Fireflies E07 preview
2043 posts / 0 new
Glenn7
Last seen: 3 days 12 hours ago
Tally-ho wrote:
The raised part for the button on the previous version looks better and it would be easier to recess the button in that part.
The new milled flat for the button removes metal mass which should be kept for heat management.
!https://hsto.org/getpro/megamozg/post_images/3ca/3cf/9d0/3ca3cf9d0bed7f2...!
Recessed button might be better, but to my eye the head looks bigger with deeper fins and the bezel is longer/bigger/stronger so mass looks bigger anyway.
Tally-ho
Tally-ho's picture
Last seen: 1 week 6 days ago
Yes but heat conductivity is greater in a one piece part, particulary in aluminum or copper. A “longer/bigger/stronger” stainless steel bezel isn’t as much important for heat management than for the one-part-head where the LED MCPCB sits.
I was just pointing that with the button raised part of the previous prototype you could have both recessed button and a bit greater head mass…and incidentally a better looking flashlight IMO.
But that won’t happen as the new proto is said to be final.
d_t_a
Last seen: 15 hours 52 min ago
would like to know approximate thermal stepdown / runtime behavior. Like how quickly will it stepdown from Turbo? I suppose with many emitters, it will still get fast relatively quickly… hopefully at least as good as D4S or better (time it takes before stepping down, let’s assume set to max thermal control setting)
djozz
djozz's picture
Last seen: 7 hours 34 min ago
I see the fuss about the raw machined version, looks really cool, but for me I like this light in the same matt black ano with SS bezel and tail cap as my ROT66.
P33
Last seen: 5 days 7 hours ago
I’m pretty sure they should stick to black/champagne color scheme as the previous light to make anyone who wants to have all of them in one colour BUT a third – clear anodising – option would also be great.
SKV89
Last seen: 1 hour 40 min ago
But that won’t happen as the new proto is said to be final. !https://forum-images.hardware.fr/images/perso/cerveau%20totoz.gif!
I totally agree with you especially on a small head like this, it is important to maximize thermal mass and surface area. I wouldn’t want a large stainless steel bezel, which is a thermal insulator. We do need a bezel inorder to get to the mcpcb so I prefer an aluminum bezel so it can absorb and shed heat much better.
I also agree that they could have raised the finning around the button to leave a recessed button. The current design with the wedge at the button loses some mass and fins around the button. But I doubt FF will redo the design since they already said this is the Final.
SKY69
Last seen: 13 hours 37 min ago
Very interested can’t wait to see the final product
AlexGT
AlexGT's picture
Last seen: 2 hours 20 min ago
Since the PL47 is starting to ship, now my attention shifts to this light, I want one!!!
Anyone knows what specific TIR optic are they going to use, is it Ledil, Carclo?
djozz
djozz's picture
Or the same optic as the DQG tiny 26650.
DB Custom
DB Custom's picture
Last seen: 3 hours 13 min ago
I sure wish they’d “embiggen” the individual TIR’s so they merge, all that wasted space kicks in my OCD and makes me crazy! Sick Maybe they could make the center TIR larger to attempt some throw? Just sayin…
Pavlo
Last seen: 26 min 9 sec ago
I like the idea of a larger center TIR for better balance of flood + throw.
freeme
freeme's picture
Last seen: 1 day 10 hours ago
Forget about bare aluminium.Let's make it in titanium! tongue-out
©freemex1thedeals.com
Agro
Agro's picture
Last seen: 35 min 57 sec ago
There’s a huge number of Chinese ~35mm lenses available, they are used for one of light bulb standards. Unlikely to be exactly the same as Tiny, though it could be compatible. Judging by head diameter I think the lens would be <35 mm.
SKV89
freeme wrote:
Forget about bare aluminium.Let’s make it in titanium!
Titanium is a heat insulator instead of conductor, which is not a good choice for a high output scorcher like this. The heat will get trapped in the MCPCB and internal components will get damaged pretty quickly.
djozz
djozz's picture
It is a cruel freak of nature that the unchallenged no 1 best material for flashlights is such a cheap and common layman’s material as aluminium.
hank
hank's picture
Last seen: 2 hours 7 min ago
I don’t like those snap-on/pop-off belt clips at all.
