Emisar D1S Oslon Black flat mod 340k+cd
103 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 36 min ago
That isolated head so you can use the Black Flat is already reason enough to buy a D1S. Great mod with awesome throw for such a small flashlight!
mikelights
mikelights's picture
Last seen: 12 hours 20 min ago
So true! Thanks and I’m glad you liked it
Current collection
Olight -S1R -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42 -TN40 ThorFire -S70S -TG06S -TK05 Manker -Mk34 Noctigon Emisar -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S -Emisar D18 -Emisar D4S Rofis -TR31 Lumintop -BLF GT -GT Mini -IYP365 -Tool AA 2.0 -FW3C Acebeam -X80GTvn -W30 Imalent -R90C -MS18 FireFlies -E07 Brass Reylight -Pineapple
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8W30
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
Redlyne22
Redlyne22's picture
Last seen: 12 hours 47 min ago
Nice find!!!!! This is great!!!…so the D1s and flat black are secretly the perfect match. I love how little spill the corona has now.
I’m still alil confused on how the head is electrically isolated. Is it simply the thick anodising emisar uses? Because I dont recall ever seeing a grommet or spacer in-between the head and body?
Sometimes being a newb is the best part of a hobbie
mikelights
Definitely a match made in heaven, the thick anodization insulates the driver from the head because it’s simply push fit into the light so therefore the negative outer ring on the driver only makes contact with the body and it’s electrically isolated from the aluminum in the head, as we were saying before if you take apart the D1S from the top of the tube near the head the threads will wear off the anodizing from friction and will soon ground out to the head and ruin the connection once it wears off but you can take care of that by only unscrewing from the bottom of the tube.
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
ImA4Wheelr
Nicolicous wrote:
ImA4Wheelr wrote:
Very cool build mikelights.  Congrats
This might be the same emitter at Arrow for lower cost and free overnight shipping:
https://www.arrow.com/en/products/luwhwqp-8m7n-ebvf46fcbb46-1/osram-opto-semiconductors
EDIT:  I just read here that there are what sounds like higher binned ones at mouser and digikey, but I can't seem to find them.  I can't seem to match up the manufacture's part number to the datasheet.  The listed specs appear to indicated the highest light output, but also highest Vf.  They are only showing max's though.  So not sure about that.
That link is for "Automotive 5-Pin SMD T/R"....I don't think it can reflow to your xpl mcbpc. Arrow do have 2 -pin but not in stock. I got their email reply of 10 pieces for $21.... Seems good deal Think I'll pull the trigger soon :-)
Oh. Thank you Nicolicous.  I scanned a datasheet, but didn't catch anything about that package.  I'll add a note to my above post.
Agro
Agro's picture
Last seen: 2 min 55 sec ago
I wonder if D1 would work just as well… Smile
LichtAn
Last seen: 7 months 2 weeks ago
Nicolicous wrote:
That link is for “Automotive 5-Pin SMD T/R”….I don’t think it can reflow to your xpl mcbpc.
Arrow do have 2 -pin but not in stock. I got their email reply of 10 pieces for $21…. Seems good deal
Think I’ll pull the trigger soon Smile
Oh wow just 3 or 4 days ago nearly 1000 pieces were in stock.
bilakos10
bilakos10's picture
Last seen: 4 days 1 hour ago
Pop your multimeter in continuity mode and give it a try!
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
ImA4Wheelr
It appears the 5-pin variant (if it is actually a variant.  The datasheet doesn't show any other footprint) will work with XP boards.
Now to hope they are of a decent bin.  Will try to attempt to measure that tonight.  Never have tried to before.
mikelights
That’s what I was thinking of doing next we will see how it goes
Current collection
Product Reviews
Chargers:
Flashlights:
Custom Builds
Nicolicous
Nicolicous's picture
Last seen: 4 min 16 sec ago
Thanks ImA4Wheelr
I noticed both footprints are the same.
I will buy 3 to testout Smile
Nico -.-
ImA4Wheelr
You may want to hold off on that order.  I'm getting lousy measurements.  Higher Vf's and lower calculated lumens then both djozz and koef3 reported.  Please keep in mind that my lumen calculation could be way off as I haven't really spent much time working on my integrating tube and have never measured a bare emitter.  I hobbled a set up just a bit ago.  So there is all kinds of potential for errors.  Conversion factor derived from maukka calibration lights.
