DBSAR Lantern Mini-Review: -Zanflare T1 (UPDATE: Second T1 failed!
181 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 5 hours 23 min ago
gadabout wrote:
Typically I have been using the lantern attached to a metal surface. I chose to let it hang so the magnetic cap could not use the metal as an additional heatsink.
I was just thinking about this earlier. Does the magnetic cap physically touch the metal surface?
If so, Zanflare could ship everybody a “fix it kit” to prevent thermal excess. It would be an 8” piece of square sheet metal. Silly
Hang the metal “heatsink” in your tent and attach the lantern to it. Makes for a super steady base when not hanging. Big Smile
I’m just goofing around.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
gadabout
Last seen: 8 min 15 sec ago
Goofing noted…
Checking using a steel ruler, it appears the tailcap and the plastic base are exactly flush when screwed down tight. You could always back the cap out a little if it wasn’t, as the threads are not anodized. So yes, the magnetic tailcap does physically touch the surface.
Having said that, I suspect that the amount of heat drawn out through a few threads and layer of paint over a circular contact surface only 20mm (3/4”) in diameter would be pretty minimal.
I just wanted to rule that possibility out for my tests.
finges
Last seen: 7 hours 23 min ago
The “fix it kit” could also be a bigger tailcap with fins, so it would screw directly on the heatsink.
djozz
djozz's picture
Last seen: 49 min 8 sec ago
I think we need some numbers here.
We humans feel pain at 55 degrees Celsius, and experience that as alarmingly hot. Electronics can withstand 250 degrees Celsius and more. Li-ion batteries are in between, thermal runaway starts only at over 150 degrees Celsius, but I guess degradations of the battery already starts at lower temperature. But still I reckon that a battery at 80 degrees Celsius (way too hot too touch) would not be unsafe? Anyone with more knowledge about that?
Btw, thanks for the very good hands-on review Den!
tatasal
Last seen: 4 min 26 sec ago
Btw, thanks for the very good hands-on review Dan!
Exactly my point in my post in the gb thread.
Agro
Agro's picture
Last seen: 3 hours 5 min ago
HKJ frequently ends his tests with temperatures well over 50 Celsius degrees over ambient. Maybe the cell vented because it was somehow faulty?
ADDED:
Mooch frequently exceeds 80 degrees. Sometimes 90.
Quick browse and I found him going to 97:
https://www.e-cigarette-forum.com/attachments/799b153b-6d58-480f-a0e8-0f...
JasonWW
JasonWW's picture
All the HKJ reviews I’ve read he usually ends the amp draw tests early if they exceed 80°C. For a continous discharge rating it has to stay under that temp.
In those tests the battery chemistry is generating the heat, not it being heated by an external source. Maybe that’s an important distinction?
Based on Mooch’s background, he’d know for sure.
Agro
Agro's picture
I PMed HKJ, maybe he’ll comment…
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 17 hours 30 min ago
A member of the German TLF just checked his Zanflare T1 with the original batteries. He also used an IR thermometer. These are the results:
Discharge start @ 4.12V, maximum brightness in coldwhite:
o IR-temp. on tailcap: 0:00h 25°C, 0:15h 41°C, 0:30h 48°C, 0:45h 51°C, 1:00h 51°C
o IR-temp. after 1:00h on battery inner tube, max. 10s after interruption of operation / removal of battery: 53°C, 3.7V resting voltage
Zulumoose
Zulumoose's picture
Last seen: 1 month 17 hours ago
Test means nothing if we do not know the conditions of the test.
Ambient temp?
Airflow?
Orientation of lamp?
Material in contact with tailcap?
Ideally the test should be done without airflow at a known ambient temp in worst case scenario of lamp standing upright on an insulating surface like wood, or even worse on material, such as a tablecloth, blanket etc.
Beam me up!
HKJ
HKJ's picture
Last seen: 2 hours 32 min ago
I doubt a cell vents below 90°C internal temperature. The internal temperature will depend on current draw and internal resistance in the battery (And of course ambient temperature). This means that the risk of a venting cell will be high when using a cell with a current draw that makes it hot when the tube also is warmed from the led.
I wonder how much the led heats up the interior of the battery tube at the top, leds can run above 100°C (The temperature of the tube may not tell the full story).
Aleister
Aleister's picture
Last seen: 1 hour 43 min ago
Thanks for the heads-up DBSAR.
After 10 days of daily usage of my three T1s, today, just before I read your post, my daughter bring me her T1 so I can recharge it and for the first time I noticed the very hot tail cap. Hasn’t happened until today even after hours on max so my guess – and its only a guess – maybe not all T1s have that issue?
I will keep my eyes open about this dangerous behavior.
Let a flooder be my wife and a thrower be my mistress
Lightbringer
Lightbringer's picture
Last seen: 17 min 42 sec ago
Lux-Perpetua wrote:
Thinkin’ about venting gas and sweet smell…the T1 could actually compete with this nice device:
https://www.banggood.com/Digoo-DG-HM1-Pearl-Wood-Grain-Aroma-Diffuser-Hu...LED-p-1090719.html
Just kidding, of course! Evil Big Smile
I still say “Sweet Smell Of Death” would be an awesome name for a thrash-metal band.
Lightbringer
gadabout wrote:
The first test has now run to completion. I got a further 55 mins or so on MAX CW and the tube and cell were still not “hot”. I’m topping off a protected Panny 3400 at the moment for another test.
Your idea of sitting it on an insulating surface might have to be part of my further testing but I’ll wait until I get my IR gun back again after the weekend.
Just thinking out loud here… and getting strange looks from people around me.
