DIY Glow Gaskets for Triples etc.
46 posts / 0 new
CRX
CRX's picture
Last seen: 11 min 26 sec ago
A wee tutorial on how to make your own glow gaskets for multi emitter lights BLF style.
Making glow gaskets using magnets, glow powder & UV glue.
First I made a template from an old 20mm triple MCPCB to match up with a Carclo 105xx optic. 65mm steel box lid.
This is the most difficult & time consuming part but only needs done once.
A piece of sticky tape placed on the steel surface sticky side up. (Clear tape is best to allow UV hardening of both sides)
6mm x 2mm and 3mm x 2mm magnets, three of each for the optic & leg holes.
Place the 6mm magnets onto the sticky tape using the template.
Then add the 3mm magnets and remove the template, apply non stick grease carefully around the magnets & tape.
Template back in place and thin 20mm ID x 2mm thick outer ring fitted around the template with four large magnets to keep it from movement.
Carefully remove the template again and now we have a mould.
Mix up some GITD powder and UV setting glue.
Apply the mixture to the centre of the mould and allow it to slowly bleed out to the extremities on a flat surface until even.
Next is setting the glue mixture using a UV light source and then slide the tape and moud from the steel.
Carefully peel the tape from the back of the mould and press out the magnets with something like a thin screwdriver.
Remove the outer ring and sand down the surfaces & outer edge of the gasket.
A little tidying up the well holes with a scalpel blade and cutting in an angled bevel in each to suit the optic and it is just about done.CRX glow gaskets
I've found these to be superior to the tape method, although initially more effort.
GITD triple gaskets & fobs.
CRX glow gaskets
Dual colour gaskets.
CRX Powder Gaskets vs ICE Filaments printed ABS GITD version.
So I did a little comparison test over the course of 20 minutes or so with these.
From left to right, CRX Aqua Blue, Green, ICE Filament printed and then CRX Red.
CRX Glow Gaskets
FW3A with green.
Glow brightness/ duration chart.
Making glow gaskets using glow tape.
I find these better than sticking a GITD strip to the inside wall under the bezel.
I have used a sheet of 1mm NBR rubber to make a template for marking out but you can make these without it using the same technique by just pressing the marks into the GITD material.
I used an old optic to mark the three leg positions by pressting the optic into the rubber.
Using a 3mm punch, take out the holes for the legs then press the optic into the rubber again to mark the optic well positions with your fingers and remove with a 6mm hole punch.
Then mark out the back of the GITD tape using the rubber template and take out the holes again with the corresponding cutters. Best to press on an old piece of wood for this.
It can be tricky getting the right position for punching out the holes.
You can use something of the right size to mark the outside edge, use the optic itself or cut freehand.
These discs don't have to be perfect as the optic hides most of it.This is the stickyback version for larger lights where there is more room to stick the GITD tape to the MCPCB.
Noctigon Meteor XP-G2.
I also made some floating double sided discs for smaller lights using the same method as above except I stuck two GITD pieces together back to back.
These are good for where the wires, components etc mean sticking the tape down is not possible, these will also not heat up so much so may increase the life of the GITD tape.
You can also just use a single sticky version here and stick it to the top of the wires but I thought I would try this.
FourSevens Mini ML Ti Triple Nichia 219C.
Convoy S2+ Triple XP-L HI.
Emisar D4 Nichia 219C.
I did a little experimentation with some GITD tape & powder mixes too.
First I thought I would try the heat method to charge these as I have noticed before a slight glow from these compounds when soldering stars that have it around the LED.
I applied various tapes & two powder mixes onto an aluminium plate and heated over a gas burner until they glowed.
Not too impressive after a few minutes.
Next I mixed up some glow powders with UV setting glue and clear silicone.
Charged briefly with an M43 XP-G2 3D on turbo for one minute.
The new LIT powder seems to glow best with a mix of 50:50 UV glue.
Here we have a comparison of the sticky tapes and two types of glow powder mixed with the recommended white acrylic base.
The glow powder mix was made very thick.
Interestingly, the much thicker white acrylic mix glows less after time than the thinner mixes of powder clear & silicone/ UV glue.
After the short charge time it is clear here that the LIT green powder mixed with the UV setting glue glows brightest after one hour.
I used approximately the same amount of powder in each mix.
Also note the cheap green glow sheet is brighter than the 3M 6900...
I think some more playing around with the ratios in the white acrylic mix is needed to determine if it is the best medium for the glow powders.
The LIT powder does glow with a little more intensity than the KillaBitz stuff to begin with but it is not revolutionary.
I must admit that I had high hopes of this stuff charging up by heat, imagine applying to a groove in the head of a light and having the heat charge up the glow - cool Wink
So I applied a little sample of each powder mixed with the acrylic base to the case of a little Nichia 219C triple hotrod to see what would happen. Wasn't quite the result I hoped for but like I said earlier I probably made the mixture too thick.
I might try some more thermochromic experiments too.
Feel free to post your own ideas here too.
Edited by: CRX on 06/12/2019 - 18:47
DavidEF
DavidEF's picture
Last seen: 4 days 9 hours ago
Those look good! Nice job! Thanks for the tutorial.
- The YKK Philosophy
Ford Prefect
Ford Prefect's picture
Last seen: 2 months 4 weeks ago
Nice work CRX, a lot less messy than me mixing V10 powder with epoxy and slopping it around. Oops
I will be looking for some GITD tape for future glow mods.
