FOLOMOV magnetic keychain charger test
14 posts / 0 new
steel_1024
steel_1024's picture
Last seen: 9 hours 42 min ago
FOLOMOV’s new portable charger
Design concept is very good, easy to carry around
You can understand everything by looking at the picture!
Transparent plastic box packaging
back
side
The other side
Original battery
Positive
Back
Can be carried on the keychain
Open the wiring, pay attention to the positive pole on the body
Connect 2A load first, test USB power plug, can provide 5V 2A
The new battery starts charging and the charging current is as high as 1.66A
Automatically control the charging current to 0.74A
Charging is nearing completion, down to 0.37A
finished charging
The charge completion cutoff voltage is 4.22V
Blinking
Charging status light indication
iPhone charging
Detect battery remaining capacity
21700 lithium battery is also suitable
Too lazy to type
Directly charge the battery
Thanks for watching
Sorry for my poor english.
Edited by: steel_1024 on 09/13/2018 - 08:43
fluke
Last seen: 6 hours 42 min ago
Thanks for the review.
Where can I get one of those load testers with multiple usb connecotrs?
steel_1024
Here:
https://www.aliexpress.com/item/WEB-U2-Current-Voltmeter-USB-Tester-QC4-...
and……
https://www.banggood.com/WEB-U2-Current-And-Voltage-Meter-USB-Tester-QC4...
d_t_a
Last seen: 2 days 10 hours ago
HKJ has reviewed several of those.
I think RD Tech’s HD35 would be a good start.
There’s also the DTU-CC01.
And YZXStudio’s ZL1100 (which I consider as one of the more advanced load testers). And then there is also the EBD-USB+ for graphing/saving with a PC..
fluke
Thanks.
And where did you get the switchable load?
Not seen one with that many inputs that has fixed resistance.
Pete7874
Pete7874's picture
Last seen: 1 hour 52 min ago
Quote:
I’m only seeing 4 LEDs on this charger, so how can you have 1 blinking LED and 4 solid LEDs (5 total)?
Looks like an interesting charger though.
4.22V after removing from the charger seems a bit on the high side, no?
steel_1024
fluke wrote:
Thanks.
I ordered from the same store on Taobao.(China)
They also have an adjustable 25W load
steel_1024
1. Should be a bug. Big Smile
2. I think the voltage is a bit high also.
steel_1024
Edit:
YZXStudio is a true professional design and a better choice.
d_t_a
steel_1024 wrote:
YZX is usually a follower of WEB
(probably off-topic for this thread…)
Is there a ZL1100-equivalent load tester from WEB? Can you point me to a product link or review link? Thanks.
steel_1024
I spent some time searching for information.
I found YZXStudio to be a truly professional design.
Although it is a bit expensive, it is in a leading position.
Folomov official
Folomov official's picture
Last seen: 4 days 20 hours ago
Thank you for the review. Folomov KEY Charger is available on Amazon now.
Folomov -- specialized in quality and innovative LED flashlights, battery chargers and batteries for outdoor sports and everyday carry.
www.folomov.com info@luminltd.com
New products:
KEY Charger -- Max 2A 18650 key chain charger. With power bank function and automatic power detection.
USB-1834 -- Micro USB charge and discharge 18650 battery. Definitely a pocket power bank.
18650S -- The shortest multi-function 18650 tactical flashlight.
travis
Last seen: 1 hour 32 min ago
Seems huge for keychain.
I’d rather just have the Folomov A1 magnetic charger in my pocket.
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
Pete7874
Pete7874's picture
The one that HKJ reviewed was under-charging. Has Folomov fixed that issue yet? Not a big problem, I suppose.
