Looking For AA Beacon Mode and diffuser
Hello I am looking for an single AAA with beacon mode, with diffuser.
When I say beacon I would it to be the same as the Nitecore beacon mode.
And a screw on diffuser Liteflux used to do an LF2 many years ago but I lost it.
It’s not clear if you want AA or AAA, there is a difference between the thread title and your text. AA is easy, http://www.zebralight.com/SC5c-Mk-II-AA-Flashlight-Neutral-White-High-CRI_p_192.html. There is direct access to beacon with a triple click from off, with a flash every 5 seconds
AAA, https://www.amazon.com/Manker-Flashlight-Keychain-Reversible-Magnet/dp/B071W211VQ. No direct access to beacon, you have to go through turbo, strobe, and SOS to get to beacon, which is one flash a second on high.
I have both and they are both good lights. There must be other choices for both AA and AAA.
Had a Lumintop EDC05 that I think had a fairly easy to get to beacon. I got nothing for the screw on diffuser. I’m sure someone will have a good suggestion though.