CRX
CRX's picture
Thanks, though I rushed these a bit they still look alright. Thumbs Up
Yeah I just added some GITD to these 47’s too with the powder & epoxy, not as easy.
MRsDNF
MRsDNF's picture
Last seen: 6 hours 49 min ago
Sweet, love the look. Beer
Agro
Agro's picture
Last seen: 2 hours 46 min ago
Would it be possible to use Lexel’s lighted TIR board with UV LED to excite the phosphor? Should allow much cleaner beam than the LEDs by themselves. Smile
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 days 40 min ago
Nice work as usual CRX!
May I ask what triple optic you used to explain the development process?
duramax
Thank you for posting this! Very insightful and I have never approached this kind of mod before. I might now!
pinkpanda3310
pinkpanda3310's picture
Last seen: 10 hours 23 min ago
Nice. 4 triples and 2 quads please Mail Cool
Agro
Agro's picture
I wonder if someone could create printable templates for common optics…
CRX
CRX's picture
Agro wrote:
Would it be possible to use Lexel's lighted TIR board with UV LED to excite the phosphor? Should allow much cleaner beam than the LEDs by themselves. :)
Here's some examples using the SGN3, Off, low white, UV, Red, Off.
I don't think having low powered charging LED's close to this tape would work very well. Maybe that setup would work better with the tape on the sidewall?
I did use a similar method on the SL, these are eight fairly strong UV LED's though.
Thanks. Carclo 10507 20mm size used there.
pinkpanda3310 wrote:
Nice. 4 triples and 2 quads please Cool
We're out of quads at the moment but I got your triples Silly
Agro wrote:
I wonder if someone could create printable templates for common optics...
There is someone selling printed versions, wouldn't be too difficult to make I think. (With a printer) Innocent
Agro
Agro's picture
Doesn’t ship to my country.
Anyway, I may try to print some template. Probably no earlier than October though….
CRX
CRX's picture
Cool. Show us what you come up with Thumbs Up
I’ve seen a few different guys advertising these, pricey though and some are too thick, cause problems.
finges
Last seen: 1 hour 45 min ago
Thanks to this thread I got the motivation to do the same on my M43.
A little sloppy but I like it Smile
CRX
CRX's picture
Nice, thanks for showing Thumbs Up
DavidEF
DavidEF's picture
Wow finges, that GITD looks really bright! Is it that bright in real life? You almost don’t even need the flashlight!
finges
I took this pic directly after a turbo blast with the light directly against a white wall Wink
BobG
BobG's picture
Last seen: 7 months 2 weeks ago
Is there a good GITD paint available? Seems like that might be easier and neater for some of these applications.
Agro
Agro's picture
This one is highly rated:
http://glow.glowinc.com/glow-in-the-dark-paint/new-category/
Note that they don’t ship paint internationally.
It is also possible to buy pigment and mix it with paint.
fluke
Last seen: 1 day 17 hours ago
What quads do you do?
CRX
CRX's picture
Haven’t done any quads with the powder as I would need to make another mould but they would be made the same way.
fluke
OK keep us posted.
Pwsmith
Last seen: 3 months 15 hours ago
Sorry for the possibly dumb question but what is the 20×2mm ID?
CRX
CRX's picture
20mm ID x 2mm means a 20mm internal diameter x 2mm thick.
Probably not termed correctly Innocent
Pwsmith
That makes sense! I was thinking it was the name of something when I read it. Where could I find something like that? I’ve sourced pretty much everything else! And any preference on the type of grease?
CRX
CRX's picture
I’m always scavenging bits & pieces of stuff that I think I might find useful when I come across them, no idea where that ring came from.
Just try to find a piece of tube the correct diameter or order a small sample piece etc.
I use light white lithium grease.
Moly is a bugger to get rid of, silicone grease doesn’t work too well.
Also, you’re better using white or preferably transparent tape.
Once you’ve used the UV light on one side you can flip the mould over and blast the other, useful if you make a thick mix as sometimes the UV light doesn’t penetrate all the way through.
You’ll figure out your own way Thumbs Up
Pwsmith
I have everything sourced and ready to go but for the life of me, I can’t seem to get the drilling to come out right manually. I’m tired of ruining boards! I can always wait a few months til I visit my folks and use the old mans drill press. But I was thinking maybe I could order a custom mcpcb from oshpark. So i downloaded some pcb making software but there doesn’t seem to be a simple way to just tell it to put holes in places. Does anybody have any experience with that kinda stuff that could guide me to do that? Is it even possible?
CRX
CRX's picture
You mean drilling the template?
Drill smaller holes than needed and hand file them to the right size/ positions with small diamond files, that’s what I did anyway.
Trying to drill the holes manually first time will lead to lots of… experience Wink
DavidEF
DavidEF's picture
What software are you using? Eagle does make it easy to add holes. At least it seems easy to me. Innocent
Umpi2000
Last seen: 2 hours 37 min ago
Who was it that used a 3D printer to make some glow gaskets? I’d love to get my hands on the cad/stl so I can get one made locally
kikkoman
kikkoman's picture
Last seen: 6 months 1 week ago
Here’s one that has slots for tritium vials (not shown in the preview, it’s lying on its top side).
Though it might make more sense to print a mold from this so you can cast them in silicone + glo.
No idea what filament doesn’t stick to silicone, you might have to experiment with that.
https://www.thingiverse.com/thing:3667132
