Osram Oslon Boost HX
204 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 11 min ago
That is settled then Smile
Now for the leds and we’re in business Love
nofearek9
nofearek9's picture
Last seen: 3 days 23 hours ago
waiting for the test Smile
Enderman
Enderman's picture
Last seen: 7 hours 12 min ago
led4power wrote:
I will try to contact my few distributors regarding this led, and maybe start a group buy, since I already have DTP boards
You’re amazing, thanks so much Smile
ZozzV6
ZozzV6's picture
Last seen: 3 hours 2 min ago
Yaaaay! Thumbs Up
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 26 min ago
Yes Led4Power… Go for it…
This will be ultra thrower for sure and I really really know that. No need for any special testing I guarantee that to whole forum Wink Thumbs Up
Jerommel
Jerommel's picture
Last seen: 1 week 1 day ago
BUMP this topic to create more demand, which will help getting these (well, hopefully).
Jerommel
Jerommel's picture
Thinking about this emitter, i have several lights waiting for this kind of LED, some of them for years already…
But i guess it is just a matter of time. Smile
But we were all a bit worried about the flip chip trend, i guess.
Hope to see some warmer tints soon too.
I want green one Beer
Jerommel
Jerommel's picture
Maybe wait what Cree will come up with? Big Smile
Agro
Agro's picture
Last seen: 1 hour 11 min ago
You mean like XHP35.2? Facepalm
JaredM
JaredM's picture
Last seen: 1 hour 48 min ago
It’s sad to say, but I don’t have any new build plans for a Cree emitter (s). The last was a triple 50.2 and before that a quad 70.2. Just toys and shelf queens. IMHO, ~80cri NW HI emitters from them are the only things I might buy more of anytime soon for gift lights.
The present and near-future of my interests are practical builds. For me, that’s hiCRI arrays running sustainable currents in mule headlamps or Carlo tube lights and pocket throwers utilizing Black Flats. If these turn out as expected and help resolve the pencil beam issue of the BFs then paint me happy! Hoping to see these soon!
Lothar
Lothar's picture
Last seen: 1 day 3 hours ago
To quote Driver:
The_Driver wrote:
The waiting for this is gonna kill me cry.
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
The_Driver
The_Driver's picture
Last seen: 2 hours 3 min ago
I just found something:
Application Note No. AN131:
Osram Application hints for high-current LEDs valid for OSLON Boost HX (KW CULPM1.TG)
It shows the internal structure of the LED and that one (obviously) shouldn't use non-dtp pcbs.
Also, I found some precise values regarding the luminance (these are stated in the product filter/selector):
At 6A and 1670 lumen the LED gives off 553cd which means the luminance is 278cd/mm(just divide by the die size - 1,9875mm2). 1670lm is at the center of the possible brightness range of the possible bins when the LED is being driven at 6A.
The luminance based on the lumens: 0,167cd/mm2 per lumen (scales linearily, just multiply with any lumens value to get the luminance at that specific brightness)
djozz
djozz's picture
I’m not really good in this. Does this imply that the Boost HX has 2.7 times the luminance of even the KW CSLNM1-TG ? (based on the numbers you just posted in the KW… thread)
(edit: maybe the drive currents can not directly be compared)
Agro
Agro's picture
278 cd/mm² at 83 lm/W? If yes – that’s incredibly good.
At this efficiency HWQP, Q8WP, XHP35 HI do a bit less than 150 cd/mm². XP-G2 is probably slightly behind. NM1 is nearing 200.
Agro
Agro's picture
No. According to that thread KW CSLNM1-TG does 281.7 cd/mm² when driven to 900 lm.
Boost HX at 6A (which is not peak) does 278 cd/mm². According to the datasheet, that’s 340+ cd/mm² at 8A. And the output curve looks like it’s far from the peak.
Frankly, I find it a bit too good….
Added:
A 1.9875mm² Lambertian emitter driven to 1670 lm has 267.46 cd/mm². Or 160.1 cd/mm²/lm.
djozz
djozz's picture
Thanks for the extra info Agro Smile
The_Driver
The point here is that you can use my conversion factors to calculate the luminance of these LEDs ( I also posted numbers in the other Ostam “white” thread) based on the lumens they put out. Just multiply the two values. You have already measured the lumens at different currents. Now we can calculate the performance of different lights using these LEDs.
Added:
There has always been a slight discrepancy between the measured values and using the lumens/(area*pi) formula.
Agro
Agro's picture
Further notes:
1. I see that The Diver listed the die size as just 1.25*1.59 rectangle. This is marginally untrue because of rounded edges.
If I calculate size from 0.167 cd/mm²/lm I get 1.906047 mm². 4.1% less? Rounding seems smaller than that, so we have some discrepancy, but marginally smaller than before.
2. From the application note:
“additional care should be taken to minimize mechanical stress on the silicone encapsulation”. Silicone? I thought they use sintered phosphors. Does that include silicone? Or did they just copy and paste this sentence from another document?
Agro
Agro's picture
If Boost HX actually becomes available reasonably soon and performs in line with the expectations, it’s going to give LEPs a run for their money.
It’s not as intense, but close enough to compete with the current generation of LEP flashlights. Output is way higher. Efficacy is good. Price…way way lower.
The_Driver
I’m not sure regarding that. Maybe they put silicone on top of the sintered phosphor.
Jerommel
Jerommel's picture
^ Just like XP-L HI and XHP35 HI
The_Driver
Well yes and know. Those LEDs also have silicone inside the phosphor and it’s not sintered (Cree has never mentioned this as far as I know). I mentioned the article regarding sintered phosphor here.
kikkoman
kikkoman's picture
This might refer to the white stuff surrounding the die. Could be a rigid silicone with fillers.
djozz
djozz's picture
That stuff on the PM1 is not silicone-like but seemingly rigid stuff that chips off.
contactcr
Last seen: 38 min 45 sec ago
djozz knows, he is a serial LED abuser.
Enderman
Enderman's picture
Maybe ceramic?
Stable at high temps…
Or that white cement stuff put on high temperature bulbs:
kikkoman
kikkoman's picture
Enderman wrote:
Maybe ceramic? Stable at high temps… Or that white cement stuff put on high temperature bulbs: !{width:25%}https://images-na.ssl-images-amazon.com/images/I/51hkWb4lk7L.SX425.jpg!
I’m pretty sure it’s not a premolded part since it encapsulates the bond wires (see the OSRAM document somewhere above). It’s very likely molded around the mounted die.
They talk about the types of materials used here: Link
I know it’s not very “silicone-like” but that’s based on the “typical” silicones we know. Even cheap Fujik is quite different (hard and almost brittle).
djozz
djozz's picture
The white stuff shows no flexibility at all, it breaks, and makes a scratching noise when I rub it with my forceps. It has at least the hardness of bakelite, or maybe it is ceramic.
kikkoman
kikkoman's picture
I know, the CSLNM1 I have here are packaged in the same stuff. Again, I see no reason why this couldn’t be a filled silicone compound. It behaves like one under the tip of a soldering iron too (gets crumbly around 300°C, never melts). And the advantages in this application are obvious.
How could they cast ceramic around the die + phosphor + bond wires (nicely visible in your pic btw)? They clearly mold this in place.
Aaaaanyway… my point was that there’s fragile bond wires embedded in there and that may be why they mention not to put pressure on it.
