ENEDED
219 posts / 0 new
gorb507
Last seen: 2 days 4 hours ago
interested. What is the color temperature ?
Gorb507
BlueSwordM
BlueSwordM's picture
Last seen: 29 min 3 sec ago
5300-5700k.
gorb507
Thanks
Would you happen to know the approximate range ?
Gorb507
delete
Last seen: 1 day 10 hours ago
interested
octav
Last seen: 1 month 1 week ago
Interested depending on price.
Agro
Agro's picture
Last seen: 2 min 59 sec ago
SKV89 wrote:
I recommend you guys buy the Sofirn version. Sofirn just found the issue with their driver that caused it to under perform. My 21700 version makes even less lumens than the 18650 version. Sofirn is sending out free replacement drivers to those who bought the 21700 C8F with the bad drivers. This clone version is still using the old driver so should be making 1,000 lumens less than the Sofirn fixed version. Besides we should support Sofirn for coming up with this excellent design and listening to the BLF for suggestions.
Maybe we can have a Sofirn C8F group buy.
Nobody comments on that, I guess I can assume that UTorch has the inferior driver, right?
freeme
freeme's picture
Last seen: 1 hour 54 min ago
I am not really sure if this C8F model is able to see the light. innocent Sofirn is unable to provide support for my GB.
©freemex1thedeals.com
Jerommel
Jerommel's picture
Last seen: 2 hours 38 min ago
Did i say already that this is one ugly looking light?
HONDARIDER
HONDARIDER's picture
Last seen: 1 day 52 min ago
These are for sale at Gearbest for $28.99 right now. Have we confirmed these have the bad drivers?
freeme
freeme's picture
Seem like C8F project has been confirmed.
freeme
freeme's picture
Sofirn will get them fixed.
freeme
freeme's picture
Group buy is confirmed. We need names for at least 150pcs. Our group buy price will be marginally cheaper than C8F. However, you can be rest be assured that Utorch C8F will be the cheapest 3000lm (or one of the cheapest) flashlight to date.
d_t_a
Last seen: 8 hours 33 min ago
Interested, depending on how much lower the price would be, compared to the Flash Sale coupon price..
freeme
freeme's picture
Replied.
wstrachan
Last seen: 2 weeks 21 hours ago
Does anyone know how this compares to the sofirn c8f V2.0?
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
HONDARIDER
It’s already a good deal. Less than $10 for every 1000 lumen. Don’t know if you can find that very often. Be awesome if it were brought down to $25 or so. I would buy a couple for that price.
Rdubya18
Last seen: 1 hour 7 min ago
Interested
DENGOH
DENGOH's picture
Interested. May I know what is the final unlock price? Thanks.
cool i'll see you when you get there
blueb8llz
Last seen: 23 hours 59 min ago
Is the gb finalized? Is the final price 28.99 using the coupon from the first post?
freeme
freeme's picture
There will be another price coming in soon. If you are not short of lights, i advise to wait a bit longer. Coupon will definitely be for the first batch of C8F. They are scheduled to deliver by end of this month only.
tu_army
Last seen: 3 hours 58 min ago
interested depending on the price.
HONDARIDER
Suprised this isn’t doing a little better. Still need 40 or so more participants?
freeme
freeme's picture
I heard someone (Jason?) mentioned new Sofirn C8F driver has yet to address under-powered issue. Hope confidence would be reinstate for C8F after it is 100% fixed. If they wish to delay another month, so be it.
HONDARIDER wrote:
Suprised this isn't doing a little better. Still need 40 or so more participants?
HONDARIDER
Sofirn is supposed to be sending me 2 drivers to fix this issue. Hopefully they will work better once installed. I have 2 so I will post my results for each light before and after the new driver is installed.
JasonWW
JasonWW's picture
Last seen: 3 hours 34 min ago
It is quite strange. My driver with Sofirn 21700 was only pulling 7.2A and had 2580 lumen. I swapped to a better FET and got 9.3A and 2930 lumen.
I assume the FET swap helped. Testing a couple days later showed output was down to 7.7A and 2450 lumen. This was a head scratcher. I was thinking maybe the edge of the driver was dirty and not making good contact. I cleaned the driver edge and driver cavity and retightened the retaining ring. Then I measured 9.6A and 2930 lumen.
I don’t think it was dirty, I suspect the driver retaining ring is not tightening fully. It seems to tighten to a certain point and stop firmly instead of how a normal ring will continue to tighten as pressure is added.
SKV89 recieved his replacement driver with its new FET and saw no change in output.
So I’m thinking maybe it’s not a FET related issue, but a connection issue with the retaining ring. I plan to add a copper shim or maybe build up some solder on the edge.
I relayed this to Sofirn. I also suggested they swap to heavier led wire. I recently swapped it to 18ga and got 11.5A and 3330 lumen. So that is an easy factory upgrade that can boost output.
Click this to go to signature links.
nqcken
Last seen: 2 days 21 hours ago
interested
Nguyen
Nguyen's picture
Last seen: 1 month 6 days ago
Interested
klrman
klrman's picture
Last seen: 19 hours 2 min ago
JasonWW wrote:
] It is quite strange. My driver with Sofirn 21700 was only pulling 7.2A and had 2580 lumen. I swapped to a better FET and got 9.3A and 2930 lumen. I assume the FET swap helped. Testing a couple days later showed output was down to 7.7A and 2450 lumen. This was a head scratcher. I was thinking maybe the edge of the driver was dirty and not making good contact. I cleaned the driver edge and driver cavity and retightened the retaining ring. Then I measured 9.6A and 2930 lumen. I don't think it was dirty, I suspect the driver retaining ring is not tightening fully. It seems to tighten to a certain point and stop firmly instead of how a normal ring will continue to tighten as pressure is added. SKV89 recieved his replacement driver with its new FET and saw no change in output. So I'm thinking maybe it's not a FET related issue, but a connection issue with the retaining ring. I plan to add a copper shim or maybe build up some solder on the edge. I relayed this to Sofirn. I also suggested they swap to heavier led wire. I recently swapped it to 18ga and got 11.5A and 3330 lumen. So that is an easy factory upgrade that can boost output.
Very good troubleshooting there
Freedom
Freedom's picture
Last seen: 8 months 3 weeks ago
Interested if it will fit a protected cell.
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
Kazik
Last seen: 1 month 4 weeks ago
Interested. Wish there was NW option, but can’t complain since it’s <30 bucks…
