Sofirn SP36, impressions of a sample
542 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 56 min ago
joechina wrote:
Djozz you are a bad seller, I want the right light. Wink
Can we have a lanyard hole in the head?
Like the acebeam k30?
It would be also nice on the Q8 lamps
I will ask for it, the sample has no attachment points at all.
Btw, I was too tired tonight to do a teardown of the SP36 sample but I did some turbotime testing. This afternoon I set the stepdown temperature at 60 degrees (or so I thought) and let the light cool down and recharged the 30Q’s. Later this evening I ran the turbo-test. It ran for 4.25 minutes at around 4600 lumen before stepdown occurred, the flashlight head was then 67 degC. So about 3 minutes before the head is too hot to hold (but I could hold it by the battery tube until stepdown)
Sillen
Sillen's picture
Last seen: 4 days 5 hours ago
joechina wrote:
Can we have a lanyard hole in the head?…It would be also nice on the Q8 lamps
It has one Smile https://www.ebay.com.au/itm/173003374973
djozz
djozz's picture
I just measured throw of the SP36, and I get 39 kcd.
I also measured my high CRI 219B ROT66 and I measure 19 kcd, which is higher than maukka’s copy (he measured 14 kcd). The XP-L HI version of the ROT66 throws better btw, 60 kcd was posted by someone (seems somewhat high to me). The ROT66 manages that because it is higher powered with its 9 leds. (the XP-L HI version of the ROT66 has twice the output of the SP36. The thermal stepdown kicks in much sooner too: 30 seconds on my ROT66 when set at 60 degC., vs 4.25 minute on the SP36)
cclight
Last seen: 1 day 20 hours ago
Could you post the length and diameter?
It’s a FET driver, right? Any info on regulated levels, PWM?
The leds are driven quite hard at max…
VictorB
VictorB's picture
Last seen: 9 hours 39 min ago
I think it’s a good idea and an interesting flashlight. Do you know if sofirn is planning to take out his 21700 c8f with USB charger? for me it would be ideal for some gifts that I want to make.
SKV89
Last seen: 1 hour 56 min ago
Yep I totally agree. I’ll buy a few of the 21700 C8F with USB C recharge if Sofirn makes them
DB Custom
DB Custom's picture
Last seen: 2 hours 45 min ago
But of course, THIS is a discussion of the Sofirn SP36… there are other threads discussing their other lights. Wink
djozz
djozz's picture
The SP36 proves that Sofirn is able to make a flashlight with both Narsil and USB-charging, that is a desirable combination!
DB Custom
DB Custom's picture
This pipe bomb walks into a bar… the bartender says “Hey, aren’t you that crazy pipe bomb I threw out of here last night?” The pipe bomb says “No, I’m just another cheap flashlight with a built in USB charger and multiple Li-ion cells. Give me a break man! And a glass of water please…”
Satire, an attempt at humor where humor doesn’t exist…
djozz
djozz's picture
I ‘m not an expert on charging electronics but once I opened the driver I will make pictures, it may use a known and decent charging chip.
With batteries directly connected parallel it does not use balancing charging, monitoring each individual cell, my question is: how bad is that?
DB Custom
DB Custom's picture
Even IF a pricey name brand excellent charging chip was used, it’s still charging 3 cells in parallel that may be imbalanced and will almost assuredly become so at some point in the flashlights life. I sure wouldn’t use it. I remove those and plug the USB charging port with silicone to seal it up. I like my fingers on my hands and I like to be able to see… consider myself to be a compassionate person and don’t want to deprive anyone else of their senses either, Lord knows there’s far too many folks actually running around not using much sense these days…
Simple scenario, and we’ve had someone in the forum recently talking about how they do this… a 2200mAh store brand protected cell get’s put in the light alongside a high discharge 30Q and a 3500mA high capacity cell. All three of these, side by side, charge simultaneously from the same charging circuit. Hmmmm, yeah, I don’t think that’s a great idea! A lot of folks take chances daily that I’m simply not willing to take at all. I reckon Justin said it best when he said “It is what it is…” Still, I’ll stay well and clear away from that mess, thank you very much!
(Remember, you never know what someone else may have put in a light when they’re using it right beside YOU! Or in your building, at work, at the store, at the movies or in the mall, so simple for someone else’s error to become your life, or your loved ones…)
[I know someone that recently had a cell vent, scary scenario!]
BlueSwordM
BlueSwordM's picture
Last seen: 1 min 52 sec ago
Not bad at all. One parallel group of cells works as a giant group, so no problem there.
The only thing needed is temperature monitoring here, and a reverse polarity protection circuit for obvious reasons, physical, or electronic if possible.
E: I have to add something.
Different capacity+internal resistance cells in a parallel circuit is not too bad, since they will just be charging at different rates and will be equalized at the same voltage at the same rate.
The thing you do not want is putting different voltage cells in parallel. It won’t do much damage if the delta is less than 0,1V, but beyond that, it gets dangerous for the cells mostly.
