Test/review of Shockli 16340 700mAh (Yellow) 2018
33 posts / 0 new
HKJ
HKJ's picture
Last seen: 8 hours 39 min ago
DSC_1300
Official specifications:
  • Nominal voltage: 3.7V
  • Nominal capacity: 700mAh
  • Discharge cut-off: 2.75V
  • Standard charge: 0.3A to 1A 4.2V +/-0.05V
  • Maximum charge current: 1A
  • Maximum discharge current: 3A
  • Initial impedance:
  • Cycle life: 500 cycles to 70%
  • Protection: Over charge, over discharge, over current and short circuit.
Shockli%2016340%20700mAh%20(Yellow)%202018-info
Protected 16340 (CR123) sized batteries with a nice current output.
DSC_1297DSC_1299
DSC_1301DSC_1302
DSC_1303
DSC_1304
DSC_1305
Shockli%2016340%20700mAh%20(Yellow)%202018-Capacity
The curves tracks fairly well. The batteries handles 2A, but 3A is a bit much.
Shockli%2016340%20700mAh%20(Yellow)%202018-Temp-3.0
Shockli%2016340%20700mAh%20(Yellow)%202018-CapacityTimeHours
Shockli%2016340%20700mAh%20(Yellow)%202018-Energy
Shockli%2016340%20700mAh%20(Yellow)%202018-PowerLoadTime
Shockli%2016340%20700mAh%20(Yellow)%202018-TripCurrent
I did not succeed in tripping the over current protection, it will probably trip on a direct short. The over discharge protection is still very useful.
Shockli%2016340%20700mAh%20(Yellow)%202018-Charge
Conclusion
The battery has good capacity and can deliver a fair amount of current, but it not a high current cell.
Notes and links
The batteries was supplied by Shockli.com for review.
Comparison to other LiIon batteries
djozz
djozz's picture
Last seen: 4 hours 55 min ago
Nice cells. Thanks for the test!
I’m still on the lookout for a cell of the performance of the AW 16340 “15C” that you tested two years ago but is long ago discontinued. This one is not it, but do you have 16340 cells in the pipeline that may have that current performance?
HKJ
HKJ's picture
I do not have any 16340 in queue.
Geuzzz
Geuzzz's picture
Last seen: 7 hours 32 min ago
Good high(er) current 16340s are hard to find.
Just ordered these trustfires, not my favourite brand, but tests seem ok.
https://www.fasttech.com/product/1804001-trustfire-imr-16340-3-7v-650mah...
https://lygte-info.dk/review/batteries2012/TrustFire%20IMR16340%20650mAh%20(Red-gold)%20UK.html
djozz
djozz's picture
Yes they look decent but only the AW 15C was able to run at 5A (and thus make 1400 lumen OTF of a pocket EDC, which is completely unneccessary and a lot of fun).
MascaratumB
MascaratumB's picture
Last seen: 2 hours 30 min ago
Are these the ones you’re referring to djozz?
https://www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&S...
I don’t know if the stock is the “real”, but in Alibaba there’s a lot of places with them aparently!
EDIT: “you have dialed the wrong number…” Facepalm I imagined a T after “AW”, as moderator007 stated below… I gotta sleep Facepalm
BTW, HKJ, for the 16340s, I believe you’ll have the Sofirn 900mAh, right?
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
moderator007
moderator007's picture
Last seen: 54 min 35 sec ago
Those are AWT. I think the cells djozz is looking for are these. http://budgetlightforum.com/node/49113
MascaratumB
FacepalmFacepalmFacepalm You’re right, please ignore Ughh
 MY GIVEAWAY (FW3A)
MascaratumB
Funny enough, seeing HKJ tests of both batteries (AW and AWT linked above) measuring them on 3A and 5A, the AWT seems to hang a little better.
Am I wrong on that reading? Oops
 MY GIVEAWAY (FW3A)
moderator007
@djozz, I found these searching around, not much info but appear to be the AW 16340 15C (doesn’t say 15C) and they’re on sale.
https://www.vaporshark.com/vs-aw-battery-16340-550mah
moderator007
Look at the AW IMR16340 15C 550mah (red) 2016
Check it at 5 and 7 amps using the comparator.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 40 min ago
These…https://www.cremedevape.com/B63-10-AW-IMR16340-Battery
KB1428 “Live Life WOT”
MascaratumB
moderator007 wrote:
MascaratumB wrote:
Funny enough, seeing HKJ tests of both batteries (AW and AWT linked above) measuring them on 3A and 5A, the AWT seems to hang a little better. Am I wrong on that reading? Oops
Look at the AW IMR16340 15C 550mah (red) 2016 Check it at 5 and 7 amps using the comparator.
I really need to sleep Facepalm
I was comparing the non PC version!
