Astrolux A01
94 posts / 0 new
jerm03
Last seen: 2 hours 53 min ago
Astrolux A01
I have purchased 4 of these lights. Two were purple and 2 black. The black colored lights when changing the battery would not work unless I removed the tail spring and pushed it down with the new battery. Otherwise they would not work. The purple colored lights gave no trouble. I used alcohol and cleaned the barrel, head, and spring to no avail. I even took some sandpaper and used it on the barrel.
The lights are on sale for $7.88 and I may buy a couple of purple to give to friends, but not if they are unreliable. I have not read of an unreliability problem on the forums.
Any bad experience with the A01?
Thanks, Jerry
Sillen
Sillen's picture
Last seen: 2 weeks 4 days ago
I got 4 at once about 4 weeks ago – black, purple, red and green. All work fine.
jerm03
Thanks, that helps. The pricr is right. Big Smile
Jerry
Tumbleweed48
Last seen: 1 hour 9 min ago
That’s a good price – where did you order them from?
Are they Nichia 219b (or c?) and are they ‘always start on low’?
I regret not buying more from the first batch, I’d sure like to get my hands on a few more.
d_t_a
Last seen: 9 hours 40 min ago
During last year-end’s sale on BG, I got a few pcs Astrolux A01 and CPF Italia A01. All of them used Nichia 219B, the difference is that the the CPF Italia uses the Manker driver (no PWM) while the Astrolux A01 uses a different driver with PWM on the lower modes. I can’t be too sure if the Astrolux version has NMM (next-mode memory) as some reported…
I wonder if the new batch of Astrolux A01 still use 219B or have they changed to 219C (since 219B seem to be discontinued by Nichia..), maybe someone who has a recent purchase can mention it.
I do remember the CPF Italia A01 (I don’t see it listed in BG anymore now) had a slightly warmer tint (probably 4500K) whereas the Astrolux A01 have a more neutral (around 5000K) tint.
That’s from last year-end’s batch (Dec 2017 or Jan 2018).
jerm03
I decided to order a couple of purple from BG. They state they have Nichia 219B. I know some have had problems with BG, but I haven’t and would probably write it off and never again if PayPal would not get me a refund. I do not buy much from BG.
That light and color are really cute. Big Smile
Jerry
Lightbringer
Lightbringer's picture
Last seen: 54 min 3 sec ago
These the ones that got NMM?
I got a coupla waaaaaaay back, no NMM, but later(?) versions seemed to have it.
Jerommel
Jerommel's picture
Last seen: 1 week 6 days ago
Yeah, you want one of the first batch (Manker driver)
But then still it kind of sucks a little..
Threads are too sloppy / loose, starts in unusable firefly mode… (i mean, come on, it’s like 1 lumen or something…)
The later models have visible PWM on low modes i.i.r.c.
I would even prefer a 1 mode Olight i3E, although the Nichia in the A01 is okay, but again, not as nice as the first batch..
Or spend more and get the real Manker.
Sounds as if there is anodizing inside the tube, which should have been drilled / milled out.
Maybe you could grind the bottom out a little, if you have a Dremel of some sorts and a long grinding bit.
But maybe interesting to go to Gearbest and look for the BLF 348 with Nichia LED.
https://www.gearbest.com/led-flashlights/pp_554387.html
Only one mode (ON), but it’s stainless steel and a timeless design.
jerm03
I had one of the BLF 348, and also a Slingfire. Personally I preferred the Slingfire to the BLF model. The tint did not do anything for me.
AliExpress has a sale coming up on some Lunintop Worms in a couple of days. I will pick a couple of those.
https://www.aliexpress.com/item/LUMINTOP-Mini-Worm-AAA-110-Lumens-Keychain-Flashlight-with-clip-1X-AAA-Battery-Cree-LED-Tool/32736465729.html?spm=a2g0s.13010208.99999999.260.41433c00hivyb3
Thanks for the reply.
Jerry
Plotthound
Last seen: 2 months 5 days ago
I just got a couple for $6.96 shipped. The code says black, but it worked for an orange and a red one. I had to buy one at a time.
https://couponsfromchina.com/2018/09/07/astrolux-a01-219b-flashlight-bla...
dealgrabber2002
Last seen: 18 hours 34 min ago
I also got the first batch when it came out. It was not reliable. It either skipped modes or stuck in Med mode refuse to go to High mode. I tried with primary, lithium, and rechargeable (eneloops and amazon basic). I gave up and just toss it in the drawer.
lampliter
lampliter's picture
Last seen: 2 days 4 hours ago
I carry a green one daily; it’s been dropped and banged around; still works fine.