UPDATE
Do not listen to my advice unless you have a multimeter and battery knowledge! It is advanced knowledge Smile
Keep a matched set of batteries for one large multi-cell light, and keep them at the same charge level when putting it inside the light.
DB Custom
DB Custom's picture
And for what it’s worth, I had 4 LG HE4’s, pretty new, in a Nitecore TM16 this past year, a matched set from the beginning, and one day one of the 4 was stone dead! The other three were holding their charge and seemed fine, that one cell wouldn’t charge and my chargers wouldn’t recognize it as a cell… is it really safe to charge up those parallel cells on a single circuit if one cell is that much off from the others? I mean, it didn’t just get dead all of a sudden, did it? We get lax, day in day out, don’t we?
DB Custom
DB Custom's picture
Preach it Blue, but it goes against everything we’ve practiced here for the past 6 years. Stay away from me and mine if you do that, I want no part in it…
BlueSwordM
No problem.
You want matched cells obviously. I’m just saying it’s not dangerous for someone like me and you
I wouldn’t have too much confidence in someone else putting a laptop cell at 3,6V and 2 fully charged 30Qs. Now that would be a nice combo, and a dead laptop cell Smile
klrman
klrman's picture
Last seen: 1 week 1 day ago
Any chance to have the illuminated side button in a different color to keep it a little different than the Q8?
BlueSwordM
Yeah. Let’s make it orange Silly
DB Custom
DB Custom's picture
The problem here, Blue, is that you’re trying to address the few dedicated flashaholics in a room consisting of 26,663 people. Only 58 members were logged in as of a few minutes ago, but we do have 26,663 members… you have to be careful the advice you spread, thousands of new people will take it for gospel and never check the voltage in their cells, don’t even have a multimeter. . . .
Satan@103TFS
Last seen: 1 hour 41 min ago
Any change to have SS bezel on this SP36 ?
djozz
djozz's picture
Dale, your concerns are mostly valid for all flashlights with parallel cells, with or without charging, like the Q8. Not everyone must be given a Q8. The question here is if the parallel charging part adds extra danger to that.
What we, based on assumptions, have been doing the past 6 years has, after actual testing, more than once been proven unneccessary or even wrong. Knowledge develops over the years.
I would like as much input as possible before dismissing this quite useful feature.
SKV89
Then what about those Imalent and Acebeam battery packs that consist of multiple cells in the DX80, MS12, X65, etc.
djozz
djozz's picture
Was thinking about that too and my conclusion was that is surely looks good but it also makes this light look more like similar lights like the ROT66, not sure if that is good.
BlueSwordM
That’s worse.
While in parallel, we have the problem with parallel differential voltage cell balancing, with series packs, we have to be careful of cell age, internal resistance, capacity.
We also have to install a capable BMS, and most importantly, we have to prevent polarity inversion of a cell.
klrman
klrman's picture
BlueSwordM wrote:
Yeah. Let's make it orange :p
How about blue or violet?
SKV89
Violet or orange would be good. Too many green and blue switch leds already.
pennzy
pennzy's picture
Last seen: 4 hours 18 sec ago
And laptops.
patmurris
patmurris's picture
Last seen: 9 hours 2 min ago
Do i read this right?
5000 lumen at startup out of the box.
Compact Q8 style 3 cells design.
USB C onboard charging…
That i can gift around without a charger or worrying about li-ion cells.
I WANT ONE!!!! – to start with. Cool
djozz
djozz's picture
The switch light is green, so a bit boring, but the sample is slightly the cyan side of green, a bit different from the Q8.
Of course this may just be what they had around for the sample light, the production light may simply be Q8-green. We can ask for a different colour, who knows.. (I quite like red for a change. Orange leds are very inefficient btw)
DB Custom
DB Custom's picture
Since when do we not have to “worry” about Li-ion cells Pat? Quite the contrary, gifting such a light should make you worry MORE, as the recipient is unlikely to remove the cells and even check that balance is being maintained. With low voltage protection being a process of the driver itself, the charging circuit is isolated and left to push the 3 cells simultaneously, regardless of their individual condition. Time to worry, indeed!
And when a light is built with the cells making a battery, there are controls in place to keep balance in check. Hence, a proprietary battery pack like in a lap top. Much different than user interchangeable individual cells.
I’ve been hot rodding lights for 5 years, been an advocate of Li-ion safety the entire time, but y’all go ahead and kill each other, I won’t say another word about it… ciao.
djozz
djozz's picture
I like to be on the safe side of things as well, I just want to know as well as possible what is actually safe, so that I can set my margins at the correct distance.
I’m sorry but that is the way I am, I base my behaviour on facts and statistics instead of rumour and isolated incidents (with often lacking crucial details in the story). If it appears that there is data about calamity rates of modern 18650 cells being circuited parallel for longer periods without balancing electronics I would really like to know.
To be clear: I’m not denying the risks, I’m trying to asses them. If the risks of keeping batteries connected parallel unguarded for longer times are real I’m the first to mark this light (and many other currently available products with USB charging that have this setup) as unsafe.
