Maratac CR123 Rev3 Triple Nichia 219C 5000K 90CRI & Lighted Tail Switch
9 posts / 0 new
CRX
CRX's picture
Last seen: 27 min 2 sec ago
A forum friend asked if I could make this light into a triple with the added question of fitting a tail switch.
Cree XP-G3
CR123 3v Cell
Low - 15lm
Med - 61lm
High - 245lm
I knew the triple mod was do-able but due to the new tail design of the revision III model I was not sure about the switch.
First thing to do was a mock up of the light with similar parts that I intended to use.
And some quick calculations Big Smile
Cool to proceed Wink Thumbs Up
Installed a 2mm thick copper slug and lined the aluminium pill with copper sheet. Filed off some or the top threads so the pill can sit further into the flashlight head, required due to the switch & triple setup.Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.
Sanded down the triple MCPCB and optic to 18.4mm. Used tape taken from the MCPCB for a template for sanding the optic and to protect it during.Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.
Installed the driver, LEDs & NTC sensor to the pill and made a glow disc.
The copper sheet allows two soldering points for driver attachment. Fitted in flashlight head.Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.
Made a copper enclosure for the green ILC-0 lighted switch and drilled out the tail to fit a 12mm rubber boot.Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.
Fitted clip.
Almost done.Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.Triple Nichia 219C D240 5000K 90CRI on 18mm MTN DTP MCPCB
L4P LD-A4 3A driver
10507 Carclo optic
Green GITD glow disc
ARC glass
Copper & aluminium pill
ILC-0 reverse clicky green lighted tail switch
SS clip
Lockout-able
Length – 70mm
Width – 22mm
Weight – 104g (with 16340 cell)
Max - 1624lm (DD)
Max - 780lm (3A)Maratac CR123 Rev3 - Triple Nichia 219C 5000K - LD-A4 6A - 16340 - Lighted Rv Clicky Tail Sw - 1624lm.
Edited by: CRX on 10/26/2018 - 14:19
MascaratumB
MascaratumB's picture
Last seen: 5 hours 56 min ago
Shocked Shocked Shocked
Uau, just..uau!! Nooo, not for the mod, just for the calculation Big Smile Silly
Well done mate, that light looks great now!! Awesome work Hat
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
-X3-
-X3-'s picture
Last seen: 1 hour 52 min ago
You made a mistake, just here :
Innocent
Amazing work, as always !
Even inner parts are polished, that’s how you see one loves modding !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Essexman
Last seen: 3 days 17 hours ago
Lovely mod, great looking light, excellent work sir!
Nicolicous
Nicolicous's picture
Last seen: 3 hours 1 min ago
nice
Beer
Nico -.-
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 7 hours ago
Another brilliant CRX mod Thumbs Up
Hoka
Last seen: 10 months 2 weeks ago
Simply stunning!
You make it look so easy!
If the production version was similar, they’d sell a ton of them.
Slayer1
Slayer1's picture
Last seen: 48 min 56 sec ago
Speechless!! Thumbs Up
jon_slider
jon_slider's picture
Last seen: 11 min 23 sec ago
I could not follow the calculations.. LOL
but that MentalHealthTransponder is Brilliant!;-)
