Isopropyl Alcohol USP 70%..... ok to clean battery terminals?
18 posts / 0 new
klrman
klrman's picture
Last seen: 1 day 19 hours ago
I have a bottle of Isopropyl Alcohol USP 70% in my house.  I did use it to clean some battery terminals the other day and the IR readings when in my charger went back to normal which is good, but, does it melt the wrappers or any other cautions using this type of alcohol?
robo819
robo819's picture
Last seen: 2 hours 33 min ago
I have been using 90% for a long time cleaning cell ends and different parts of flashlights with no negative effects that I have noted.
I wouldn’t think the 70% would cause any negative effects either , unless it might cause some surface rust possibly on untreated or bare metal since the 70% does contain more water than the 90% does. (30% for the 70 vs 10% for the 90)
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Newlumen
Newlumen's picture
Last seen: 1 hour 52 min ago
I do it all the time. I even use it on the threads..
klrman
klrman's picture
Well, that does it then, I will keep using it and next time get 90% for less water content!
robo819
robo819's picture
The 90% also has worked well for rinsing my chemically dedomed emitters over time as well as a quick rinse for the hot dedomed and sliced ones. I use it for cleaning reflectors and lenses a lot and it works well for that , where the 70% many times would leave tiny spots , much like using distilled water. Also cleans most surfaces well for soldering.
EDIT: when using to rinse reflectors or lenses , I use a light spray of air to blow away the droplets. Even then the 70% many times would still leave tiny spots where the 90% usually does not.
klrman
klrman's picture
Going to look for that 90% tomorrow and keep it in my flashlight cabinet.  Never thought of trying alcohol for cleaning the lenses and reflectors. Might give that a try    soon too.  I still have a fair size bottle of Monster Screen Clean that I use for my monitors and that is what I have been using so far to clean all my flashlight lenses since that bottle never seems to run out.  Had it for several  years now.
LichtAn
Last seen: 1 month 1 day ago
BTW 99.9% is also very easy to get. (at least in germany)
Car detailing companies also often have these in 1l bottles for degreasing.
Enderman
Enderman's picture
Last seen: 2 hours 39 min ago
I only use 99.99999% or better.
klrman
klrman's picture
Where do you find that stuff in BC
LichtAn
Is this attempted mockery? Big Smile I think there’s no 100% rating, it’s always 99.9% minimum rated.
Tumbleweed48
Last seen: 1 hour 14 min ago
99% isopropyl alcohol is about the best cleaner/degreaser you can find – and if you have soap scum in your sink or on faucets, it wipes that stuff away like magic. Any residue evaporates in seconds.
I use 70% for after shave as my wife doesn’t like strong fragrances (and many health care services here ban fragrances in hospitals and clinics). Most after shave lotions are just 70% isopropyl to begin with, with a shot of ‘stinkum’ added.
LumenHound
LumenHound's picture
Last seen: 2 days 16 hours ago
Shoppers Drug Mart.
Look for Isopropanol.
klrman
klrman's picture
LumenHound wrote:
Shoppers Drug Mart. Look for Isopropanol.
I was just responding to Enderman kidding about the 99.99999% purity!
Lightbringer
Lightbringer's picture
Last seen: 2 hours 6 min ago
Ummm, IPA is an azeotrope at something like 87%-88% or so, so anything “purer” will just absorb water from the air as soon as the bottle’s opened.
90% is about as good as you’ll get… and be able to keep.
klrman
klrman's picture
Just picked up 99% at walmart this morning or as you say, "87%-88%" once I open the cap
Lightbringer
It’s extremely difficult to get CP isopropanol, because unless it’s kept pretty much in a vacuum and sealed, any water vapor will be sucked right up. Not immediately, of course, but over time.
Same reason you should pretty much never get brake fluid and/ot steering fluid in more than you immediately require, because they’re hygroscopic and will suck water right out of the air when exposed, and that little bit can rust the lines from the inside.
So whenever I need IPA, I’ll spring for the 90%, but rarely (read, never) anything “purer”. Certainly not in an unlined plastic bottle.
klrman
klrman's picture
Good info there thanks Lightbringer
pennzy
pennzy's picture
Last seen: 1 hour 22 min ago
Bottomless pit of knowledge. Thumbs Up
