Cofly 14500 zoomie modding thread (many pictures)
15 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 20 min ago
Pilotdog68 showed by starting the " what did you mod today" thread almost 3 years ago that modding was not dead on BLF but very much alive. That thread made me post more mods than I did before because a whole new thread was not needed now, many mods were not worth more than a quick post with one or a few pics and this thread is perfect for that. But since then I also do not post many comprehensive mod threads anymore, the WDYMT thread made me a bit lazy. So to compensate somewhat for that here's a very complete mod thread once more. I chose a cheap under 10 dollar zoomie that unfortunately is not for sale anymore, unfortunately because the build quality is not bad and it has a nice 21mm diameter (plastic) lens that makes for some decent throw considering the small size of the flashlight.
In this post I show many ways-methods-gear-parts that I picked up on BLF or developed myself, but in no way what I do here is how it should be done, there's many ways to do stuff and other modders have their own methods and specialities. But perhaps it does help people to see how someone else does things.
Apart from the specific materials used for this mod and can be seen in the pictures of the mod, here's some stuff that I use all the time:
Some of the things in the photo: reamer, metal-grade countersink tool, heat block, round iron block with very flat upper surface (used as sanding base to flatten things), diamond files, tweezers, toothpicks, aluminium vice (alu=nice&grippy), test XM-L2, Nikon eyepiece used as a loupe, 63/37 rosin core solder wire, 63/37 solder paste, small cutting pliers, piece of a projection lens (=used in front of phonecamera to make macro-pictures), +4 reading glasses for close-up work, helping hands for soldering, led tester modded with clicky switch (instead of stock momentary switch), clamp meter, calliper.
Not in picture: 25W Antex solder iron, 80W Antex solder iron, several power suppplies, disc sander, small model band saw, small drill press, numerous drawer storage cabinets with bits and parts, cardboard boxes, and more stuff among which a couple of flashlights wink
Oh, and I forgot this very often used thing, my 20x-80x Olympus zooming stereo microscope. To check things, to work through for tiny mods, and for making very detailed macro-pictures.
The mod.
I have several copies of this Cofly zoomie, and thusfar the best one has a dedomed XP-G2 S3 3D and a BLF X5/X6 bistro driver. I re-measured the light (@30 seconds with purple Efest14500) and it produces 54 kcd (same as the famous Jacob A60 laughing). With the new Osram "White Flat" 1mm-die thrower led I hope to make a version that throws even better Smile
This zoomie has a hollow pill and although normally when using a copper DTP-board that is no problem for the heat path, with this led at close to 5 amps some extra measures are needed, I decided on a little chunk of copper under the ledboard.
The ledboard
After sanding with disc sander and by hand with sand paper, and driling holes for the led wires:
Solder paste was added (yes, I use too much solder paste for the led!)
stacked
the stack was soldered together on my heat block, making sure that the copper chunk was centered well under the ledboard (info on the heat block here: http://budgetlightforum.com/node/52886 )
Excess solder on the underside was sanded and filed away
The assembly fitted tightly in the pill, but only in one orientation (pill=not perfectly round apparentlyundecided) I marked the working orientation with a sharpie.
the pill was loaded with Arctic Alumina Adhesive (5 minutes curing time)
glued in, pushing hard onto the board during the curing of the adhesive to make as much as possible direct metal-metal contact
I tested with the led-tester if all worked without unwanted shorts to the pill. cool
The driver.
I decided on a BLF-A6 FET+7135 driver, but leave enough resitance in the flashlight to not overdrive the (very low voltage!) Osram KW CSLNM1-TG led. The BLF-A6 driver is a 17mm driver and can not be sanded down to 15mm for this flashlight, but WarhawkAWG a few years ago had made a 15mm version of wight's FET+7135 driver (Oshpark link) that works well with the components unsoldered from the A6 driver, except the FET is too large and should be replaced by a smaller LFPAK33-package FET (bought from Mountain Electronics some years back).
solder paste was applied on the new board.