It's only true if you believe it.
jerm03
I had trouble with the first black ones I bought. I would have to reemove the spring and re-insert it with the battery. Did not have ths problem with purple.
ryukin2000
ryukin2000's picture
Last seen: 21 hours 59 min ago
Plotthound wrote:
I just got a couple for $6.96 shipped. The code says black, but it worked for an orange and a red one. I had to buy one at a time. https://couponsfromchina.com/2018/09/07/astrolux-a01-219b-flashlight-bla...
Thanks! just ordered one. i already have one and i think it is almost the perfect edc. o-ring broke off and i cant find the spare so now i get a light and can use the spare oring. hopefully it doesn’t come with NMM that my first one did.
Jerommel
Jerommel's picture
What is NMM?
raccoon city
raccoon city's picture
Last seen: 6 min 8 sec ago
Jerommel wrote:
What is NMM?
Next-Mode-Memory
hank
hank's picture
Last seen: 52 min 54 sec ago
I just got a couple — it’s the no-name driver, but has the 3 levels and hidden strobe.
One of them works fine; the other is intermittent, skips brightness levels, flickers up and down.
No wonder they were on sale.
toddcshoe
toddcshoe's picture
Last seen: 12 hours 11 min ago
Mine has sometimes disease too. Sometimes it works right sometimes it don’t. You never know what you are getting with it. It’s like playing the brightness lottery. You know it will light up, you’re just really not sure of the outcome. It has been relegated to a bathroom emergency light. I’d give it away if I wouldn’t feel so guilty about it.
"Everywhere I go, there I am"
jon_slider
jon_slider's picture
Last seen: 1 hour 4 min ago
Lol!
Youre a good man Smile
did you try the pencil mod?
"High CRI lights for sale":http://budgetlightforum.com/node/72660
lightboks
lightboks's picture
Last seen: 1 week 8 hours ago
got 3 last week. opened them up to do the pencil trick today. took 10 minutes for all 3 lights. Happy with the outcome. All lose memory after 3 seconds and return to firefly. before that with next mode memory as they came, they were basically unusable and a PITA. Now an instant favorite.
not sure if a 8$ light is acceptable if it has to be modded to work as it should.. but now mine is good.
it is probably frustrating for a lot of non knowing people to get the brightness-lottery whenever they turn these on. I would never ever bought these lights if I had not read that I can hack them with a pencil to make them work like the original design.
hank
hank's picture
I made a little hook out of paperclip, fished the spring out from the A01 battery tube, dabbed a little conductive lubricant on the wide end of it and pushed it back in place. That seems to have resolved the flickering problem. Probably if I’d looked I’d have found a sharp cut end on the spring that was making intermittent contact with the base of the battery tube.
It’s the cheap little corner-cutting parts that screw up the product.
toddcshoe
toddcshoe's picture
jon_slider wrote:
Lol!
No, I sure didn’t. It just really wasn’t that important to me. I bought it mostly because the wife liked the color. She swiped up a BLF348 instead. So it doesn’t really get used anyway.
hank
hank's picture
Quote:
did you “try the pencil mod”:https://imgur.com/a/pmSAI?
I greatly appreciate the pointer, very helpful.
buck91
buck91's picture
Last seen: 10 hours 22 min ago
As others have stated, they are next mode. Too bad, great light and perfect for my use otherwise… but the “NMM” completely ruins it for me. I prefer M-L-H but can work with other similar interfaces as long as its no memory.
hank
hank's picture
Just did the pencil fix on one of the two I just got. Perfect behavior now.
I’d like a word with the subcontractor who provided the wrong resistor to the builder (or the purchasing agent who found a great price on “almost close enough” parts).
jon_slider
Yay!
thats great to hear
hank
hank's picture
And done the second one — harder as the wires were shorter, so I had to carefully push the pencil graphite into the tiny gap to hit the right spot. Nevertheless, it’s working properly.
Macka17
Last seen: 1 day 12 hours ago
I got 3 and 4 on order now. magic little good looking lights.
I just turn it on. Not the right beam?. Just click it till it is. Simple.
Have yet to have any intermittent power.
My Kids love them too.
The near perfect torch for walkabout work, Fit in pocket/purse. and about the most well proportioned on the market.
Similar to the S-R1. They Just ‘“feel” right.
bidas
Last seen: 29 min 44 sec ago
I been using one since march 2018 in my keychain, many scratches from drops and keys, but i never got flickers. BTW i didn’t bother “modding” the capacitor because eventually it gets discharged(maybe minutes later or even hours) because the next time i use it starts in moon!
unrealrocks
unrealrocks's picture
Last seen: 1 year 1 month ago
Just ordered one of these, looks like an interesting little torch (especially for so little money!).
One question for those who already have one of these, do you have any thermal issues with running a 10440 in this guy? I love my BLF 348 but it just gets too hot too fast if you use a 10440 rather than an AAA.
buck91
buck91's picture
Hmm, haven’t tried it but generally I didn’t think 5mm LEDs did well being over driven?
