Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1239 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 days 15 hours ago
Yep, anduril.2018-09-07.BLF_Q8.hex
Edit: Just cracked it back open and checked, no wires pinched and all wires still solidly soldered. No side switch light. Not that it really matters, I’d turn it off if it was on, but it’s odd that it quit working.
klrman
klrman's picture
Last seen: 1 hour 39 min ago
Mine came this morning.  Cleaned the contacts, tightened screws in head and cap and did the ceiling bounce test.
Thanks for the deal Sofirn, I really like this light.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 9 min ago
That’s weird. At first I figured I must have broken something, but that’s the same file I just put on mine and it runs normally.
I wonder if the driver design was changed at some point, or if a wire may have come off. If you plug in the usbasp and clip it onto the MCU, but don’t flash it, does the switch light come on? On mine, it does.
teacher
teacher's picture
klrman wrote:
teacher wrote:
klrman wrote:
I just charged  four new 30Q button tops to 4.1V and they ended up from 4.080 to 4.091V. Is the spread in voltage safe enough to use in parallel in my Q8?
That is a difference of ’11 thousandths’ of a Volt klrman… Nothing at all to worry about in any way for parallel or series connections.
I thought it was 11/100th of a volt? I was just curious as to what the threshold would be just for my own info.
Nope… .011 is eleven thousandths. Jason either made a typo or thought that too.
As far as a threshold….. A tenth of a Volt ( 4.10 vs. 4.20) should be fine, probably 15 hundredths (4.05 vs. 4.20) would be too.
But IDK for sure, hopefully someone with the technical knowledge to answer correctly will chime in.
4.091 – 4.080 = .011 = (11 thousandths)
DB Custom
DB Custom's picture
Odd, I had 3 5700K XP-L2’s in a sealed tape with the order label accompanying them, and 2 5000K XP-L2’s in a sealed tape with their original order label accompanying them, separted in my emitter kit and clearly labeled. I put the two 5000K’s on first, opposing each other on the board, then I placed the 5700K’s on the remaining opposing pads. Re-flowed it, assembled the light.
So now, checking with a UV light, it doesn’t look like what I know it is…
BlueSwordM
BlueSwordM's picture
Last seen: 5 hours 42 min ago
Wouldn’t it be better to use IS units?
Writing a delta of 11mV would have been much easier to understand, and there would have been no confusion that way.
DB Custom
DB Custom's picture
Yes TK, when I plugged the clip on the chip the light came on. Pretty sure it was on while it was flashing Anduril.
Leave it to me, huh? LOL
ToyKeeper
ToyKeeper's picture
It’s not really a threshold sort of thing. Small differences have a small effect, big differences have a big effect. Just try to get things as close as you can, and the effects should be small.
I have a 2-slot charger instead of 4-slot, so I can’t charge all 4 cells exactly at the same time… but as long as I do each set of 2 one after the other, on the same charger, they end up almost identical. It’s probably safer than using two different chargers, since each charger has a different termination voltage.
DB Custom
DB Custom's picture
TK, it came on when I hooked it up to flash, it doesn’t now.
ToyKeeper
ToyKeeper's picture
That pretty much narrows down the issue to firmware, unless the button LED was moved to a different pin. But probably firmware. I don’t know why it would work on mine but not on yours, though.
I should probably open a bug for this, until an explanation is found. And, for that matter, I should probably actually be using the bug tracker instead of leaving it empty. Has anyone else tried Anduril on a new Sofirn Q8?
… moments later …
In that case, maybe it is just a loose wire. Could be loose on the switch PCB where it’s harder to see, perhaps? Not sure.
DB Custom
DB Custom's picture
TK, did you remove Beacon? The only things I can see that don’t work like I’m used to seeing from Anduril is the lighted switch and there’s no beacon. I have Candlelight, Bicycle Strobe, Party Strobe, Tactical Strobe, Lightning. Everything else I use works fine. It comes on at the top of 7135 after a battery change, it blinks once when you get power connected, ramp works fine, double click to Turbo, the Candlelight and Party Strobe adjust up and down as usual, can’t find any other issue.
teacher
teacher's picture
Not for me… you almost lost me in what you wrote above. Shocked . Big Smile . Big Smile
I jest learnt the three R’s… Redin… Ritin …. Rithmatic
What is an “IS Unit”?
  • I am guessing “delta” means a difference??
  • And 11 mV is .011 V ??
BlueSwordM
@teacher
1. IS unit = International System of Units. We don’t use pounds, Fahrenheits there Silly
2. Delta means difference yes.
3. 11mV = 0,011V yes. 100mV= 0,100V
ToyKeeper
ToyKeeper's picture
Beacon should still be there… but it’s in the battcheck blinky group, not the candle/strobe group.
Honestly, the groups aren’t really organized all that well. It was more of an organic growth process than a carefully-considered design.
klrman
klrman's picture
teacher wrote:
klrman wrote:
teacher wrote:
That is a difference of _'11 thousandths'_ of a Volt klrman... Nothing at all to worry about in any way for parallel or series connections.
