Astrolux S43 - New model (On Sale)
249 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 41 min ago
joechina wrote:
I found this on the Banggood page
Quote:
Lock/Unlocked Function: With the breathing light on the button is unlocked.Click the button at least 1.5seconds when flashlight is off,then the breathing light will turn off and the switch is locked.To activate the breathing light,click the button 1.5seconds again.
Is this wrong stuff from the old S42?
I see problems:
You can’t ramp from off, it shuts off after 1.5 seconds.
You have two electronic lock outs: NarsilM and breathing light.
@Texas Ace
Can you test this on the prototype?
I hope Banggood wrote BS
Yes, that is just a copy / paste from the old S42.
They decided for some reason to wire the LED’s so that both of them are used for the charging and Narsil does not get an LED in the switch. In fairness though I did not realize I would need to specify this in detail until it was too late.
The driver uses narsil 1.3 and all functions are the same. TomE just had to make some back end changes to work with the different pinout that this driver used.
It does have the normal lockout function in Narsil but nothing more.
joechina
Last seen: 19 hours 27 min ago
So it does breath green and and I can switch this off?
ZozzV6
ZozzV6's picture
Last seen: 1 day 12 hours ago
If the pinout is different then I can’t flash regular Andúril to it? I need to modify firmware?
joechina
If you wait a bit, I am sure someone will make an Andúril version.
Texas_Ace
Texas_Ace's picture
The switch LED’s only light up if you plug in the USB for charging. You can change this by moving one of the wires on the driver if you desire to re-enable the Narsil indicator LED.
Texas_Ace
Texas_Ace's picture
Correct, the pinout will need to be changed a little. Pretty sure that TK make this fairly simple in Anduril.
Texas_Ace
Texas_Ace's picture
If it is popular I am sure someone will at some point as well.
shirnask
shirnask's picture
Last seen: 18 min 19 sec ago
Good, which wire do I need to move? – I don’t care about charging in the light
Texas_Ace
Texas_Ace's picture
I only have the prototype drivers and I am not sure what the final drivers / wires setup will be at this point.
This is the charge PCB design though:
You will just need to move one of the wires from either the Charge or standby ports to the main driver IND pad.
The charge pad should be the red LED and the standby the Green LED but like I said, I assembled my driver myself, not 100% sure on the final driver.
shirnask
shirnask's picture
Ok, thanks TA
Phlogiston
Phlogiston's picture
Last seen: 19 hours 48 min ago
Texas_Ace wrote:
I got permission to post the prototype light I got, these are pictures from Mateminco, the ano looks a lot better on mine in real life then the picture look.
Thank you Smile
The prototype tube does look better. Even the production light is sorely tempting me, though. I’m not usually up for this type of light, but wouldn’t mind an easy way to try the Narsil UI.
KevinZA1988
KevinZA1988's picture
Last seen: 18 min 57 sec ago
Hi TA, is a straight MCPCB swap easy to do on this light??
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Texas_Ace
Texas_Ace's picture
Yeah, that is fairly simple, just unscrew the bezel, remove optic, swap mcpcb, reverse process.
vresto
vresto's picture
Last seen: 1 hour 59 min ago
any thoughts about replacing the leds with xplhi?:))
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
KevinZA1988
Thanks
TheAuditor
Last seen: 4 hours 14 min ago
I just got a shipping notice so someone is working in China Smile
Bonum commune communitatis.
Yarp.
Firelight2
Firelight2's picture
Last seen: 6 hours 2 min ago
Sillen wrote:
I like the tip. Good for defence against drop bears.
You want to use the spiked tip on the back of this little flashlight to fight bears? Facepalm
joechina
I got the info from TA that the green LED works as driver LED, like in other NarsilM lights. The red LED is on when charging and off when finished.
It is a last minute change. We will see if all shiped lights got this.
MascaratumB
MascaratumB's picture
Last seen: 58 min 40 sec ago
It’s not “bears”: it’s drop bears Big Smile
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 hours 8 min ago
Are there stand alone charge pcb’s like this for sale anywhere?
Texas_Ace
Texas_Ace's picture
Not that I am aware of. The design will be uploaded open source but not sure it will do any good as I can not find the IC they wanted to use outside of the china. The only way I was able to test it was with the prototype they sent me.
pinkpanda3310
Thanks TA Beer
shirnask
shirnask's picture
Got one in today and the switch light is on when light is off – don’t have to change anything – and I now have protection against drop bears Wink
Sillen
Sillen's picture
Last seen: 4 hours 36 min ago
Lucky you! Mine arrives in Melbourne last Friday but Australia Post haven’t delivered yet, awaiting clearance, so I’m still vulnerable!
Texas_Ace
Texas_Ace's picture
Yes, they made a last minute change and now the indicator LED works like it should.
jdavis
jdavis's picture
Last seen: 1 month 2 days ago
The looks of this thing wasn’t enough to override all of the goodness in it and keep me from ordering a couple of these. They’ve shipped, but I’m still waiting for them to arrive. Perhaps we’ll get lucky and the BG/Mateminco folks will read this forum and in addition to the smaller battery tube, they’ll offer an additional tube (can you say prototype?) that can be ordered later. That way we’d get all that this offers with a much better looking light.
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 50 min ago
Nah, just change out the head from the S42 to the S43.
That would be a great change already. And ask them to make a solderable tailcap for the spring lol. It’s impossible to solder to aluminium in a flashlight, and I want to replace the single phosphor bronze spring for a much more capable dual BeCu spring array.
jdavis
jdavis's picture
I just looked in NealsGadgets @ M4DM4X and the 18650 tube that is being offered with the Mateminco S03 looks to be the same one that was in the photo of the prototype. Does anybody know if this is the same light, and the tube would work? Or how to contact Mateminco to see if they offer the tube only for sale? Just curious.
Texas_Ace
Texas_Ace's picture
Yes, the S03 is the prototype light, with a few minor changes.
nokoff
nokoff's picture
Last seen: 1 day 4 hours ago
Just got my S43 today. Awesome UI. So much better than the S42. The stock photo is a horrible angle; it looks symmetrical and balanced in person. Can’t wait for the Special Metal editions. I’d even like to see a full COPPER of this.
PS wife loves a ramping UI, she took ownership of this one immediately. Back to the S42 for me.
Nokoff..still Made in China 山寨主義
