Fireflies E07 preview
2050 posts / 0 new
contactcr
Last seen: 2 min 19 sec ago
they should not “overheat”, are you sure it’s not just the anduril blink telling you it’s at the top of the ramp? I dont remember if the stock E07 firmware has that or not
DEVGRU120903
Last seen: 2 months 5 days ago
Hi! I know the quick flicker when reaching the ceiling ramp and the floor. However this one is a flicker for about 3 seconds then it disappears.
contactcr
You should probably clean everything with alcohol (springs, threads, driver ring, and your battery + and -)
If you are using 18650 make sure to use flat top with their black adapter. If you are using 21700 make sure it is flat top and not too long (Chinese brand battery sometimes are while OEM brand is shorter)
cowboygg
Last seen: 3 days 15 hours ago
fireflies E12
twisted raven
Last seen: 4 days 3 min ago
Nice looking light.
Th558
Th558's picture
Last seen: 12 hours 20 min ago
That thing better be factory spring bypassed. Wonder what the head with is. Maybe 45mm?
Once I told them to make and E09 and they made an E12 instead Big Smile I’m not complaining though.
twisted raven
Looks like they just stuck the ROT66v2 optic in an E07. So it should be the same bezel diameter as the ROT66.
Th558
Th558's picture
Does seem like it. That’s means it’d be 50mm. I’d prefer something smaller with less throw. I like the floodier beam profile on my FW21 Pro.
contactcr
This guy problem solves
