[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ALIVE
2224 posts / 0 new
PBWilson
Last seen: 2 hours 9 min ago
Any idea what price range this one might be?
AEDe
AEDe's picture
Last seen: 14 hours 33 min ago
It use simple driver not buck boost, and very similar to D4. so my guess ~40-45$.
amars7
Last seen: 6 days 13 hours ago
Interested pending more info
freeme
freeme's picture
Last seen: 7 hours 18 min ago
Mass production has begun. cool
JordanZHP
Last seen: 11 min 25 sec ago
Awesome! Any news on tint options?
dmsoule
Last seen: 51 min 43 sec ago
ToyKeeper wrote:
I have some info. The design isn’t set in stone yet, and I hear Fireflies is still doing changes to the host and the clip and maybe some other things. But here are some random observations so far:
  • It’s a right-angle light.
  • Mine has 4 × 219B emitters, so the tint and beam are very nice.
  • It’s about 88 mm long, 24 mm across the body tube, 26.5 mm across the tailcap, or about 40 mm deep at the head.
  • It seems quite heavy for a headlamp, but I don’t have a headlamp holder which fits it so I haven’t actually tried to wear it.
  • The battery is a 21700.
  • The driver is a FET+3 with a tiny85, much like the Emisar D4S. It runs Anduril, but I still need to get a few things working.
  • It has 12 blue aux LEDs and 2 red aux LEDs under the optic. It changes from blue to red at 3.3V, and turns off below 3.0V. Otherwise, these aux LEDs are always on. I’m hoping it can be connected to a dedicated pin on the MCU, so the user can turn it on and off. There is a pad on the driver labelled “aux” with nothing connected, so it seems likely.
  • It also has aux LEDs around the button, but they’re not visible in my prototype. Like the ROT66, it seems to have two blue LEDs which are always on, and two which might be controllable, but on my sample the latter two never turn on. That’s probably something for me to fix.
  • The tail PCB and driver PCB are at extreme opposite ends of the light, with a cell between. The emitters and optics are off to the side at 90 degrees. The switch PCB is directly on top of the driver.
  • The body tube’s threads go rather deep into the head, so it takes a while to unscrew the tube. It seems to also double as a retaining ring for the driver, like how the Emisar D4 is designed… so it’s recommended that you leave the body tube tightened.
  • The button is recessed just far enough to be flush with the edge of the light.
  • I’m not sure how the head is held together, but it looks like the entry points are the lens retaining ring and the button retaining ring… which both look like they might be press-fit. It may be difficult to do emitter or driver mods. However, the driver has Lexel’s flashing pads, so the firmware can be probably changed without removing anything. (“probably” because it’s 2cm deep in a hole, and I’m not sure how deep the pogo pins can reach)
  • There is a magnet in the tailcap, and it is strong enough to attach the light to solid metal surfaces.
Sorry this is all pretty disorganized. I haven’t had a chance to really work on it yet.
Thanks for these details, Toykeeper. Do you know the weight? For comparison, the new Acebeam 21700 headlamp is 80g without the cell and harness, and the ArmyTek Wizard Pro USB model is 65g.
freeme
freeme's picture
We are so close to completion.
Gerrit
Last seen: 2 days 9 hours ago
Interested
RobertB
RobertB's picture
Last seen: 1 day 12 hours ago
Wow, 3 days from “the design not set in stone”, to mass production. And 1 month from a facebook announcement with a CAD drawing to full production. We’ve got the wrong companies working on the BLF lights taking 1 to 3yrs.
Mass production also means the specs must be set. Lets hear what they are
Nicolicous
Nicolicous's picture
Last seen: 5 min 39 sec ago
wow nice
definitely interested
Nico -.-
freeme
freeme's picture
ToyKeeper is involved in PL47 Anduri firmware. She has already shared some of the details on the driver and light construction.
http://budgetlightforum.com/comment/1385571#comment-1385571
Full specfication will be made known right before / during launch.
RobertB wrote:
Wow, 3 days from "the design not set in stone", to mass production. And 1 month from a facebook announcement with a CAD drawing to full production. We've got the wrong companies working on the BLF lights taking 1 to 3yrs. Mass production also means the specs must be set. Lets hear what they are
Dirt
Last seen: 2 months 6 days ago
How did I miss this one? I’m IN!
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 2 days ago
I am finally interested in the light.
SKV89
Last seen: 1 hour 1 min ago
Looks really good. Can we get the aux in cyan like the D4S, amber, or pink/purple?
lohtse
lohtse's picture
Last seen: 4 months 4 weeks ago
Anyone have any figures regarding lumens and runtimes???
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 42 min ago
The prototype I have is not the final design, so I haven’t shared any pictures. It’s just a close enough design for some testing purposes.
Nguyen
Nguyen's picture
Last seen: 2 days 22 hours ago
Interested
Eraursls1984
Last seen: 1 hour 15 min ago
twisted raven wrote:
That’s kinda cool that they pushed forward the emitters and optics so the battery could tuck behind it all to make it overall shorter than a Zebralight 18650 headlamp, even though it uses a 21700.
I see a few people in here really care about the length. For me length isn’t much of an issue, it’s the width that makes it uncomfortable to carry.
Silent_Star
Silent_Star's picture
Last seen: 1 month 6 days ago
Interested.
 Genesis 1:3 "And God said, "Let there be light,"  and there was light."
Tally-ho
Tally-ho's picture
Last seen: 4 hours 37 min ago
Tally-ho wrote:
Interested.
EDIT : interested if parts are not glued !
Kozy
Kozy's picture
Last seen: 1 month 1 day ago
Interested Thumbs Up
Angel Martínez
Last seen: 4 days 14 hours ago
Interested
dompred
Last seen: 4 hours 57 min ago
interested too
McLight
McLight's picture
Location: German rain does not fall, our rain occupying the area.
Interested!
In GoD & Trance we trust, the rest pay Cash!!
Plotthound
Last seen: 1 week 3 days ago
I’m interested.
zotee123
Interested.
P33
Last seen: 2 days 13 hours ago
Is it going to be sold with a headstrap?
If it does, I’m very interested.
Rusty
Rusty's picture
Last seen: 7 hours 16 min ago
Interested
FireFlies
Last seen: 5 days 9 hours ago
P33 wrote:
Is it going to be sold with a headstrap? If it does, I’m very interested.
Yes, regular headlamp belt can be used on this light. PL47 uses 21700, this form factor is not so good for using as a headlamp. Gross weight is near 150 grams including the battery.
Official store:
www.ff-light.com
JordanZHP
Hi FireFlies!
Do you think these lights will be available to ship in October? Thanks
