DARKSIDE | NYMPH (10440 twisty Fet+1 flashlight w/ 4k 9050 219C)
150 posts / 0 new
nick779
nick779's picture
Last seen: 12 hours 7 min ago
DB Custom wrote:
Soft start is easier on the electronics and emitter as well as being easier on our eyes. Turbo or level 6 can do 700 lumens on a fresh cell, it will sort of ease into that brightness instead of slamming full brightness, hence soft start. At about 30 seconds it will gently ramp down to protect the light ftom getting too hot. You have to keep in mind this entire light is about the size of your pinky finger and the cell is AAA sized.
Bistro uses a soft start when cycling through the modes, most appreciate it, some don’t particularly care for it. Makes a lot of sense in a light this size for sure.
Yeah, these little 10mm shirt button sized drivers are fun to build! Sick
After re-reading my post it was a bit confusing, I was asking about the 8+ turns mode.
Hoop
Hoop's picture
Last seen: 2 min 41 sec ago
The turbo starts slowly ramping down after more like 5 seconds and ends up at mode 5 level after 20 seconds or so. Lumens measurements are usually taken at the 30 second mark. Instead of giving run time measurement from a continuous run, which would not be much different than mode 5 run time in that case, I ran the turbo multiple times for a total of 30 seconds each time. You can cycle the turbo 8+ times this way before lvp. There’s probably a better way to word it.
nick779
nick779's picture
OH, so its the “number of cycles/runtime” equivalent for the turbo mode.
Does it take another 6 turns from mode 5, or just 1 to jump back to turbo?
Hoop
Hoop's picture
Just 1 turn and it’ll do the turbo blast again but only if you let it go 20 seconds first.
It’s probably going to end up with thermal regulation rather than a timer though thanks to switching to a more capable mcu.
nick779
nick779's picture
Sounds good, im good with either flavor though, I just want this to be a success!
Is there a glass lens to protect the TIR or has the bare TIR been resilient enough ?
mattlward
mattlward's picture
Last seen: 10 hours 59 min ago
I do not see any glass in mine, but I have carried it a bunch loose in my pocket and have not scratched up the TIR. PMMA TIR’s seem to be very tough! Olight has been running the bare for years and most of mine are still in very good condition.
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Zebralight SC62w
Olight S1A
Olight S1R
DB Custom
DB Custom's picture
Last seen: 3 hours 56 min ago
As a plus, the opening at the bezel is so small that most coins and such can’t enter the bezel to scratch the optic. Wink
nick779
nick779's picture
Very true.
From Kickstarter:
Quote:
Each light is individually calibrated for voltage accuracy
I thought this was a nice touch
ToyKeeper
ToyKeeper's picture
Last seen: 25 min 2 sec ago
There’s actually an entire robot set up for that. It tests the voltage sensor on each individual driver, modifies the firmware, and flashes customized code to each driver. It’s pretty fancy.
ToyKeeper
ToyKeeper's picture
The thermal algorithm in Crescendo should work reasonably well on this, though it doesn’t have the smooth adjustments of Anduril. Anduril’s algorithm is smooth but still needs some fixes before I’d trust it on such a small light. I suppose I should just bite the bullet one of these days and rewrite the whole thing.
nick779
nick779's picture
Aw, no pics? Thats such a tease. Might be better left as a secret.
Id like to see a nymph raw or clear anodized, curious how that would shine.
Well, were almost halfway there, still have a ways to go though. I might be upping my contribution if not doubling my order depending on how things go.
ToyKeeper
ToyKeeper's picture
I haven’t seen it either. I only heard about it.
I figured the normal method would be used — manually measure a dozen drivers or so, take an average, and use the same values on each. But I guess there’s an automated rig set up to flash the battcheck firmware, run it at specific voltages, count the blinks, compile the real firmware with those values, and then flash it again for real.
nick779
nick779's picture
Well, were halfway there with 10 days left. Im hoping for the best as this project has really grown on me.
Might actually double my backing depending on how things go.
Fate0n3
Last seen: 1 week 4 days ago
This is an awesome light, hope to see it for sale soon not on kickstarter. After being burnt by the Znaps and another kickstgarter project that never came through I don’t waste money on kickstarter anymore!!! It is a wonderful looking light and looks like you have put quite a bit of effort into it!!
Acebeam X70 – BLF GT70 – BLF Q8 – Acebeam X80GT – Acebeam X45 – Astrolux MF01 – Noctigon Meteor M43 – Thrunite TN36 Limited – Emisar D4S – Emisar D4 – Lumintop GT Mini – Olight S10 Baton – Olight SMINI Baton Ti – Mateminco X6S – Mateminco S03
ToyKeeper
ToyKeeper's picture
If this were some random guy on Kickstarter, I’d be wary too. But it’s not. This is Hoop, not some anon who just wants to take the money and never deliver anything. If the money is transferred, he’ll deliver the items. The R&D is already done, with working items already out in people’s hands. Some Kickstarter projects are pretty high-risk, but that’s not the case here.
