Fireflies E07 preview
2054 posts / 0 new
chinooker
chinooker's picture
Last seen: 1 hour 57 min ago
don’t worry about making your watermarks nicer
make them harder to circumvent or crop out
we appreciate your stuff and don’t mind reading between the lines
SKV89
Last seen: 4 hours 7 min ago
TK thanks for the pics. So it seems like the blue/purple can be in differentA orientations
nokoff
nokoff's picture
Last seen: 5 days 15 hours ago
Thanks TK. I agree make it a larger watermark on the product so it can’t simply be cut out, unless you plan to actually sue them.
Those pics show off the color difference between the champagne and desert yellow, first I’ve seen together. I wonder why they didn’t stick with champagne this time.
Nokoff..still Made in China 山寨主義
g_damian
g_damian's picture
Last seen: 8 hours 32 min ago
Is the driver glued? How hard would it be is to reflash it?
Jay
Last seen: 5 days 14 hours ago
There’s already a large watermark on the pics, it’s just very subtle.
chadvone
chadvone's picture
Last seen: 1 month 6 days ago
TK darker watermarks is my vote. I noticed, but only really notice after I read about it. Just put TK right over there branding?
Interested in throw and beam pattern.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 57 min ago
The driver has reflashing pads on the spring side, which should be compatible with Lexel’s flashing key. So it can be reflashed without removing the driver.
But I don’t know if it can be reflashed without removing the aux LEDs. Lexel’s previous designs were all incompatible with the flashing process, so it was necessary to unsolder one of the aux LED board wires before reflashing. That might still be the case, but I won’t find out until I get a suitable flashing key.
My guess is that you’d need to unsolder one of the aux LED wires at the front of the light, then flash the driver, then solder the wire back on. Because the current regulation used on the aux LED board may interfere with the flashing protocol. Same reason why the aux LED board doesn’t have a low mode.
hank
hank's picture
Last seen: 11 hours 48 min ago
Maybe a lawyer letter pointing out that by using your image (which is automatically copyrighted), they have agreed to send you a baker’s dozen of the flashlight pictured.
Surely there’s a shrinkwrap agreement to be asserted here.
https://www.copyright.gov/help/faq/faq-general.html#mywork
ToyKeeper
ToyKeeper's picture
About the watermark thing, I’ll fix it eventually. This was just a quick test to make sure it could be done automatically as a batch using a short script. I don’t actually care enough to do a manual process, like manually adjusting the placement and opacity for each image. So I’ll adjust the input files and parameters to make it just barely visible on a wide variety of images, and probably get some sort of logo to put in the corner.
This quick test was just “use the simplest boldest font on my computer so I can get the script working”.
I was also kind of having fun experimenting with global illumination in order to reduce and soften shadows.
freeme
freeme's picture
Last seen: 10 hours 14 min ago
Color turns out well for desert yellow. FF should consider making ROT66 in desert yellow now. wink
d_t_a
Last seen: 7 hours 1 min ago
I just got the Fireflies PL47, and I notice the Aux-LEDs can be in 3 states: Off, On(High?), Blinking.
Whereas in the Emisar D4S, it has 4 possible states, Off, Low, High, Blinking.
(on the BLF Q8/Sofirn Q8 with Anduril, the side button can also be in 4 possible states: Off, Low, High, Blinking)
I notice the PL47 does have similar programming pins as the D4S, but you mentioned that with the Lexel board (PL47), I wouldn’t be able to just flash it (assuming I’m able to align my ordinary-type ATTiny programmer device with some pins to flash it)?
Maybe they initially planned it to be champagne gold like the ROT66, but anodizing turned it too yellow, so they now call it desert yellow. ;-p
Tjohn
Tjohn's picture
Last seen: 5 days 17 hours ago
Quote from d_t_a ……
“Maybe they initially planned it to be champagne gold like the ROT66, but anodizing turned it too yellow, so they now call it desert yellow.”
…or maybe they plan to offer Dijon com Champagne
Mildlyangryjohnny
Mildlyangryjohnny's picture
Last seen: 1 year 1 month ago
leaftye wrote:
Did anyone getting a shipment notice yet?
Yes. Just got shipped email. Ordered 11/29 #618 i think. Gray nichia.
Paid full price—didnt want to wait on coupon. I was part of the group that argued pretty strongly to get that extra fin!
If we could just “get to the coppah” option now, that would be outstanding.
Will probably order a clear one once i decide how i like pl47s which are still enroute.
Glenn7
Last seen: 1 day 15 hours ago
yep got my notice today too
Glenn7
Grey
DB Custom
DB Custom's picture
Last seen: 49 min 26 sec ago
All black flashlights shipping to California are under a quarantine, will probably be February before they lift it… beats me why that would be.
contactcr
Last seen: 12 hours 10 min ago
A flashlight that holds 7 LEDs to California? Fuhgeddaboudit.
Better be 5 LEDs or less and only one can be turned on per switch press. Plus it includes something called a “clip”? Will be caught up in bureaucratic red tape forever thanks to that.
DB Custom
DB Custom's picture
And this one in particular has auto step down for thermal control, a 7 round clip automatic, yeah, good luck with that!
lotrbfme
lotrbfme's picture
Last seen: 1 hour 10 min ago
Could someone please explain the different types of LEDs?
I am looking to get the most floody and also one that is a good combination of flood and throw.
Thanks in advance!
Nichia
Last seen: 1 month 3 days ago
Guys please someone tell me what's the color temp of the nichia 219b they are using here? Is it the 4500k  R9080 ????
Nichia 219B
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 15 hours ago
Yes, 4500k R9080.
Nichia
BlueSwordM wrote:
Yes, 4500k R9080.
How do you know that??
Nichia 219B
Jay
Snippet from an email conversation with Fireflies:
“Yes, E07 R9080 219B option is SW45K R9080 D220.”
Nichia
Jay wrote:
Snippet from an email conversation with Fireflies: "Yes, E07 R9080 219B option is SW45K R9080 D220."
then why they don't list it on their website??
Nichia 219B
DB Custom
DB Custom's picture
Could be you’re asking that question to the wrong people…
Are you an official representative of the Japanese based Nichia company? If not, sure hope that massive firm doesn’t take offense at your use of their name and prosecute….
SKV89
Nichia wrote:
Jay wrote:
Snippet from an email conversation with Fireflies: “Yes, E07 R9080 219B option is SW45K R9080 D220.”
then why they don’t list it on their website??
It’s well known that Fireflies sourced a large batch of 219B sw45k 9080. Many people here bought the 219B version and can confirm it is the 4500k 9080. Maukka also tested them in the ROT66. Look it up.
Nichia
They also bought the 4000k version I want make sure 100% am buying the 4500k and tried to contact them but with no luck
Nichia 219B
SKV89
Where did you read that they bought the 4000k version of the 219B? You’re probably thinking of the SST-20-W 95CRI 4000k version.
Nichia
SKV89 wrote:
Where did you read that they bought the 4000k version of the 219B? You're probably thinking of the SST-20-W 95CRI 4000k version.
I have read that info here somewhere but can't remember where?
Nichia 219B
Dmitriyrus
Has anyone ordered a yellow aux-led? I want to order this color, but there is not a single photo, how it shines.
