I just finished up modding my D1S with a Oslon black flat , all i did was reflow the LED on to the xp board that came in the light. I put the MCPCB back into the light, shaved down the centering ring to fit the new LED and viola it worked!, it now produces 345kcd and ~707 lumens comapred to the 140kcd and 1200 lumens. LAZER BEAM TIME
Some Pictures, a video will be up soon @ https://www.youtube.com/channel/UCcWcPSMe1ohtcYf3BHsaldA?
Compared to a D1S XPL-HI
Current collection Olight -S1R turbo S -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite -TN42 ThorFire -S70S -TG06S -TK05 Manker -Mk35 Noctigon -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S Rofis -TR31 Lumintop - BLF GT -GT Mini -IYP365 -Tool AA 2.0
Product Reviews
Chargers:
Opus BT-C3100, MiBoxer C4-12, MiBoxer C8, Folomov A1
Flashlights:
BLF GT, TN42, TG06S, Emisar D4, GT Mini, S70S, TM36, EDC-C4, BLF Q8
Custom Builds
XPL-HI C8, Aspheric XHP-70, OSLON D1S
Nice. Is that the D1S with XPL HI in the comparison shots?
Yes it is! Just updated the thread to say the comparison light
Product Reviews
Chargers:
Flashlights:
Custom Builds
That’s a nice tight beam right there
The OPTOFIRE - 4.63Mcd aspheric LED flashlight The SYNIOSBEAM - 10Mcd recoil LED flashlight List of the farthest throwing flashlights
I always thought those were very expensive but I guess not, quite a surprise at under $5..
That is just awesome, you should be able to light up some satellites going by with that D1S..
I thought the Oslon black flat were weird to feed, like with a P-Fet or something
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
wait, isn’t Stock MCPCB is DTP
did you also change the driver?
Forgot my pen
“shaved down the centering ring to fit the new LED”
What do you mean by shave down? Because the LED is sitting lower than the XP-L HI?
The data sheet Vf is 2.75(min) 3.05V(typ) 3.75V(max) at 1amp. Rated forward current is 50-1500mA. Maximum rated pulse current is 2.5A.
He’s talking about the thermal pad not being electrically insulated.
Ahh. I’m still learning.
From the data sheet:
So, any explanation ?
Is it as simple as a reflow on the stock Noctigon and voilà ?
My best guess:
A lot of non-conductive thermal paste was used and the DTP-MCPCB is just isolated from the driver by sheer luck.
Otherwise you would need an isolated MCPCB as those from led4power which use a special aluminium oxide layer to have near DTP-performance on isolated MCPCBs
Yeah I was thinking the same… Heat path is not ideal in that case
This might be 100% wrong. But I vaguely remember someone saying that the Emisar boards have a P-FET?
Very cool build mikelights. Congrats
This might be the same emitter at Arrow for lower cost and free overnight shipping:
https://www.arrow.com/en/products/luwhwqp-8m7n-ebvf46fcbb46-1/osram-opto-semiconductors
EDIT: I just read here that there are what sounds like higher binned ones at mouser and digikey, but I can't seem to find them. I can't seem to match up the manufacture's part number to the datasheet. The listed specs appear to indicated the highest light output, but also highest Vf. They are only showing max's though. So not sure about that.
EDIT2: Please disregard the struck out text. Member Nicolicous alerted in Post 31 below that this is a 5-pin package that may not be compatible with XP based.
Cool.
- LEDs & Other Stuff - - UI CheatSheets - - Mods & Builds -
Have you voted yet?
The Emisar lights don’t have a p-fet driver .
The explanation : the driver’s ground , isn’t connected (electrically) to the head , but only the tube is , that carries the Battery (-) .
That allows the head to be connected with Led (-) without causing issues on the driver .
- George
My Reviews : KDlight C8 / ThruNite Archer 1A V3 / Thorfire C8s / ThruNite TN12 (2016) / Utorch UT01 / Utorch UT02 / Jetbeam WL-S2 (xp-l) / ThruNite TC12 V2 / Massdrop Brass AAA / Manker LAD / Lumintop SD26 / ThruNite Mini TN30 (3x xm-l2) / Qualilite D81 / Nitecore MH20GT / Odepro TM30 / Klarus XT30R / Nitecore NU20 CRI / Ultrafire XM-L2 / Foursevens Mini MK II / Manker E02 / Manker E14 II / Teekland Flashlights / Lumintop Elfin / Thorfire S70S / ThruNite Neutron 2C / Jaxman M8 / KDLITKER C8.2 / Zanflare F1 / Nitecore Concept 1 / Emisar D4 / Astrolux MF-01 / ThruNite TC10 V3 / Amutorch JM70 (xpl hi)
Annnnnd thank you very much for that clear explanation, I couldn’t for the life of me figure how it was possible.
You couldn’t do that in, say, a C8…
Now I have to order some black flat
True about the head being isolated from battery negative. I didn’t think of that. But I wouldn’t necessarily rely on this method of isolation because if the anodization of the tube threads wears off it’s no longer isolated.
A method to isolate the MCPCB from the shelf that’s worked well for me when I was experimenting with making XD16 arrays is using narrow strips of kapton as spacers under the MCPCB. A couple small strips (~2mm x 15mm) near opposite edges of the MCPCB prevent any metal to metal contact. Put the strips on the MCPCB and use ceramic thermal paste as usual. The kapton thickness is only 50microns so it’s practically not adding any thickness to the thermal paste junction.
This is a rare occasion , since most people change battery from the tailcap side . Someone could add some (veeery little) medium strength threadlocker to be sure they won’t change battery from this side , and so it won’t wear off .
- George
Yes but since the head isnt electrically connected to the driver I didnt need to change anything except reflow the LED.
Product Reviews
Chargers:
Flashlights:
Custom Builds
I had to sand down the little centering ring for the led to get optimum focus and shave it out a bit to make the hole bigger so the black flat would fit, the black flat is a bit wider than the XP-L HI
Product Reviews
Chargers:
Flashlights:
Custom Builds
simply put yes it is, I was expecting to have to isolate the MCPCB but I didn’t have to because of the isolation between the head and driver which made the build process a lot easier and quicker
Product Reviews
Chargers:
Flashlights:
Custom Builds
Thanks! and thanks for the info I will check out that site you linked
Product Reviews
Chargers:
Flashlights:
Custom Builds
precisely
Product Reviews
Chargers:
Flashlights:
Custom Builds
originally I was going to use thermal epoxy on the bottom of the driver to isolate it but I didn’t need to because of the driver isolation, but my solution is not to unscrew the body from the head just use the tail cap which keeps the threads from ever getting worn down.
Product Reviews
Chargers:
Flashlights:
Custom Builds
I made mine too some days ago , now I’m messing with the focus to get the optimal result
- George
Awesome! let me know the max cd you get out of yours I am curious how they compare
Product Reviews
Chargers:
Flashlights:
Custom Builds
Thanks haha, it turned out awesome
Product Reviews
Chargers:
Flashlights:
Custom Builds
That link is for “Automotive 5-Pin SMD T/R”….I don’t think it can reflow to your xpl mcbpc.
Arrow do have 2 -pin but not in stock. I got their email reply of 10 pieces for $21…. Seems good deal
Think I’ll pull the trigger soon
Nico -.-
