New Folomov 18650s
182 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 3 days 9 hours ago
djozz wrote:
It could be simply that the 219D is not capable of high current.
Hmm, tomorrow I will fire up my bench PSU to see how many amps it takes before the LED turns blue.
By the way, the whole driver circuitry seems to be implemented into the tail, as shorting the tube with the BATT- creates a direct drive.
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
Tom E
Tom E's picture
Last seen: 4 hours 57 min ago
bilakos10 wrote:
Hmm, tomorrow I will fire up my bench PSU to see how many amps it takes before the LED turns blue. By the way, the whole driver circuitry seems to be implemented into the tail, as shorting the tube with the BATT- creates a direct drive.
Did'n't check specs, but yes, seems like the 219D is low Vf LED, so amps can go crazy. That pic I took of the tail PCB certainly appears to be everything a fully working driver needs - I'm assuming that is a full driver, and at the head, is probably something simple like a resistor or something, no smarts. Got a couple of 18650S owners over on FB (Flashoholics Anonymous group) saying they don't see the blue shift on turbo on full charge, but mine is not showing that now as well. May have to risk an attempt to get the head apart.
Firelight2
Firelight2's picture
Last seen: 4 hours 17 min ago
Just got my 18650s.
Preliminary impressions:
  • Out of the box quite nice. Great fit and finish and nice compact size. No sign of blue-shifting tint when I used the partially charged cell that came with the light.
  • But then I used the built-in USB to fully charge the folomov cell and PROBLEM!!!! When turned on in turbo the light blue-shifts within 5 seconds and output drops dramatically. Instead of 800 lumens it looks like its only outputting 100 lumens.
  • Once the light is warmed up by having been turned on and off for 5-10 seconds, the problem is worse. Turning the light on while it is warm causes the blue shift and reduction in lumens to happen almost instantly (less than 2 seconds).
  • and all of this is with the cell that came with the light! It’s not even a high discharge cell I assume.
My guess is the LED simply can’t take the amps. Either that or the LED is defectively installed. If anyone can get the head open it might be worth swapping the LED to something else. Perhaps XPL HI.
djozz
djozz's picture
Last seen: 5 hours 20 min ago
When my 18650s arrives I will not switch it on but directly remove the led for testing!
Brainsick67
Brainsick67's picture
Last seen: 2 months 4 weeks ago
Firelight2 wrote:
Just got my 18650s.
thats so odd..i didnt use the usb to charge, but charged the batt in my own charger, and dont get that.
I'm ThatCrazyFlashaholic 67
M4D M4X
M4D M4X's picture
Last seen: 5 hours 32 min ago
was the cell overcharged ?
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
ToyKeeper
ToyKeeper's picture
Last seen: 23 min 17 sec ago
The most interesting thing about this light seems to be its tail-mounted driver with no extra channel to run BAT+ back or run the switch signal forward.
How does that work? Does it seem like something which might be useful for BLF designs?
Firelight2
I agree. I’d LOVE it if someone made a tail mounted e-switch driver that didn’t need the extra channel and sold it on Mountain Electronics. Love Love Love
Firelight2
No idea. I’m at the office right now and don’t have a way to test voltage. I charged it until the little red LED on top of the cell turned green.
Tom E
Tom E's picture
I agree - it's fairly unique, but I think the UltaFire UF10 had the same design. Here's the UF10 driver from the tail:
I really like the UF10, same sort of tail e-switch, but much simpler UI. All I did was swap the LED/MCPCB,and maybe wires to get more output and added bypasses.We use it about every night with the dog.
Ohh, this is the PCB at the head, so there are some surface mounts but no smarts, I believe:
This is how I tested for amps:
tail assembly:
I went dedomed in the UF-10:
The pics on the UF10 were all from Aug 2016.
Tom E
Tom E's picture
Mine sure wasn't. Happened on multiple cells - 30Q BT, PanaB BT, etc.
Muto
Last seen: 3 hours 4 min ago
This info is disheartening.
I ordered one which will arrive tomorrow after the all clear was given.
Maybe I’ll get lucky with my sample but Not going to keep a flashlight that can’t be dis assembled to fix.
How does the flashlight operate with other cells?
Thanks
Keith
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
Firelight2
Actually, I think the fully-charged cell might be providing too much voltage to the LED.
After running the light another couple minutes on and off I notice that it no longer seems to blue-shift and dim. So the issue seems to occur with the fully charged cell.
Anyone figured out how to change the LED in the 18650s yet? From looking in the back of the head it looks like a press-fit plastic washer might be keeping the guts of the light in place.
Tom E
Tom E's picture
Firelight2 wrote:
Actually, I think the fully-charged cell might be providing too much voltage to the LED. After running the light another couple minutes on and off I notice that it no longer seems to blue-shift and dim. So the issue seems to occur with the fully charged cell. Anyone figured out how to change the LED in the 18650s yet? From looking in the back of the head it looks like a press-fit plastic washer might be keeping the guts of the light in place.
Well, that's not press fit plastic. It's a black painted LED isolator glued to, what I think, is a shelf. I got the isolator ring off and it exposes threaded screw holes with screws in them from the top. Only way they could do that if the front end bezel comes off - suspect it's glued,very hard to see where.
Tom E
Tom E's picture
Muto wrote:
This info is disheartening. I ordered one which will arrive tomorrow after the all clear was given. Maybe I'll get lucky with my sample but Not going to keep a flashlight that can't be dis assembled to fix. How does the flashlight operate with other cells? Thanks Keith
Yeah, not the best UI and weaker output that spec'd, as stock. Looks difficult to mod, and this is all assuming you don't blow the LED -- ugh...
chadvone
chadvone's picture
Last seen: 1 month 5 days ago
Maglite has tail mounted drivers on there XL lights.