 Current Vf Lux Lumens
1
3.14
364 245
2 3.49 617 415
3 3.78
814
547
4 4.04 955 642
5 4.31 1040 699
 EDIT:  Improved the setup up.  I was losing lumens around the heatsink.  I resolved that a good bit, but am still losing some lumens.  My new measurements are as follows:
1
3.14
445 305
2 3.49 763 523
3 3.78
1009
692
4 4.04 1186 813
5 4.31 1290 885
The_Driver
The_Driver's picture
Last seen: 23 sec ago
That Vf seems way too high for this LED at max brightness.
ImA4Wheelr
I definitely was a bit disappointed in the Vf results.  The reading seems reasonable according to the bins listed in the datasheet.  Used a DPS5015 to provide power and to measure Vf.  Used about one foot of 18 gauge leads.  Didn't see signs of thermal sag.
I will remeasure tonight with a meter directly on the emitter.
The_Driver
That explains it partly. Your meter will probably measure lower values.
ImA4Wheelr
You weren't kidding.  I was expecting a small difference, but was surprised.  I verified power supply readings at the power supply terminals, no problem.  Then measured at the emitter pads.  I read 3.02, 3.23, 3.42, 3.60 , and 3.80 volts at 1 through 5 amps, respectively.  Good news from an emitter efficiency standpoint.  Thank you for sharing your observation The_Driver.
The_Driver
Those values are realistic. The LED is probably brightest at 4-4.7A.?
Niko
Last seen: 5 hours 9 sec ago
Thats great! who can make a distance ring for black flat?
ZozzV6
ZozzV6's picture
Last seen: 5 days 1 hour ago
The GT mini also has same body setup like D1S. 5 black flats ordered last week and I will put one in aa GT mini, one in a Convoy L2 on led4power MCPCB. And maybe one in a modded Convoy S8 to see what throw I can get from a small tube light.
giorgoskok
giorgoskok's picture
Last seen: 2 days 21 hours ago
On C8 you can get up to 300kcd with 1000% perfect focus and a “good” Black Flat .
ZozzV6
ZozzV6's picture
You misread it. S8 not C8 Wink
Small tube light like S2+. Basically it already has an S2+ smooth reflector and a dedomed XP-G2 now with 3,15A 9×7135 driver and AR coated lens. It makes 22500 cd in that config.
giorgoskok
Oops , sorry Zozz Smile
ZozzV6
ZozzV6's picture
No problem. It is not a small tube light what came in people’s mind first when talking about black flat mod Smile
ImA4Wheelr
The HaikeLite MT07S - HI seems like a good candidate for this emitter for any that don't want to electrically insulate under the emitter base.  Looks like you would just need to use plastic screws to keep the driver from grounding to the host.  Maybe a piece of kapton tape under the 2 driver screw a points for extra measure.
Pluses:
  • Smooth reflector.
  • The light would already have a large XP emitter base.
  • I'm assuming a buck driver?  Just sense resister to 4 or so amps.  Should have good run times
EDIT: Fixed some typos & added content
Nicolicous
So I reflowed it perfectly on the board and it work nicely.
Wanting to use FET driver but is it too much current for this led?
Other review state the max it can handle is 5.4A
Nico -.-
The_Driver
At 5.4 it will not be at maximum brightness and be a bit blue tinted. 4A – 4.5A is optimal.
Enderman
Enderman's picture
Last seen: 1 hour 18 min ago
Yeah for a regular flashlight host you want to stick to between 4-5A
5+ is possible if you have good active cooling.
HONDARIDER
HONDARIDER's picture
The 2 pin version is in stock at ARROW for $2.93 each. Just ordered 5 to play with.
SKV89
Last seen: 2 hours 46 min ago
How do you limit the amps to the black flat on the D1S? Do you just use a low current battery or do you have to replace the driver?
BlueSwordM
BlueSwordM's picture
Last seen: 10 hours 38 min ago
Low current battery like an NCR18650B, replacing the driver, or perhaps, just remove the high current BeCu springs and replace them with steel ones.
