OSRAM CSLNM1.TG 1mm, CSLPM1.TG 2mm, CULNM1.TG 1mm
956 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 21 hours ago
For people got confusing about different performance L4P and Djozz got of their tests.
Djozz got best performance at 4.8- 5A while L4P got it at 5.75A.
L4P explained why they got different readings: “Excess solder could cause that when power density is high like with this LED. Also, I’m using lead-free solder which has a little bit better thermal conductivity.”
I did my own re flow and I used very thin layer of solder paste we mostly use here (that cheap budget mechanic solder paste in syringe) and I got similar performance to L4P test.
Yes I also find that confusing but I know that my test subjects Osram white flat performs as in L4P test. And since I am testing it for more than month in fet dd setup I know it is robust emitter that will work without any issue with low current 18650 cell like LGBD1 and that it can even survive abusing with high current cell like Samsung 30Q but I don’t recommend that to anyone. Why would anyone want to run emitter on 7A if it has best performance on 5.5A?
So yes. Barkuti is right. If you want to be worry free get regulated drivers, but if you insist on FET DD be very careful and use low current cell or you could fry something out Smile
Lfatman
Lfatman's picture
Last seen: 1 month 6 days ago
New tests:
52KCd in Godmes T01 (14500)
118KCd in Olight M22 (30Q)
Original driver in both. The main difficulty of this led is propperly focusing. It was impossible to focus the TK61 (600KCd max) and Warsung MX900 (83KCd max)
nottawhackjob
Last seen: 1 week 4 days ago
Luminarium,
FYI. For the record, I’m not trolling anyone here, Jack, nor am I trolling anytime, period.
Other readers didn’t exactly agree with you 1:1 on every single technical point, observation, or at times confusing or contradictory comments you’ve made until you further clarified your comments but that doesn’t mean they obviously don’t understand or didn’t read. That includes me.
Look at your Post #122 as an example. Even you admit there are seemingly confusing elements involved.
All I poised was that can the Osram KW take relatively short bursts from high current cells on highest draw mode without harm if for whatever reason I need/wanted to do so. The point being this led isn’t apparently going to immediately fry with a short or even long burst from a high current cell. Is it optimum? No. Is it recommended by you? No. But again to be clear I don’t disagree with your initial comments about this led performing best with a low current cell. Totally understand.
Congruently I also surmise I can still put a high current cell behind it if I keep it away from operating on essentially turbo mode. But it’s not absolutely essential because it can take the abuse as you said. So it’s really not a safety issue according to you, right? This led apparently isn’t going to melt, fry, or cause a fire with a high current cell, right? It’s really a better performance issue, right? No problem there. I fully understand. Ergo, I’m not trolling.
You see there are times and situations when and where I foresee I may not happen to have a low current cell on me when this led happens to be in an empty light that I need to use for whatever reason.
It’s not going to definitely harm anything according to the long term results of your high current testing other than it’s just not needed for best performance so why do it? Agreed.
And again, fully understood. So am I a troll?
Davie
PS. Am I correct that English is not your first language at Location ‘X’? I guess I have trouble deciphering exactly what you’re saying at times. Maybe moreso the syntax.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
deleted
nottawhackjob
Well you are wrong. Again, I’m not trolling. I kinda suggest you quit going there with that deal. It’s better that you understand you gain nothing by name calling or trying to paint someone negatively so that you try to look superior to others.
Now reread edited post #124 to better understand where I’m coming from.
djozz
djozz's picture
Last seen: 23 min 37 sec ago
Performance discussions about leds used in flashlights, however heated, however annoying, however one seems to not understand the other, are not trolling.
A troll has no opinion, has no conviction, does want to convince someone else, he just wants to mess up. This not going on here.
sb56637
sb56637's picture
Last seen: 9 hours 17 min ago
Well, at any rate, the BLF Rules prohibit fighting, and regardless of a user’s opinion or motives, this is always the best course of action:
BLF Rules wrote:
4. Please avoid fighting. If you or somebody else is losing their calm, please drop the subject.
I’ll lock this thread for now. If there’s something else to add the technical discussion please PM me and I can re-open it after tempers calm down.
sb56637
sb56637's picture
Thread re-opened. To those who participated in the argument that broke out, please go back and delete those posts. Thanks.
Agro
Agro's picture
Last seen: 2 min 55 sec ago
I read the Texas Ace test that showed that a cheap thermal paste is just as good as a top one for flashlight use.
But Osram LEDs are quite vulnerable to bad thermal transfer. I have GD900 and I wonder if it’s worthwhile to invest in something better?
Arctic MX-4 won’t let you down.
Cheap thermal compounds tends to dry very fast.
Very worthwhile to invest cause you don’t want weak link in your modd or build.
The_Driver
The_Driver's picture
Last seen: 1 hour 17 min ago
If you have two copper surfaces, liquid thermal paste is the best way to go (it’s much, much better than any standard paste). Otherwise something like Arctic Silver 5.
The flatness of the surfaces will make the biggest difference though.
Barkuti
Barkuti's picture
Last seen: 13 min 38 sec ago
Agro wrote:
But Osram LEDs are quite vulnerable to bad thermal transfer. I have GD900 and I wonder if it's worthwhile to invest in something better?
