Nitecore NU20 Rebuilt
20 posts / 0 new
CRX
CRX's picture
Last seen: 6 hours 19 min ago
I recently had a near fail modding my MecArmy SGN3 with a lighted switch but managed to save it by making a new case after destroying the original.
Mecarmy SGN3 Nichia 219C 4000K, Red, UV - SD - El Lighted Sw - 180lm..
Well, I've been at it again this time with the Nitecore NU20 after I snapped the clip off the back Innocent
Messy...
Now where's that piece of old shower rail... Big Smile
I reorientated the dual sided PCB 90°, swapped the XP-G2 for a Nichia 219C 5000K, made a remote micro USB charging port and installed a green 1206 LED at the switch in line with a 15k resistor and got to work with the aluminium box tube.
I siliconed a 20mm ARC glass into the case once the front hole was finished.
Magnets installed and components roughly fixed in place. I used an old micro USB plug with grease on it and an 8mm round magnet with some blutak to keep the ports clean and allow easy removal once the JB Weld has set and then filed the ends flat.
Then I cut in some lines on the front & back with a junior hacksaw and stuck a 6mm round magnet onto the switch covering using an 8mm x 1mm rubber o-ring to keep it centered, after setting I mixed up some clear silicone & green GITD powder and replaced the o-ring with that.
Some tidying up later...
The light from the main emitter charges the GITD when on.
Would be better with a clip you say?... Wink
Charging indicators red & green can be seen through the switch and around the reflector due to the 20mm glass.
Set.
Edited by: CRX on 09/01/2018 - 17:45
MascaratumB
MascaratumB's picture
Last seen: 6 min 22 sec ago
Shocked Shocked Shocked Shocked Shocked Just this and claps!!! Hat Brilliant work, again, mate Beer
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
GIVEAWAY - 1
CRX
CRX's picture
Beer
SKV89
Last seen: 9 hours 13 min ago
Wow that is hardcore Thumbs Up
CRX
CRX's picture
I’m just warming up LOL
Gebe
Last seen: 1 day 16 hours ago
Like all of your stuff, that IS BRILLIANT!
Hey, just a thought, wonder what you could come up with, with one of the teeny, tiny Nitecore NU05 Headlamp Mates? Looks like a project that’s right up your talented alley. Big Smile
CRX
CRX's picture
Thanks.
I hadn’t seen the NU05. I might have considered it if the UI was CRX friendly.
blueb8llz
Last seen: 12 hours 3 min ago
That’s a beaut. Looks like it was scratch up easily?
CRX
CRX's picture
Thanks, Yeah the bare aluminium is fairly soft but these are my “fridge lights”, I keep them in the kitchen stuck to the side of it so they don’t really come into contact with anything.
The tube was like anodized, a bugger to sand off really but I didn’t like the dull grey colour.
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 17 hours ago
The master himself creates another beauty from a mishap. Love
CRX
CRX's picture
Thanks Moose Smile
CNCman
CNCman's picture
Last seen: 6 days 15 hours ago
I have been suspicious the Chief Engineer for the Starship Enterprise is here among us modding flashlights.
Nice light, but nicer ingenuity by you CRX . Beer
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Good Intentions are no guarantee for Good Results.
Gebe
He is the masterbuilder!
finges
Last seen: 1 hour 45 min ago
How did you swap the LED of the NU20? Hot air?
CRX
CRX's picture
I used a soldering iron.
finges
Ok, and than you held it to the side of the led or at the other side of the pcb? I am asking because I want to change mine to a LH351B 3000k.
CRX
CRX's picture
Held it to the side of the emitter and tweezers on the emitter, comes off fairly quick, same technique replacing.
Hoop
Hoop's picture
Last seen: 1 day 17 hours ago
Dang. Nice work! Looks real posh.
finges
Thanks will try that!
M4D M4X
M4D M4X's picture
Last seen: 1 hour 42 sec ago
i am blown away every time you present your wizardry! Beer
already member of M4DM4X.com ?
the best deals are waiting for YOU!
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