The yellow BLF-A6 board was put on the hotplate and the components one by one transferred to the 15mm board (except the FET, that came new).
The reflow, accompanied by my talented son sealed who is learning himself how to wistle
result
it works with my test-led
The pill has no driver retaining ring, and being aluminium, can not be soldered to. So the driver needs to be press-fit. I have my method to make the driver pressed in and at the same time provide good ground ring contact with the pill. First some notches were filed in the side of the driver and  pieces of thin (nickle-plated) copper wire were stuck inside a via and bended around the side of the driver to the battery side (top of the wire-pieces were filed flat a bit)
the wires were soldered in on both sides
and the result was filed in shape so that the component side of the wire pieces was kept very flat, and the side was sticking out a bit to clamp in the driver cavity of the pill.
The driver just before pressing it in with my orange vice
pressed in tight, will not go anywhere, spring added, and spring bypass soldered (22 AWG wire). Later I have removed the bypass because I found the current too high
I forgot to add a bleeder resistor to the driver (the flashlight will have a lighted tail), so I drilled a shallow hole (dia2,5mm) on the battery side and crossed the ground ring and batt+ pad with a 680 Ohm resistor.
I tested the finished pill with the led tester (a led tester will power the driver enough to make the user interface work) and all was working
The tail
I do not trust the stock switch very much at high current, and also I wanted to do a lighted tail. So the stock tail on the right must go, and it must become one like the one on the left. The height seems about correct.
But the switch assembly like on the left needs a retaining ring and there is none for this specific flashlight. So I made a retaining ring out of the original switch. First I pushed the switch out of the aluminium holder. Then a pieces containing the threading was cut off with the band saw (a hack saw would have worked just as well).
The cut-off piece was sanded flat with sand paper (on the flat iron block) then the inside that was way too narrow was reamed a lot with a hand-reamer. For grip on the piece during reaming, it was screwed into the tail-section of the flashlight that was held firm in the hand with a piece of rubber inner tire. The inner edges were bevelled with a countersink tool.
result
An Oshpark tailboard by pilotdog68 (link later) was used for soldering the switch (Omten 1288) and spring. I always pre-tin everything, then fuse with the solder iron. In case of the switch I solder very fast, to prevent melting the inside of the switch and kill it. Also, the spring is soldered first before doing the switch, so that the heat from the spring soldering can not kill the switch.
I used a 6-led ring board for the tail leds, made by Lexel. it has pads for two potmeters on the back, but I simply soldered fixed resistors there (2x 8.4 kOhm). The leds are ice-blue 0603 leds. If 10 minutes of your life watching soldering is not too boring tongue-out, off you go:
ok, it worked but it was not particularly nice solderingsealed
so I did it up a bit after the video
I had a few tail leds fail over time and I think it helps if the soldering is good.
Two very short copper connection wires were soldered in the ring-board and soldered to the switch-leads. tested with the led-tester, it works Smile
all screwed in
Assembly
The light was assembled, and before closing the lens, the top and inside of the pill was blackened with a black marker, while being careful not to touch the die undecided
Although the new ledboard is thicker than stock, the focus of the beam in spot modus was correct, so no lens height adjustments were needed.
Finished
performance
I had chosen the bleeder resistor value and tail resistor values well so the user interface was not messed up (I chose the BLF-A6 driver and not the X5/X6 driver because it is less critical about that).
I measured output without tail with a clamp meter and got over 6 amps. With the flashlight on the highest setting the light was clearly getting a bit blue. Even with the extra resistance of the tail the current was too much, so I removed the spring bypass on the driver. Then there was no blue shift of the tint anymore.
The output zoomed out on a purple Efest 14500 is 400 lumen, zoomed in 170 lumen.
The throw with the driver spring bypass still in place was 68 kcd (measured at 30 seconds on a full battery), with the bypass removed it was still 65 kcd and I reckon the current is now just under 4 amps with the battery full. Much better for this small light, but still it gets hot pretty fast, the build-in stepdown of the BLF-A6 driver after 40 seconds is much needed (and adequate).
