Potting compound for building a tank light
60 posts / 0 new
Jack Kellar
Jack Kellar's picture
Last seen: 4 hours 28 min ago
Enderman wrote:
Jack Kellar wrote:
Enderman wrote:
I don’t know about any brands but I would recommend something that’s not just for waterproofing but also thermally conductive because there will be no air touching your components, so you need the potting compound to move heat away rather than insulate it.
Isn’t air a thermal insulator already?
It’s a fluid though so it cools by convection.
Air will keep components on a pcb much cooler than covering them with some non-conductive plastic or material.
I doubt convection is a thing when there’s so little air inside a waterproof M1, you can’t get a flow going and there are no real differences between one side of the minuscule air pocket and the other.
Enderman
Enderman's picture
Last seen: 8 hours 59 min ago
It doesn’t matter, simply the fact that the particles can move means that heat will be transferred to all the other metallic surfaces that the air is in contact with.
This is exactly why it is beneficial, because there is “no real difference between one side and the other”
If it was filled with a solid insulating material there would be a huge temperature gradient inside the light.
The goal of cooling is literally to reduce the temperature gradient so that there is no real temp difference, as you just said.
texas shooter
Last seen: 56 min 33 sec ago
I was just about to post this question also. I need potting for three reasons.
1.) to help bleed heat out of the electronics.
2.) to water proof the electronics, especially those with some kind of USB port.
3.) strengthen the components like USB ports that are prone to breaking loose.
Any one know of a product that can do all three? I’m trying to get up to speed on newer work lights like Acebeam, Mateminco TK01, etc but port connections like to break off the boards and leak in water.
Enderman
Enderman's picture
I know MG chemicals makes good solder pastes so I would assume they know their stuff on electronics assembly potting compounds too.
https://www.amazon.com/MG-Chemicals-Thermally-Conductive-Encapsulating/d...
Reviews seem good.
freefly
Last seen: 23 hours 10 min ago
Reviews seem good.
+1
I’d stick with a good thermally-conductive epoxy encapsulant.
I think there are some good options available from Stycast (now owned by Henkel/Loctite) as well.
Tom Tom
Last seen: 1 year 4 months ago
You are asking for three different things, which I think need three different materials.
1) Bleed heat out ? I don’t think any sort of encapsulation or potting will help much, more likely to insulate, you need to address the basics first.
2) Waterproof electronics ? This is exactly what conformal coating is for. I don’t understand why is is never mentioned here, it is compulsory for everything that I design.
3) Strengthen weak connectors ? Glue them up with suitable polyurethane or epoxy materials (no, not hot glue). Preferably polyurethane that can be easily cut away if the connector does eventually fail and needs to be replaced.
In summary, potting is not what you need. It’s purpose is primarily to strengthen the device against shock and vibration, secondarily to protect from humidity or other contamination, or, quite commonly, to render the device un-repairable (much more money to be made selling complete assemblies than encouraging simple component replacement) and to make reverse-engineering more difficult.
Which is why most potting compound is black, rather than naturally transparent.
Potting is also an easy consistent way to mass-produce cheap things that might benefit from it,or simply to make them un-repairable. Whereas precise glueing of key components, application of conformal coat, possibly with e.g. latex masking over connectors and test points etc. thereby creating a repairable, inspect-able part, is expensive, in skilled labour costs.
Enderman
Enderman's picture
Potting is also an easy consistent way to mass-produce cheap things that might benefit from it,or simply to make them un-repairable. Whereas precise glueing of key components, application of conformal coat, etc. thereby creating a repairable, inspect-able part, is expensive, in skilled labour costs.
Potting does literally those three things.
It is thermally conductive to help cool the electronics, it is waterproof, and it is a solid which strengthens all components against shock and vibration.
Of course there is some potting material which is not thermally conductive, which is why I recommended buying one which is.
You do not need a separate material for separate tasks, this is the year 2018 and humans have evolved a lot.
Tom Tom
Potting is a brutal thing to do to a circuit, unless you don’t care to ever look at it again. Just toss it if something goes wrong. It is generally a cheap solution for cheap things, that don’t justify any skilled workmanship.
As for “thermally conductive” compounds, once you study the numbers you may find that it just means “not as thermally insulating as the worst compounds, but still not great”
There is also a halfway-house using stuff like Raytech Magic Gel, which is not bad.
The OP is looking for ghetto ways of potting using locally available materials, at affordable local prices. I can’t really advise, because I’ve never been in that situation.
If the primary reason is for shock and vibration resistance, then yes, potting is the best idea.
Enderman
Enderman's picture
1) Potting is what you do when you want something to last as long as possible in the harshest of conditions.
Anyone who knows what potting is knows that if something dies you basically have to replace the whole circuit, that’s not a concern because electronics circuits last decades when designed correctly.
Also the point of potting is prevention.
That means you sacrifice repairability in order to make it last longer so that you don’t need to repair it.
2) Not all potting is permanent, some can be removed, as seen here inside my hellfighter:
3) thermally conductive depends on which one you use.
The one I linked earlier is close to 1W/mk which is many times higher than air.
It is not the same as a thermal paste which is 5-10W/mk but still good enough for preventing overheating of the PCB components.
Potting is good for waterproofing, cooling, AND shock resistance, assuming you buy one which is designed for all 3.
Not just shock resistance.
Please do some research.
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 3 min ago
I use Stycast when it’s in the shop, but I also use MG Chemicals. Both work excellent. You have to watch what you use, some thermal epoxy can be electrically conductive, I bricked a Convoy L6 once.
This is what I use from MG Chemicals https://www.amazon.com/gp/product/B005T8OSL0/ref=oh_aui_detailpage_o08_s...
