Angle grinder belt sander attachment (Sanding Belt Adapter Head M10/M14)
Hey lads i was cruising Aliexpress and found an angle grinder attachment. The attachment is for a belt sander it basically converts your angle grinder into a mini belt sander. I am not sure of the quality but its fairly interesting. Apparently its made from aluminum but i do see some plastic on it.
The belts are a small size but it might be a cheap option for some one who only does casual sanding or needs a narrow head on a sander. The narrow head will help get into tight spots.
First time i have seen one of these for sale but i have seen the DIY builds on YouTube.
This is the link other seller may also sell it i have not checked.
https://www.aliexpress.com/item/Sander-Machine-Sanding-Belt-Adapter-Head-Convert-M10-M14-Electric-Angle-Grinder-Mayitr-Woodworking-Grinding-Power/32860513632.html?spm=a2g01.11715694.fdpcl001.16.25d025c4bscesM&gps-id=5589660&scm=1007.19201.111800.0&scm_id=1007.19201.111800.0&scm-url=1007.19201.111800.0&pvid=1be4b715-866a-4c20-8a91-54ff1f410dd9
The price is 20USD so not super cheap but not to bad i guess, A belt sander will cost more.
Any one got one?
