Osram Oslon Boost HX
203 posts / 0 new
djozz
djozz's picture
Last seen: 7 hours 17 min ago
I don’t know enough about ceramics to know that it can not be casted in this way, so I’m with you in this Smile
CRX
CRX's picture
Last seen: 1 hour 31 min ago
Asbestos Big Smile
kikkoman
kikkoman's picture
It would have to be fired at 1000° upwards.
But it might be used here as a filler material (it’s stiff, opaque and doesn’t degrade or outgas Thumbs Up ).
Enderman
Enderman's picture
Last seen: 7 hours 44 min ago
http://www.cotronics.com/vo/cotr/ca_fastset.htm
There are ceramic adhesives which are used in bulbs because of low thermal expansion at high temperatures.
Just because it is “ceramic” does not mean it is solid like a rock.
It can be made into epoxies or other stuff.
eas
eas's picture
Last seen: 5 hours 25 min ago
Interesting. Ceramic powder with some sort of silicate binder.
Eleziel
Any updates on this?
Enderman
Enderman's picture
Not available yet.
https://octopart.com/search?q=KW%20CULPM1.TG&start=0
Agro
Agro's picture
Last seen: 48 min 21 sec ago
avnet lists them now with MOQ of 2000, no stock and no price:
https://www.avnet.com/shop/us/products/osram-opto-semiconductors-1/kw-cu...
LouieAtienza
Last seen: 8 months 3 weeks ago
Agro wrote:
avnet lists them now with MOQ of 2000, no stock and no price: https://www.avnet.com/shop/us/products/osram-opto-semiconductors-1/kw-cu...
LOL if we do a group buy with a 25 piece minimum….. Big Smile
djozz
djozz's picture
I would not mind buying 25 Smile
virencelights
virencelights's picture
Last seen: 9 hours 32 min ago
how would these compare to a flat white and would these work good in a triple LED light with optics?.
thank you.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k, Virence Jetbeam AAA Nichia HCRI Red Led.
Enderman
Enderman's picture
thank you.
This is the same thing as the 2mm white flat (CSLPM1.TG) but with a larger thermal pad for better overdriving capability.
There are no MCPCBs for it yet, hopefully LED4power will make some.
Eleziel
Enderman wrote:
HCRI9080 wrote:
how would these compare to a flat white and would these work good in a triple LED light with optics?. thank you.
This is the same thing as the 2mm white flat (CSLPM1.TG) but with a larger thermal pad for better overdriving capability. There are no MCPCBs for it yet, hopefully LED4power will make some.
Wait, it’s exactly the same otherwise? i can see the single 18650 tube zoomie with a collar putting out 1mcd already..
Enderman
Enderman's picture
Yes. Literally the same die just with bigger substrate for better thermals.
You won’t get anywhere near 1mcd in an 18650 size tube light.
Do the math and you’ll see.
Lothar
Lothar's picture
Last seen: 3 days 13 hours ago
So is it also a rectangular die? From the first picture it looks square, unless that was an old picture
Current Collection: BTU: Shocker (3 x SST-40 @ 8A)Lumintop: BLF GT70 (CW Sliced), BLF GTmini; Solarforce: 2 x L2P (XM-L2 U3 2C @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 2C @ 12A), M6 (Nichia 319A @ 6A), M8 (Cree XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 1A @ 2A)
Coming Soon: Lumintop: BLF GT4; Sofirn: BLF-LT1;
Enderman
Enderman's picture
It is rectangular, yes, you can see on the datasheet.
Agro
Agro's picture
TBH I don’t think it’s a viable source.
But it is a source which is a small step towards general availability.
Though now that I think about it – I remember when Hank managed to source a batch of old XP-G2 long after they were unavailable.
From memory – 1000 was sold very quickly with several members buying hundreds each.
Boost HX is likely to stay the throw king for a while so it makes sense to stash them if GB promises a lower price than a store would. Though better bins may appear.
So maybe 2000 is not out of BLF range?
Texas_Ace
Texas_Ace's picture
Last seen: 14 hours 52 min ago
Interesting, this means it should pop up on “normal” sites before long.
DavidEF
DavidEF's picture
Last seen: 3 days 1 hour ago
Agro, if the Boost HX turns out to be the next throw king, as the hype suggests it will, then 2000 pieces in a BLF group buy would be pretty easy to do for sure.
- The YKK Philosophy
contactcr
Last seen: 4 hours 19 min ago
  • Assuming we have a suitable MCPCB for it.
If the DTP 4040 fits as well as LED4Power thinks his Q8 board + 4 of these will instantly go in my Q8
DavidEF
DavidEF's picture
contactcr wrote:
** Assuming we have a suitable MCPCB for it.
OOOHHH! Make one for me too! I’ll start saving up for it. Cash
Agro
Agro's picture
Yes, DTP 4040 from L4P is probably a superb choice. Smile
Among the best MCPCBs (if not the best MCPCB) and already available.
Enderman
Enderman's picture
Yeah I’m just waiting for led4power to get them in stock like he did with the first two white flats Smile
M4D M4X
M4D M4X's picture
Last seen: 5 hours 36 min ago
mouser listed them too
but i do not find the "good" BINs
(from this datasheet)
brightness: 5S
voltage group: G5
i assume the lower bins will die fast in a DD setup
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
contactcr
I dont see the listing on mouser?
I did find arrow.com has the start of a page:
https://www.arrow.com/en/products/kw-culpm1.tg-z6rf6-ebvffcbb46-65g5/osr...
Looks to be lowest brightness bin and unknown voltage bin?
M4D M4X
M4D M4X's picture
contactcr
M4D M4X
M4D M4X's picture
aah thx
google must have offered me a "similar result"
sorry
LouieAtienza
M4D M4X wrote:
aah thx
google must have offered me a “similar result”
sorry
Got us all excited there for a moment…
Agro
Agro's picture
The lowest brightness bin is unlikely to beat KW CSLPM1.TG available from L4P.