Nope... *.011* is eleven thousandths. Jason either made a typo or thought that too. As far as a threshold..... A tenth of a Volt ( 4.10 vs. 4.20) should be fine, _probably 15 hundredths (4.05 vs. 4.20) would be too_. *_+But IDK for sure+_*, hopefully someone with the technical knowledge to answer correctly will chime in. . !{width:75%}https://sp.yimg.com/ib/th?id=OIP.r9uwb1RJVf-rA_iRu5ewwwHaHk&pid=15.1! . . 4.091 - 4.080 = .011 = (11 thousandths)
Well then, 11 thou does not sound like a huge difference in voltage that's for sure   Thanks for taking the time to run that by me teacher
BTW, here's how my BLF Q8 looks compared the the Sofirn.  Crappy camera but still can see.  Very nice white light on the Sofirn.
Newlumen
Newlumen's picture
Last seen: 2 weeks 3 days ago
So I sent email to amazon about my q8. I got replied within 5 hours. They said they have to get the light from another location.. oct 4 was original delivery date.
They upgraded the shipping to 2 days.. Friday is expected delivery..
Sound fair.. amazon do good job..
klrman
klrman's picture
ToyKeeper wrote:
It's not really a threshold sort of thing. Small differences have a small effect, big differences have a big effect. Just try to get things as close as you can, and the effects should be small. I have a 2-slot charger instead of 4-slot, so I can't charge all 4 cells exactly at the same time... but as long as I do each set of 2 one after the other, on the same charger, they end up almost identical. It's probably safer than using two different chargers, since each charger has a different termination voltage.
Thank you ToyKeeper!  It tells me I was overthinking it all as usual.
light junkie
light junkie's picture
please add me to i terest list
Lj
DB Custom
DB Custom's picture
Ok, until I get a lens in this will be a final… 9453 lumens.
That’s another 518 lumen gain. Simply by switching from Samsung 30Q cells to Samsung 25S cells. Big Smile
Edit: Just for notation, this is a 3678 lumen increase over the stock light that just came in at lunch today. I think I can deal with that…. Wink
teacher
teacher's picture
BlueSwordM wrote:
@teacher
Thank you Blue!! I have learned something, I appreciate the explanation. Thumbs Up
teacher
teacher's picture
klrman wrote:
teacher wrote:
Nope… .011 is eleven thousandths. Jason either made a typo or thought that too. As far as a threshold….. A tenth of a Volt ( 4.10 vs. 4.20) should be fine, probably 15 hundredths (4.05 vs. 4.20) would be too. But IDK for sure, hopefully someone with the technical knowledge to answer correctly will chime in. . . . 4.091 – 4.080 = .011 = (11 thousandths)
Well then, 11 thou does not sound like a huge difference in voltage that’s for sure   Thanks for taking the time to run that by me teacher
BTW, here’s how my BLF Q8 looks compared the the Sofirn.  Crappy camera but still can see.  Very nice white light on the Sofirn.
My pleasure my friend!! Yeah, that is a pretty tiny difference for sure. Thumbs Up
Thanks for the comparison beam shot. That really does show the difference. I am loving the beautiful white of the Sofirn!! Thumbs Up
Brainsick67
Brainsick67's picture
Last seen: 4 months 3 days ago
That is great..THANKS AMAZON..
I'm ThatCrazyFlashaholic 67
Brainsick67
Here is my Unboxing, def a better CW tint then i thought, Sofirn can be a hit and miss.THANKS ALLOT FOR WATCHING
https://m.youtube.com/watch?v=uG2dmXYGISU
JasonWW
JasonWW's picture
Last seen: 6 hours 26 min ago
I corrected my original post. Facepalm
teacher
teacher's picture
Hey… stuff happens. Wink
I had to double check before I wrote that to make sure I was right. Big Smile
Doubt started creeping in…… Shocked Hat
Newlumen
Newlumen's picture
Nice bro.. just need to clean the contact points.. amazon shipped out my powerful flashlight.. it should arrived on friday. ( one week early )..
jigsaw
jigsaw's picture
Last seen: 2 days 49 min ago
In the beginning, I said I wasn’t going to buy one because of the tint. I ordered one anyway, knowing I could flip it to a friend or co-worker if I hated it. Nope! I’m keeping it. I like how much different the hotspot is when I do a side-by-side with my BLF Q8. Great job Sofirn!
Brainsick67
My beam shot of the Q8..great performer, sorry these arent the best quality..but i dig the Q8.
https://m.youtube.com/watch?v=0sYhg3HWFQo
Brainsick67
Thats great man, i did do that…Fri will be a good day for you.
Brett
Brett's picture
Last seen: 3 months 2 days ago
 Im interested in 2 Sofirn Q8s from Aliexpress in Australia if i can still get in on this Group Buy ??
Brett