DavidEF
DavidEF's picture
Last seen: 2 hours 4 min ago
If I had the money, I’d pay off the other half of the Kickstarter myself. This light is worth being manifest. Sorry I’m poor. Tired
- The YKK Philosophy
contactcr
Last seen: 5 hours 1 min ago
You have successfully backed DARKSIDE | NYMPH
Thetasigma
Last seen: 1 month 1 week ago
I’m in, this thing needs to be brought to life.
slowtechstef
slowtechstef's picture
Last seen: 1 day 9 hours ago
Hoop: interesting Kickstarter project Thumbs Up
I hope you succeed, and joined as a backer as well.
nick779
nick779's picture
Well guys, were down to the last ~48 hours. $5900/9000.
Im still optimistic, hopefully there will be a surge to push it over. We will see.
DB Custom
DB Custom's picture
I just don’t understand how this level of work get’s overlooked, I find it amazing and virtually intoxicating, can’t resist.
Still hoping for the best… best of luck Hoop! Smile
MascaratumB
MascaratumB's picture
Last seen: 24 min 47 sec ago
This light is a great punch, indeed!!!
I wish it can be produced on the KS project and eventually later if all goes well for Hoop and the project itself! I cannot commit to this at the moment as I have another thing I want to buy and money won’t stretch in Christmas time!
If it is available somewhere in tome next year after the KS project, I will probably try it! It would be my first 10440 Big Smile
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
GIVEAWAY - 1
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 3 min ago
Probably because of the only cell compatible with the light being a low capacity 10440 cell.
I know I would not buy the light anyway because of my tight hobby budget not allowing buying these sorts of lights, but had it been an AA sized light with compatibility for 14500s, I think more people would be interested in it.
I still wish Hoop best of lucks!
contactcr
I think the recommended Efest cell is fine assuming you get a good one. It probably would help to support 1.5V batteries (I backed it anyways) but that changes everything about the driver. 14500 is already saturated with decent boost lights and 10180 is an even worse cell than 10440 and still manages to remain usable with 1/3 the capacity of this cell. In short, 14500 brings nothing to the table except bulk.
BlueSwordM
Yeah, but I’m too used to the huge capacity that 18650s offer, and the convenience of using regular NiMH AAAs/AAs.
I think the light looks amazing, and probably is.
But honestly though, it’s just not my type of light.
nick779
nick779's picture
Idk, Ive been looking for a “better” 14500 light that keeps a thin profile with a nice deep carry clip. I havent found much of anything in that segment that I like either.
Either way, I like to collect what I can of things made “by hand” by an artisan. All the custom 18XXX lights are way out of my budget and I probably wouldnt carry them anyway because of width and especially the cost. Hoops product is something that is definitely a work of art, but perfectly EDC-able. No other lights ive come across incorporate a FET+1 driver let alone vias for updates.
Im game for a 10440 twisty as well as a 14500 clicky if it even approaches how the Nymph is built.
DB Custom
DB Custom's picture
Ah, but see, therein lies the rub… Hoop is a young man taking a walk out onto the limb with this relatively small and simple project, if it doesn’t get backed to fruition who knows what he may have had up his sleeves? Makes it a lot more difficult to get the bigger projects going if the entry project doesn’t take off… and I for one really want to see what else Hoop has in mind! Big Smile
mattlward
mattlward's picture
Dale, that is my thought as well. I have a feeling that Brian has some very good ideas running around in his head and needs the nudge to make them happen!
EDC rotation:
Zebralight SC52w-L2
Zebralight SC62w
Olight S1A
Olight S1R
ToyKeeper
ToyKeeper's picture
I made a quick post in one of the facebook groups to remind people this is about to end. Hopefully it’ll reach its funding goal so things can move forward.
Agro
Agro's picture
Last seen: 2 min 40 sec ago
I think it’s one of the more interesting lights lately. Combination of capabilities and size is way above the competition unless we’re talking about several times more expensive customs. Even in the unlimited-budget class it would hold its own.
Then add nice looks, CRI 90….I can’t see a single weakness which happens…well…I can’t remember any previous case. Myself I would make some decisions differently, but I can’t say they would make the light genuinely better.
It’s one of those almost-superb-for-me lights. Not useful as it is but a small design change would make it superb. So I didn’t sign up. But I really with Hoop success because the job is so outstanding….