I highly recommend the full circle attachment Solarforce has:
https://www.solarforceflashlight-sales.com/products/solarforce-full-stai...
djozz
djozz's picture
!{width:50%}https://shoplineimg.com/57578d62617069110ec20000/575af35f617069328f7a5c0...?!
I completely have the same opinion, plus that a clip that goes parallel to the battery tube (Olight, Solarforce) looks much better than one that slopes towards it.
mihlit
Last seen: 7 hours 5 min ago
Is this just your wish or do you have some information, that it will have titanium body (as an option)?
This flashlight looks nice, but as usual, I have (several) different flashlights, that can do the same job, so I don’t really need it… BUT if it was made of titanium, it would be a piece to collect Smile
lmcmann
In for one, most likely. More accurately, I won’t be able to resist picking one up. Darnit.
I do like the idea of a TIR with a larger center optic, to increase throw a bit.
Larry
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 50 min ago
I would love to see a full-circle clip in an Olight deep-carry style. Sort of a mix between the picture above and this one:
Except in this case, the clip would be on the tail instead of the head. Starting from the tailcap, it would have a full ring between the tailcap and body tube. Then it bends back toward the tail, turns 180 degrees just before it reaches the back end of the tailcap, and goes forward again. It stays parallel to the body until it dips down to touch the side of the battery tube. Then it slopes upward to provide a place to slide fabric underneath, but it doesn’t go up as high as the long parallel section.
leaftye
Last seen: 2 weeks 3 days ago
You’re correct. Forget about extremely affordable and easily machinable aluminum for a light as affordable as this. We need to get serious and start looking into flashlights made from diamond, cubic boron arsenide, or graphene.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Mildlyangryjohnny
Mildlyangryjohnny's picture
Last seen: 1 year 2 weeks ago
Has there been any word on when they expect the e07 will be made available? Seems like alot of competing lites in the 21700 format all of a sudden. None seem as interesting as the e07. But my new samsungs are getting anxious.
djozz
djozz's picture
Silver and gold have good properties too (bonus: bling added). Or else tungsten (why are you limping? I’m just trying to EDC my Fireflies E07)
DB Custom
DB Custom's picture
Photon Fanatic took a square bar of Tungsten, cut it to round, then made a very unique flashlight from it. The weight was obviously more than other lights but not prohibitive. Remember, even with the weight of Tungsten or Gold the flashlight is a hollow tube, not a lot of solid area to make the weight add up. (in other words, even with a much larger light it would take quite the weakling to develop a limp from carrying a light!)
PBWilson
Last seen: 4 hours ago
Isn’t tungsten brittle? How would it perform in the thickness we see in common battery tubes? Just curious.
DB Custom
DB Custom's picture
Tungsten can be too hard, making it susceptible to breaking on impact. Brittle? Matter of perception I guess, I’ve been using the same tungsten carbide cutting dies on the lathe for 2 years… Dropping a flashlight made from tungsten most likely wouldn’t break it or show any visible result, slamming it down on concrete might would fracture it.
Been wearing a gold titanium nitride coated W wedding band for several years, wear it working on the lathe, wear it all the time, no scratches and it’s as shiny as new. Anything else get’s beat up pretty quick.
contactcr
Last seen: 48 min 5 sec ago
Tisk tisk Dale, wearing jewelry while working with tools? Calling OSHA, please stand by
I suppose you of all people probably have enough tools to cut it off should you have to, lol
nvanlaar
nvanlaar's picture
Last seen: 1 month 1 week ago
The amount of mass that little bit would contribute would be inconsequential to the heat management and/or run-time.
“Facts don’t care about your feelings.”
~Ben Shapiro
DB Custom
DB Custom's picture
I got married in 1983 originally, was divorced by the end of the year and remarried in 84. Divorced again in 2000 and remarried in 02. I’ve worn a wedding band what seems like forever… regardless what work I was doing. Cognizant of the facts, pay attention. (well, except for the woman thing, seem to have slipped a few cogs where they’re concerned)
Bastarrdo
Bastarrdo's picture
Last seen: 1 month 1 day ago
@fireflies
Please build this light with Clear anodize. Pleeeeease!!!
It looks sooo coool!!!