In my experience GD900 works rather well and is quite sticky.
Besides GD900 and way price-ier there's GD900-1 and then GD007 …
Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Enderman
Enderman's picture
Last seen: 3 hours 44 min ago
If you want to use liquid metal, conductonaut is the best option.
If you want regular thermal paste, I use MX-4 because it’s one of the best but also has other advantages like being cheap for a large tube, being easy to clean off, having low viscosity, etc.
Other thermal pastes that are good include NT-H1, kryonaut, IC diamond.
Agro
Agro's picture
Thanks for the answers. I may try better GD pastes one day.
Frankly, I forgot that the first light I’m going to try has a brass pill. So I think liquid metal is an option?
Though if I go this way, my pick will be galinstan as it’s way cheaper than the other options.
But for alu this doesn’t work.
GD-900 that I have is only marginally worse than MX-4. Definitely the difference is not worth the investment.
If I were to switch, I would probably go with Gelid GC-Extreme because it:
  • is nearly the top performer
    • which maximizes the improvement over GD900
  • doesn’t have problem with drying
  • is not very thick
  • is alu-safe
It is expensive though.
Enderman
Enderman's picture
All non-liquid-metal thermal pastes are fine on aluminum, never had problems with MX-4 drying out, it’s been in my PC for like 5 years now and temps are the same.
led4power
led4power's picture
Last seen: 17 hours 22 min ago
On he other side, I had/have problems with MX-2, after few months it's completely dry? AS-5 was similar, dry after few months.
mdeni
mdeni's picture
Why do you need such thermal pastes and extremes? This led gets the maximum output at low currents around 4.5A
I can’t wait to get mine!
Agro
Agro's picture
Kryonaut is also known for drying up.
That’s exactly my question. Smile
We can discuss what is better and what is worse. But is the difference going to be 0.1%, 1% or 10% with this LED? Anybody bold enough to make a guess or curious enough to try?
Jerommel
Jerommel's picture
Last seen: 1 week 2 hours ago
Meh, looking at the surface areas of LED board and shelf, this is like 100 times larger than the thermal slug of the LED.
And as long as there’s just a thin layer in between, so preferably with screws or other wise pressed down firmly, it will be fine.
Many tests have shown this.
The drying up seems like the biggest problem though.
Once the grease is dry, it will do a poor job.
So frankly, i think you could maybe better use silicone grease than thermal gunk that will dry up.
Enderman
Enderman's picture
When you cool an LED more it gets its maximum output at higher currents and also outputs more lumens/lux.
Enderman
Enderman's picture
Some quick calcs.
If the 980 lumens peak from Led4Power’s test is accurate we can expect almost 300cd/mm^2 out of this emitter.
https://www.desmos.com/calculator/i4rmwrzyqm
AlexGT
AlexGT's picture
Last seen: 2 days 19 hours ago
I read that conductonaut affects bare aluminum not sure if this would be the best option for an aluminum flashlight.
Look here:
Enderman
Enderman's picture
Yes I know it can’t be used on aluminum.
HONDARIDER
HONDARIDER's picture
Last seen: 1 week 1 day ago
Holy cow, am I impressed with this LED. Just dropped one in a run of the mill Convoy C8. I need to adjust the reflector but this thing came alive. Wow. Just glad you guys are around or I would never have known the possibilities of this LED. Now I need to figure out what to put it in next.
SKV89
Last seen: 3 hours 53 min ago
How about the Maeerxu M8 26650 Usb Rechargeable?
mrheosuper
Last seen: 1 week 11 hours ago
so, anyone has real figure about DD driver and low drain cell( ncr18650B, ncr18650GA, samsung 35e)
i am planning to put it to emisar D1s, what is the throw i can expect? half a mile?
Forgot my pen
HONDARIDER
I actually have one of those. I curious as to who makes a good spacer for this LED. I had to super glue one in place to hold it as close to center on a C8. It’s OK but could be better. Any ideas? Maybe the 3535 spacer modded. Hoping someone makes one.
Barkuti
Barkuti's picture
HONDARIDER wrote:
I actually have one of those. I curious as to who makes a good spacer for this LED. I had to super glue one in place to hold it as close to center on a C8. It's OK but could be better. Any ideas? Maybe the 3535 spacer modded. Hoping someone makes one.
I've been successful in glueing the typical 5050 plastic spacer of a Convoy S2+ around a 3535 emitter over its MCPCB. Just be frugal with the glue and/or clean any remainings around the emitter with an alcohol soaked cotton swab while you retain the spacer properly centered.
gchart
gchart's picture
Last seen: 13 min 15 sec ago
To my knowledge, there’s no spacer available yet. Did you see djozz’s makeshift spacer in the first post? He cut notches in a 3535 spacer to fit the 3030. Not perfect, but might be a better option than glueing.
led4power
led4power's picture
Osram KW CSLPM1.TG (2mm2) is available now:
https://led4power.com/product-category/leds1/osram/
Kills XP-G2 in throw, while having 1500lm+ output, which is great for factory undomed 2mm2 LED with pure white tint. Vf is ridiculously low, 3V@3A,3.13V@5A,3.3V@8,5A.
