the positive terminal on the newer model.
How thick is the brass plate and how wide is it? I’d like to know. Maybe my springs are actually better for once :+1:
Didn't know this light had a few issues! My switch or driver is faulty.
Would be easier for someone who has the older model to measure it as mine is in the head.
A lot of flashlights only use a spring in the tailcap.
Only high end lights use springs on both ends to ensure constant contact during vibration and also to improve drop resistance.
The two sided springs are not done for more compatibility with different length batteries, if that was the case they would just put a slightly longer spring in the tailcap.
