First - I'm posting this in the mod forum because I cannot recommend this flashlight unless you plan to modify it. It has pitifully low output - think old incan mag.
On Black Friday, Tractor Supply offered this flashlight for $9.99. I didn't make it to the store to buy one. They hardly sold any at the store I go to, and have at least 20 left. I figured they'd mark them down, so I kept checking, and they have. I only bought one because I think they'll discount them further - let's hope even cheaper than on BF.
For anyone interested, there's a similar light that's 2C but not zoomable - it was originally $10 and will end up on clearance, too (probably is already, I forgot to check, not interested myself, don't like C cells).
I'll let the pictures tell the story - sorry to those who don't like linked pictures.
https://www.facebook.com/media/set/?set=a.10150510553696798.423382.581641797&type=1&l=9311313ad5
A few things you can't see in the pics:
-no packaging, just bare lights in a display box w/ holes to hold each one, (iow, some are scratched, have dead batteries, etc)
-lots of dust/lint/crap inside the head, even though you can't see much in the pic
-no grease or thermal compound - maybe a half a drop of oil on zoom oring
-side switch gets hung up occasionally (an extra press and it frees up). took it apart, can't see why.
-current at tail - .84A, .17A, .55A strobe
-lens is plastic, but not bad
-3 x 32650s should fit, see depth of tailcap pic
- 0.8" between top of switch assembly and end of body (ie plenty of room for thick custom pill)
-C ring that retains plate/switch assembly is the crappiest part I've ever seen in any light. If you can get it out w/o breaking it you should be a surgeon. The only reason to bother trying is to measure it, because even if you did, I can't imagine getting it back in.
-it won't quite reach full focus. DX 50mm lens has longer focal length than stock lens and the whole lip would have to be removed for it to fit in the bezel. I have a 44mm on order.
I'm off to home depot - I'm going to open up the bottom of the pill to where I can pound a 3/4" copper pipe plug into the bottom of it. This should allow me to move the emitter back far enough to get it focused. Then I'm going to hook up the original emitter direct drive to see how fast I can fry that POS