Thanks for correcting me WinkTired
 MY GIVEAWAY (FW3A)
djozz
djozz's picture
The 15C version is labeled as 15C, and that label makes it different from the ‘normal’ AW 550mAh 16340 cell, no other visual differences. The batteries in the link do not have the lebel, and it is also not mentioned in the description.
djozz
djozz's picture
I have tried to order there, but it did not work for me. I can’t remember what went wrong, it was a few months ago, probably no stock despite the listing.
djozz
djozz's picture
I checked them again and indeed they seem to still have them in stock (for some time already because AW stopped making batteries more than a year ago because of some disaster at their facility), but including everything, to buy two of these batteries costs me 30 euro’s (33 dollar), and I would still be nervous if they do not send me the non-15C version. Thanks for the link though Smile
KawiBoy1428
Your welcome… Thumbs Up
Shockli-Simon
Shockli-Simon's picture
Last seen: 4 days 4 hours ago
Thanks for HKJ’s hard work, I have a question for “Protected 16340 (CR123) sized batteries with a nice current output.”,sorry i do not give you the specifications. the shockli 16340 700mah is unprotected battery.
Geuzzz
Geuzzz's picture
I still have two decent 15C AWs. I’ll see how they compare.
blueb8llz
Last seen: 8 hours 22 min ago
Not sure if hkj ever reviewed imren imr 700, but they are the closest thing to my aw’s.
It’s in a blue wrapper and says 10 amps.
moderator007
Is this the battery you are referring to. https://www.imrbatteries.com/imren-16340-700mah-button-top-battery/
How did you test them for the comparison to the 15C AW.
blueb8llz
Yup those are it. No real test with graphs or anything close. I have several high powered modded lights and I just did a simple lumen ceiling bounce test and the lumens were not too far off. And it was able to sustain the output pretty well also.
djozz
djozz's picture
Those Imren batteries look pretty good, and are even 700mAh.
..but not to be found outside the States Sad
moderator007
I ordered two button top Imren 700’s to try. I purchased them off ebay for 10 bucks shipped. I’ll try them out once they arrive.
Link for you djozz. http://shade-e-vaping.co.uk/index.php?route=product/product&product_id=712
blueb8llz
Hopefully u get authentic ones. How come you didn’t buy from Imr. I believe that’s where I purchased mine. Imr sells authentic cells.
moderator007
https://www.ebay.com/itm/2-pc-IMREN-IMR-16340-10a-BATTERY-CR123A-3-7v-Li...?
They been around since 1999 have over a quarter million sales with almost a perfect feedback and lots of good reviews, I’m guessing authentic and cheaper than Imrbatteries. If they test good, I may buy more but the shipping price doesn’t change or penalize you for only buying 2 cells to test.
If they are not authentic, I get my money back. Says they are authentic in the description.
moderator007
I tested the IMR 16340 Imren at a 3 amp load. I got 340 mah at 7 minutes before tripping the 3v cut off. It’s about average with the other top name brand 16340 cell’s. The IMR 16340 Trustfire (red-gold) is still the best 16340 cell I have tested at a 3 amp load. It did a little over 500 mah at 10 1/2 minutes at a 3 amp load.
ChrisGarrett
ChrisGarrett's picture
Last seen: 1 day 7 hours ago
I just ordered 6 of the TF red/gold 16340s from FastTech and people just need to remember that on some of the older (and perhaps newer?) lipstick lights, with reverse polarity protection, the flat tops aren’t going to work.
I always tell people that most good cells will test out well in the beginning, but the real issue is how many months do you get out of them before they’re trash?
I won’t buy Kinoko, even if they’re still in business and I won’t buy Soshine any longer, because they didn’t last long for me.
Chris
Shockli-Simon
Hi moderator007
the shockli 16340 600mah would meet your requirements. the capacity is over 500mah at 3 AMP load.
The shockli 16340 600mah have better performance than shockli 16340 700mah at high discharge current.
you can check the HKJ TEST REVIEW http://budgetlightforum.com/node/43659
mtnelectronics.com will stock the shockli 16340 600mah, the weblink is http://www.mtnelectronics.com/index.php?route=product/product&path=59_87...
moderator007
The link and HKJ’s graph both are showing the Windyfire IMR16340 600mah which looks to be a very good cell for high current drain in a 16340 battery format.
Are you stating that Shockli is Windyfire or that Shockli is using the same cell. Its not very clear what you are stating the way it stands.
I also noticed that Mtn.electronics test review link also brings you to HKJ’s Windyfire test.
Shockli-Simon
moderator007 wrote:
The link and HKJ’s graph both are showing the Windyfire IMR16340 600mah which looks to be a very good cell for high current drain in a 16340 battery format. Are you stating that Shockli is Windyfire or that Shockli is using the same cell. Its not very clear what you are stating the way it stands. I also noticed that Mtn.electronics test review link also brings you to HKJ’s Windyfire test.
Hi moderator007
The shockli 16340 600mah and the windyfire 16340 600mah are the same cells.
the capacity is over 500mah at 3A discharge current.
I don’t know if Richard himself has used shockli 16340 600mah, i also want to know how the shockli 16340 600mah performance for the flashlight.
Has anyone budgetlightforum mumber ever used shockli 16340 600mah, would you share some information.