Know the Nitefox UW360 flex-neck light-thingy? It comes with a magnetic-suck base (seriously!) and a ferric disk to act as a wider stabilising base, and to be able to stick it semi-permanently to another surface.
Well, what about something similar, a ferric disk that would stick to the magnetic-cap of the T1, and with a wider base and thus more surface area, wick away heat to the outside world?
Lightbringer
Bugger, I just suggested that about a minute ago.
Doesn’t seem like a bad idea. See the UW360, ‘though that’s not for heatsinking.
I’d imagine the T1’s cap has to make contact with a bottom surface, else there’d be an air-gap that’d seriously reduce its magnetic-suck action.
Pete7874
Pete7874's picture
Last seen: 1 hour 14 min ago
JasonWW wrote:
Another short-term fix would be to swap out the factory battery for a protected 18650.
My protected cells are too long to fit this lantern.
Coscar
Coscar's picture
Last seen: 9 min 24 sec ago
I have 3 T1s …… I ran all 3 for several hours on high CW and the tailcaps on all remained as cool as the ‘outside’ of my fridge….. Not saying this couldn’t change in the future but if there is a heat problem then it seems it may be a QC problem and would not be occurring in ALL T1s.
Im not a Pessimist …. just an Optimist with a lot of experience
tatasal
Considering the majority of present owners of the T1 are not experiencing the same thing as the op while using the cell that came with the unit but from a known old cell (might’ve already high IR) , shouldn’t it be fair to Zanflare to have this thread’s title edited ?
DBSAR
DBSAR's picture
Last seen: 2 hours 6 min ago
In my case it was a used older cell that overheated & began to gas fumes due to the battery tube being hot from the LED that are attached to it inside. It may not happen to all 18650 cells, but its still a potential risk with a weak, older, cheaper, or damaged cell in the lantern. When it comes to lanterns in particular, i focus on all safety concerns and potential hazards. unlike flashlights, lanterns will more likely be left unattended for long periods of time running in a tent or house, resting on or near flammable material. (even when people are asleep) and even if just one out of 500 of them that has a bad cell it it that causes its battery to gas or go full-vent due to the heat and catch fire is a concern.
No doubt that most who have this lantern may never have a problem, but the risk is there because of the flaw in that design using the same battery tube metal as the LEDs direct heatsink. My personal feelings on this lantern is that Zanflare should either reduce the maximum mode amp load, or re-design the LEDs to be on a separate sleeve with an air-gap from them to the battery tube. ( but neither is likely as they woudl probably discontinue it and offer a new re-designed model.
tatasal
Well, to be fair to Zanflare and the rest of the owners, such sweeping conclusion in this thread’s title (“Dangerous Flaw Discovered”) should be qualified with an additional note like “using a used, old cell, etc.” information.
No doubt you have good motives to bring this out to our attention yet one sample with such cell behavior from an old cell doesn’t necessarily require such sweeping conclusion.
Coscar
Coscar's picture
I may be missing something but it seems to me if the “design” was the problem…. it would affect all the T1s. I definitely think if they implemented your suggestions the design would be safer but think it is a little unfair to blame the design if the problem is only caused because someone uses an old or defective battery. That’s like blaming a gas car’s design because you put kerosene in it. You could re-design the car so kerosene would work or simply use the proper fuel so you don’t create a problem where one does not exist.
DBSAR
DBSAR's picture
it do not matter if its an old or new cell. the lantern has a flaw that directly heats up the cell with the LEDs. not everyone who may buy this lantern will understand what we know about Lithium Ion cells and LED lights. someday someone could put a cheap ultrafire cell on this lantern and it go bad. If a product i test has a potentially hazardous flaw, i will expose it and make sure people are aware of it.
Coscar
Coscar's picture
and that would be “someone” at fault wouldnt it….. not the lantern?
DBSAR
DBSAR's picture
your missing the point. the lantern has the flaw of heating the cell, that people are not aware of.
Jerommel
Jerommel's picture
Would be fair though, to test it with the cell it came with and see if the problem still occurs.
And for good measure, test it with a Japan made cell.
Just to make sure it’s not your old battery.
2Q19
Coscar
Coscar's picture
Maybe I am, but again, if this IS a ‘design flaw’ then why does my tailcap remain cool after hours of continuous use when I use a decent battery?
DBSAR
DBSAR's picture
maybe your particular lantern has a flaw and don’t run at full output like the others. LEDs will produce heat when running at higher modes. its fact. at 1 amp draw the tube inside my L1 gets so hit it almost burns my finger. The cap gets quite warm, but not as hot as the insides sides of the battery tube.
tatasal
User’s misuse/misapplication in the boon of all manufacturers… but if this all they consider all the time, no one can ever sell in the market anything anymore.
Adding to that, no manufacturer can predict and write all disclaimers as a safety measure.
And when using your vehicle… please don’t use kerosene and turn left when the road curves to the left…
tatasal
DBSAR wrote:
maybe your particular lantern has a flaw and don’t run at full output like the others. .
…or perhaps it’s the other way around? Numerous owners has already posted that their unit, using the OEM cell, does NOT heat up unlike your unit using your old cell…
DBSAR
DBSAR's picture
Jerommel wrote:
Would be fair though, to test it with the cell it came with and see if the problem still occurs. And for good measure, test it with a Japan made cell. Just to make sure it’s not your old battery.
I am running a new test now with a new LG HE4 high drain 2500mah cell. I turned it on now at 9:13pm EST, on maximum mode, with the tint set to roughly 4000K ( so that all the LEDs are on at the same time, (except for the red) and will let it run for 30 minutes then check the temperature of the cap, & the temp of the inside of the body of the battery tube.
- Will post the update in 40 minutes.