KB1428 “Live Life WOT
Macka17
Last seen: 13 hours 26 min ago
Why don’t you just send an email to a “good” name torch MFG.
and ask them what. if anything they use. (Tech Services dep’t.)
They can only tell you to piss orft.
Then we ALL may just learn something new.
Most I’ve seen have been either grey or black.
The old “tar” chips we used to get from road laying crews
we used for everything. Melted, it stuck everything together. and free hey.
It was great to chew on too. very tangy.
Barkuti
Barkuti's picture
Last seen: 1 hour 26 min ago
Stars-922 may be a nice option: https://www.ebay.com/itm/HY410-STARS-922-Thermal-Compound-Sink-Silicone-CGPU-Silikon-Grease-Glue/163170389586
Takes a little while to harden, it depends on volume to area ratio. No volumetric shift. Once hardened remains slightly fexible but has adequate stiffness. I used this compound to stick an Omten 1288 inside an SK98 pogo switch retaining part whose slot is for bigger switches, like this one: http://kaidomain.com/S024498-DIY-LED-Flashlight-Reverse-Clicky-Switch-14_8mm-x-9_6mm-for-LED-Flashlight. After hardening took the pogo retainer out of my vise and could easily sand down the protruding plaster excesses. Worked like a charm.
Can be removed later with a bit of patience and some spirits help: alcohol, white spirit, gasoline, etc.
Worth a try imho.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
tvizk
Last seen: 1 week 3 days ago
Well, I do know PFlexPro uses Stycast (can’t recall product number) which isn’t available in small quantities.
Boaz
Boaz's picture
Last seen: 1 day 3 hours ago
How about urathane that they use to put windsheilds in with ?  Pretty tuff stuff
texas shooter
Thanks for the input. I work in Texas with heat, rain, humidity and things that fly across parking lots. Big fan of the P60 from SolarForce with premium Pflexpro dropins. These could spend two days in the pool with out worry of water getting in or parts breaking. I’m moving into 20700 and 21700 lights for better run time and output. Those USB style charging port are the new weak points. I’m looking at the Mateminco TK01/Astrolux FT01 as a possible replacement along with the Wuben A21. I’ve got no illusions that they might not make the grade. I think potting will give them a better chance. Once again thanks for the help.
joechina
I think Dale used Sugru to secure things in the driver cavity.
It is a self curing silicon.
tvizk
So, I made another M1 with the exact same parts since I gave away the first one for the other guy to abuse. This time, I mixed some Fujik with some 8w/mk thermal paste and applied that onto the driver covering the components. On the solder joints, I just covered it entirely in Fujik. I’ll try to get some abuse footage to see how well it holds up when I have the time.
Jack Kellar
Nice, looking forward to it already Thumbs Up
teacher
teacher's picture
Last seen: 1 year 6 days ago
Yep, looking good.
I had no idea Duracell sold 18650’s. Shocked
tvizk
teacher wrote:
Yep, looking good.
Hah! Just a little bit of Photoshopping and a clear wrap. Doesn’t look so good since my printer was low on ink but meh, close enough.
teacher
teacher's picture
tvizk wrote:
teacher wrote:
Jack Kellar wrote:
Yep, looking good.
Facepalm . Facepalm . Well, ya’ got me!! Big Smile . Nice job…. Thumbs Up . Wink
SSSmodlight
SSSmodlight's picture
oh.. di sini rupanya perbincangan berlaku Big Smile Big Smile
nice work.. waiting for the abuse footage..
the other one convoy s2+ is potted with the same compound?
tvizk
Haha.. Yeah I’ll pot the S2+ when I have the time.
tvizk
Had some free time today so I decided to have some fun with the M1. Some abuse, and played some small sport with it, kick bowling, baseball, and miniature golf. Also worth mentioning, I actually did everything in the first clip 3 times because the first 2 clips sucked.
Aftermath:
This was most likely due to the stiff spring I had on the driver. It’s bypassed with 20awg and I cut it a little too short, but meh, still works.. ¯\_(ツ)_/¯
KawiBoy1428
Nice work (over) on the M1 Thumbs Up Here is a vid from 2015 and the written review.
http://apdmarksmanshipteam.org/blog/pflexpro-flashlight-review/
My Surefire M3 D36 XHP70.2 module fully potted, reflector, copper heat sink and driver, fully encapsulated in thermal potting.
tvizk
!{width:100%}https://i.postimg.cc/0NzRYJhC/PART-1532039498723.jpg!
Yeah, I’ve been inspired by that video and have always had a thing for overbuilt things which is why I decided to make one like that. Before that, I never knew lights could be waterproof even without the lens which was amazing to me.
KawiBoy1428
Try restricting the battery movement, most real weapon lights have a shoulder in the battery tube anode side to keep the battery from impacting the spring/driver, protecting both driver and cell(s) maybe use o-rings to restrict movement. I also added extra shrink wraps to batteries that have oversize battery tubes, so they just slide in, now I size the inside of the battery tube and polish to fit specially in my 2S tubes. Just my 2cents.
tvizk
I do actually want to add some Fujik to the anode side but it wouldn’t be removable. Or I could add Fujik around the spring avoiding the retaining ring but I absolutely hate working with it. It’s gooey and sticky and needs to be delicately cut to shape when dried. For now, I think a washer should work pretty well.
Tom Tom
This.
Recoil will bash in the front (positive) of the cells. No point using a spring there, a stud, and a potted driver might survive.
Better though to design the front end to pass the the recoil back to the cell through the outer circumference. Not the +V terminal.
Never seen that done, though it is so obvious, and so easy to do.