Edit- but they run 3aaa in a odd carrier
ZozzV6
ZozzV6's picture
Last seen: 19 hours 51 min ago
Nothing magic done there. If the driver is completely in the tailcap it can work. think about that way that the tube is the led negative wire. The led positive is directly connected to batt+ and that is all. So the head only have a contact PCB which connects batt+ to led+ and tube to led-.the circuit is the same just the driver location changed in the light. The only drawback I see that is not good for high power lights because you can’t measure heat at led. If thermal sensor is in the controller it takes a lot of time to sense the heat. The only working option is timed stepdown. I hope I soon get mine and make an X-ray photo from head to see if there is any parts in there other than only a PCB.
Cereal_killer
Cereal_killer's picture
How does the drivers MCU get batt+? I think that’s the magic she’s implying (seems magic to me too!)
ZozzV6
ZozzV6's picture
Maybe it has some resistor parallel with led on the contact PCB in head to allow a little current.
Tom E
Tom E's picture
How does the drivers MCU get batt+? I think that's the magic she's implying (seems magic to me too!)
Just look at the UF10 batt+ contact board above, and what I stated couple times earlier of measuring 51 ohms between batt+ brass button and the head housing, so there's current running through there. The UF10 has that hidden "thing" under the white hardened goop -- hhmm.
Tom E
Tom E's picture
John from FB said: Mine turns blue and it gets quite hot. I've never seen one turn that color before and thought maybe mine was the only one like that. I'm going to see if I can get my money back. This is my first and last Folomov.
It's not sounding good...
Firelight2
I emitter swapped my Folomov 18650s today. Cool
This fixed the issue I was having with the emitter blue-shifting and getting dimmer with some fully-charged cells. Turns out the 219D just can’t take high current.
No pictures, but here’s how to emitter swap the 18650s:
  • The head looks like it’s in one piece, but it really isn’t. The bezel is the smooth portion ahead of the fins on the head. It’s just screwed onto the head. I applied 3M indoor stairway grip tape in a ring around the head and another around the fins and unscrewed. The bezel came off easily. There was no glue, but there is an o-ring.
  • With the bezel and lens removed, lift or tip out the smooth reflector to reveal the star.
  • The star is copper and is screwed onto the full shelf on the head with 2 screws. There is one wire connecting ground to the star. On the back of the star is a soldered post that directly contacts the top of the battery. The star also has 2 resistors on it. There is no other board at the head of the light. The driver is in the tail.
  • Desolder the negative wire from the star, then unscrew and lift out the star. Some thermal paste was used under the star, but more would be better.
  • The hardest part was heating up the star enough to remove the emitter without the post on the back getting out of position. I used a wooden clothesclip held sideways in a vise to grip the post on the bottom of the star, then used hot air reflow to remove and replace the emitter. I replaced it with a XPL V6 3D that I had laying around. I might end up replacing this later with an XPL HI for more throw.
  • I also added a copper disk onto the bottom of the post at the bottom of the star to allow flat-top cells to be used.
Muto
Firelight2
Thanks for the detailed de-construction!
Got mine yesterday and decided to try a burn-in at the medium setting, tail standing for a half hour.
Used a Sony 2600 laptop pull charged around 4.09.
Light got mildly warm but no problems.
Have not tortured the light at full voltage on turbo for more than a few seconds and have decided not too.
I Love the tint and have plenty of other pocket rockets that can be used for “shock and awe” but this one will just be used in an EDC setting and will leave alone.
That may very well be Un-BLF of me but do not want to give up on the good overall function of the flashlight at this point.
Will just use with a battery that is not full up and/or high amp.
If Folomov comes up with a solution, great, but for now it’s good to go.
It does not appear to have low PWM and has the perfect (for me) moonlight and also like the mode spacing.
Really wish it had a BLF A6 style driver with reverse mode switching but it has memory so can chose setting I like and leave it and still have access to Moonlight.
Also love the Soft Ramp Beacon, very nice touch.
Later,
Keith
Big Sky Country
Tom E
Tom E's picture
Cool! Worked on a HT35 so didn't have time to work on the head. Back in post #45 I thought the bezel was removable. Does it do well on turbo/max now? Was wondering roughly how much amps. Probably the 219D is very low Vf so the amps can get way higher than with a XPL, but depends on the driver design.
Folomov - please make note, please verify.
Firelight2
Tom E wrote:
Cool! Worked on a HT35 so didn’t have time to work on the head. Back in post #45 I thought the bezel was removable. Does it do well on turbo/max now? Was wondering roughly how much amps. Probably the 219D is very low Vf so the amps can get way higher than with a XPL, but depends on the driver design.
Yes, replacing the 219D with an XPL fixed all problems with the light. It now functions perfectly at max power now on all 18650 cells that I’ve tried, including fully-charged VTC5A.
bilakos10
bilakos10's picture
Do you think that the whole procedure can be accomplished just with a soldering iron and a candle?
I do most of my emitter swaps just by hitting the bottom of the star with a candle as no hot-air station is available to me.
varbos
Last seen: 10 hours 27 min ago
Failomov flashlight with blue tint feature
d_t_a
Last seen: 1 hour 3 min ago
Have you measured the max current that the Folomov 18650S pulls on High mode and on Max Turbo mode?
Tom E
Tom E's picture
Not so easy since the driver is in the tail, so no.
Tom E
Tom E's picture
2nd piece came in and bezel was easy to unscrew - no glue:
Well, the 51 ohm resistor is there - exactly what I measured, so that's how the tail driver gets it's batt+ power. Looks easy to swap the LED, maybe a 351D 4000K 90 CRI.
