Test/review of DMM Aneng AN302
1 post / 0 new
HKJ
HKJ's picture
Last seen: 53 min 52 sec ago
DMM Aneng AN302
DSC_0717
The brand Aneng has a lot of cheap multimeters, most of them fairly good. This meter is a pocket meter, except that is missing a compact pouch for pocket use.
DSC_0634
I got the meter in the usual black plastic bag with some protective wrapping around the pouch.
DSC_0770
The pouch with the meter in it, it will fit in a large pocket.
DSC_0714
I got the following pieces: the DMM, a pouch, a lanyard and a instruction sheet.
DSC_0722
The probes a small and without tip cover, that means CAT II. They are marked 250V and the meter is marked 600V, this do not really match up with non-replaceable probes.
DSC_0735 DSC_0721
The meter do not have a range switch, only buttons, this means it will never slide around when selecting range.
DSC_0731
But the buttons can get stuck, I also had the FUNC switch non-working a couple of times, but could get it working again without opening the meter.
DSC_0718DSC_0720
DSC_0719
DSC_0724
Replacement of battery requires removal of small 3 self tappers, it will probably limit the number of times it is possible to replace the battery.
DSC_0730
The meter do not have background light, instead it is a flashlight.
Display
DSC_0727
The above picture shows all the segments on the display, most are used by this meter.
DSC_0728
Typical display during usage, it will show the number and what measurement is selected.
DSC_0729
The NCV is the usual bars, the buzzer and the flashlight.
Functions
DSC_0734
Buttons:
  • Hold: Freezes the display, hold down to turn flashlight on/off.
  • Range: Will disable auto range and change range, hold down to activate auto range.
  • Rel: Shows values relative to current value, will also select manual range. Press again to disable.
  • Select (Yellow): Select ranges, see below.
  • Func (Blue): Select between the two modes, there is no indication on what mode is selected, this must be inferred based on selected range.
Mode 1: VDC, VAC, Frequency, NCV
Mode 2: mVDC, mVAC, ohm, continuity, diode, capacity, frequency
The text on the meter is missing frequency in mode 1.
Input
DSC_0723
This meter only have a red and black probe coming out, no other connections.
Measurements
  • Volt and frequency
    • At 100mVrms input frequency range is from 1Hz to 5.6MHz in mV mode.
    • At 1Vrms input frequency range can be stretched to 6.2MHz in mV mode.
    • At 1Vrms input frequency range is from 1Hz to 30kHz (Above that the display gets unstable) in V mode.
    • At 5Vrms input frequency range can be stretched to 80kHz in V mode.
    • 1 VAC is 5% down at 2.1kHz (RMS will not work at the frequency).
    • Frequency input requires a zero crossing in both mV and V mode.
    • Input impedance is 10..11Mohm on DC and AC
    • mVDC range is high impedance for DC up to around 1.5 volt where it drops to 2kOhm. AC is similar, but capped at 10Mohm
    • mV frequency input is 10Mohm up to around 1.5 volt, then the protection clamps to 2kOhm
    • V frequency input is 10..11Mohm.
  • Current
    • Meter cannot measure current
  • Ohm, Continuity, diode and capacity
    • Ohm needs about 2.8s to measure 100ohm
    • Ohm is 1V open and 0.4mA shorted
    • Continuity is quick (About 30ms, but mostly 5ms).
    • Continuity beeps when resistance is below 50ohm.
    • Continuity is 1V open and 0.4mA shorted
    • Diode range uses 3.2V, max. display is 3.000V at 0.13mA, max. current is 1.8mA shorted
    • 10uF takes about 4.5 seconds to measure.
    • 70000uF takes about 12 seconds to measure.
    • Overload protection is not rated
  • Miscellaneous
    • Current consumption of meter is 1.5 to 1.9mA depending on range with flashlight it is up to 15mA.
    • Meter works down to 2.2V where it turns off, battery symbol shows at 2.4V.
    • Reading do not change with battery voltage.
    • Flashlight only works down to about 2.6V where it is fairly dim.
    • The meter usual need a couple of display update to reach the final value.
    • Viewing angle is good.
    • Display updates around 3 times/sec
    • Flashlight will not turn off automatic, but will turn off when meter automatic turns off.
    • Will automatic turn power off in about 15 minutes.
    • Weight is 74g without accessories, but battery.
    • Size is 119 × 63 × 13mm width includes bent strain relief for probes.
  • Probes
    • Probe wire is soft, fairly thin and 70cm long.
1uF
A look at the capacity measurement waveform for 1uF.
DMMInputVoltageSweepHz
Input resistance in mV frequency mode depends on input voltage.
DMMInputVoltageSweepmVDC
Input resistance in mV DC mode, in AC there is a 10Mohm in parallel.
DMMschema
AC input cannot handle large DC offset.
NCV is way to sensitive, just about any wire will trigger it, it do not need to carry voltage.
Tear down
DSC_0724
3 screws and the back could be removed.
DSC_0725
The inside looks very simple, but I am not impressed with the battery holder
DSC_0726
The lid has one connection for the battery holder, the buzzer that is heat staked to it and a lens for the flashlight.
DSC_0752
The circuit board is mounted with four clips, but the did not hold it fairly well and it was very easy to take out.
DSC_0753
The top has one connection for the battery holder, the rubber for the buttons and the LCD display. The rubber looks a bit messy, I wonder if the separate blue button is due to a repair or if it is made this way (In a teardown I saw all the buttons was one piece, i.e. it must be a repair).
DSC_0761
DSC_0754
The input is always connected to the high ohmic input resistors (R22 & R28: 2×5Mohm), when ohm/mV/etc. mode is selected with SW1 the iput is also routed to the PTC (PTC1: 1.5kOhm) and a low ohmic input (R21: 900kOhm). The PTC has a transistor pair (Q4 & Q5) to handle over voltage.
The NCV has 3 resistors (R18, R29, R30: 3×20Mohm) to tie it to ground.
The main multimeter chip is behind the black blob and next to it is a EEPROM (U1: P24C02A) with calibration and mode setup.
DSC_0757
DSC_0758 DSC_0759
DSC_0760
DSC_0755
The two switches are soldered on this side, this will make them a bit sensitive to high pressure. The flashlight led is here and two springs for connection to the buzzer.
The switch will connect the centre pin to either top or bottom pin, separate for the two sides.
DSC_0756
Conclusion
As usual I do not believe the CAT rating, probes is marked 250V, meter is marked 600V and the input voltage goes to a small SMD resistor.
The meter has nearly all the function of larger meters, it is only missing current, this makes it a very universal pocket meter.
The mechanical quality for this meter is on the low side, very short self tapping screws when replacing battery and clips that are not very good at holding the circuit board. I do also miss a better “pouch” for pocket use.
Notes
How do I review a DMM
More DMM reviews
