CRX Rotary - 6th Annual BLF/ Old Lumens Contest Winner
149 posts / 0 new
chops728
Last seen: 2 hours 30 min ago
MRsDNF wrote:
I’ve no idea how you make such intricate pieces. One day you will make a video. Smile
I’m beginning to think he has some Elves cutting and filing over there—-definitely some Magic Dust—- Big Smile
-X3-
-X3-'s picture
Last seen: 10 hours 3 min ago
Actual picture of CRX :
Now you know his secret Big Smile
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
MtnDon
MtnDon's picture
Last seen: 2 hours 46 min ago
very funny!!!!
BLF Member Map Add your name and location.
CRX
CRX's picture
Last seen: 5 hours 1 min ago
Jerks! LOL
Now a little something for your insolence... Wink
25mm x 22mm grade2 titanium tube arrived today Thumbs Up
I think this is much better than the brass, a lot lighter too.
 Drilled & filed out slots for 6mm x 1.5mm tritium vials.
Roughly showing how the light will look with tritium mode indicators
MtnDon
MtnDon's picture
Thumbs Up
Tally-ho
Tally-ho's picture
Last seen: 1 week 2 hours ago
-X3-
-X3-'s picture
Maaan that’s some great skills and awesome ideas !
I love it !
MRsDNF
MRsDNF's picture
Last seen: 13 hours 34 min ago
What did you use to make the slots?
CRX
CRX's picture
The trits are 6mm x 1.5mm and I only have 2mm or 0.9mm drill bits, (the thought only just occurred to me) so I used the .9mm bits to drill a series of vertical holes in wobbly lines Big Smile , then kinda drilled in from the sides of the holes at an angle moving the drill bits around to break the holes into one another then a diamond cone shaped dremmel bit to enlarge the slots so I could get the small rectangle diamond file in there, still needs tidied up & nothing is fixed in place.
Very excited though, first light I’ve made with titanium Smile
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 hours 34 min ago
You can stop making it better now…. anytime now… It’s already really really awesome.
electricjelly
electricjelly's picture
Last seen: 6 days 9 hours ago
With all the awesome things you’ve made over the years I’m surprised you haven’t played with titanium yet. This first dabble with it is looking very nice already.
CRX
CRX's picture
Just a couple more tricks, promise Innocent
Thanks mate, yeah it is surprising also considering it is my favorite metal. I just never got round to it though I think we can expect more of it now Wink
MRsDNF
MRsDNF's picture
Tedious and time consuming. Orsm work. Beer
CRX
CRX's picture
Yeah, especially when the chuck is too big to even hold the bits...
So a little tip for this is I cut three pieces of 2.5mm copper wire and use them to brace the 0.9mm bit centre in the drill chuck.
Can be a bit fidgety to get them in place but it works Wink
Some more work on the casings today.
Cut, shaped & slotted a 3.5mm machine screw to make a grub screw for fixing the copper pill in place.
Drilled & tapped a 3.5mm hole through the inner cores into to the copper pill, installed grub screw and levelled off.
Drilled & filed another tritium slot into the front section titanium casing.
Marked final positions of the various contact points on the outside of the copper core in red & blue ink.
The thick red line on the very end rotating switch piece shows where the internal sprung brass contact lines up.
The thick blue line on the body shows where the flashlight will be in the off position.
The thick red line on the main body shows where the direct drive/ charging mode connection is.
The way these indicators will work is, when the two green tritium vials are lined up    on the titanium outer shell, the light is in the off position.
When the green indicator on the rotary tail section is turned to line up with the red indicator in the body section    , the light is in direct drive mode, or in charging mode if the head section is then disconnected and the charger port is exposed.
Other than that the tritium indicators let me know where the switch is positioned.
Nothing is fixed in place yet, still got some tidying up to do and fit LED & reflector.
Tritium vials installed in outer casing with UV setting glue & copper bezels in place.
MtnDon
MtnDon's picture
I am running out of superlatives. Wink
Good trick with the “too small” drill bit
mattlward
mattlward's picture
Last seen: 3 hours 28 min ago
Holy crap! You have outdone yourself again. That is beautiful!!!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
CRX
CRX's picture
Getting there. Wink Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 7 hours 46 min ago
Hum…I guess you won’t resist to make a CRX Rotary “family” (as you’ve done with the Stratis Lumina) inside or outside the constest, will you? Evil
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
I wont be making a set or another one of these I don’t think, though the thought did cross mind mind Innocent
This light has turned out to be way more intensive and time consuming to build than I initially thought it would but I have enjoyed making it Smile
And it does already have a similar companion Wink
MRsDNF
MRsDNF's picture
Beer Smile
DavidEF
DavidEF's picture
Last seen: 2 days 8 hours ago
I ran out of words long ago in this build. Now, I just watch as he continues to overwhelmingly amaze me. Shocked
- The YKK Philosophy
FmC
FmC's picture
Last seen: 5 days 11 hours ago
Are we there yet??
Great job Thumbs Up Thumbs Up
CRX
CRX's picture
FmC wrote:
Are we there yet??
Just about Wink
 Installed Cree XP-L HD v6 3D emitter, smooth 20mm x 14mm reflector, 22mm x 2mm ARC glass and light assembled Thumbs Up
MascaratumB
Shocked Shocked Shocked Shocked Shocked
Sweet Blushing
Great work CRX Cool
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
It is nice, thanks mate Beer
I’ll do some pictures when it’s light & maybe make a better video/ GIF.
Jerommel
Jerommel's picture
Last seen: 6 hours 32 min ago
A truly amazing job, CRX. Fabulous result.
My simple build just crashed and burned this evening…
O well..
CRX
CRX's picture
Thanks mate. Sorry to hear that, it’s happened to me many times too but always a learning experience, even if at the most awkward of times.
djozz
djozz's picture
Last seen: 1 hour 3 min ago
That is a fantastic result! Thumbs Up Beer
It is hard to believe that that supernice flashlight in the gif above is completely built with hand tools! Only when you see the complete build thread you realise that.
CRX
CRX's picture
Thanks djozz, yeah if you look close you can even see the hand tools latest inprint on my left thumb (hacksaw) LOL
skinny_tie
skinny_tie's picture
Last seen: 47 min 49 sec ago
CRX your builds are always amazing but I think this one take it to a new level. I admire your creativity, skill, and especially your patience.