The beam is plain white (unlike beams of dedomed XP-G2's) and zoomed in very very square . You can see vaguely the die pattern, especially on low modes.
(left Cofly zoomie with dedomed XP-G2 S3 3D (well over 4 amps), right Cofly zoomie with KW CSLNM1-TG led (just under 4 amps)
conclusion
I'm really happy with this version, the throw is again a bit better than with a dedomed XP-G2. The new led is not at its maximum performance, perhaps I should have soldered it more critical, but also in this host there is not a great heat path. Nevertheless I think this is quite the thrower for its size Smile
I hope this post with the many pictures and video's was fun to read. I may still edit it here and there in the coming days, or add even more pics.
Edited by: djozz on 11/02/2018 - 03:27
MascaratumB
MascaratumB's picture
Last seen: 24 min 25 sec ago
Thanks djozz, for the detail and inspiration Blushing
This is a true step by step on modding something from a normal flashlight into an awesome one Wink
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
nottawhackjob
Last seen: 1 day 4 hours ago
Outstanding. A lot of pics sez more than a thousand words. A lot more. This is the Gold Standard for a fairly complex mod. This is the way it should be done.
Great detail, great skillz, and IMO great for BLF period.
CoolBeer
“In many things in order to truly understand the small picture you have to understand the big picture first.”
djozz
djozz's picture
Thank you, it is quite awesome indeed, and usually I only find out how good these lights are that we make much later when I actually take it outside on a trip somewhere (I’m a city person).
CoolBeer
Thanks a lot, but I hope that my shaky hands are not considered as a golden standard. I do not think that way I do things are the standard way, other modders have other ways, but I do try to pay attention to details. When I started modding my main concern was a working flashlight. My earlier mods often failed after a while because of sloppy work.
nottawhackjob
What I meant here is not necessarily that your methods of modding are a Gold Standard but how you explain what you’re doing through the use of great pics and precise verbal detail so that it’s very clear from novice to pro what, why, and how you did it.
That is the Gold Standard IMO. CoolThumbs Up
CRX
CRX's picture
Last seen: 1 hour 11 min ago
Nice write up & job Thumbs Up
Boaz
Boaz's picture
Last seen: 1 day 11 hours ago
When can I expect my new light ?
Super nice budget light mod
                                  https://www.gty.org/
    Interested in Diffuser film …  http://budgetlightforum.com/node/42208
MRsDNF
MRsDNF's picture
Last seen: 1 day 21 hours ago
A working flashlight is always a good thing when modding. Smile
Nice write up on a nice mod. Thanks as always djozz. Beer
hank
hank's picture
Last seen: 1 hour 47 min ago
Bravo!
I put amber emitters in several of these a few years ago with great success.
But now I feel challenged to improve them further.
Is the Cofly 14500 model still for sale anywhere nowadays?
EDIT: https://www.dx.com/p/cofly-kx-h10-cree-xp-e-r2-160lm-3-mode-white-zoomin...
DealeXtreme
COFLY KX-H10 160lm 3-Mode White Zooming Flashlight w/ Cree XP-E R2 – Black + Red (1 x AA / 14500)
I think I bought their three-for-about-$6-apiece deal, after searching for the product name various other places.
Kame Sennin
Kame Sennin's picture
Last seen: 2 hours 9 min ago
Very nice mod and photo story but (don't want to sound  negative) your driver and tail leds solders look like you'd better use less solder and less heat ... tbh for most components you might have better results with a good iron Smile
djozz
djozz's picture
Kame Sennin wrote:
Very nice mod and photo story but (don’t want to sound  negative) your driver and tail leds solders look like you’d better use less solder and less heat … tbh for most components you might have better results with a good iron Smile
Thanks! Smile
Yes, my soldering is not brilliant (but it is adequate for what I do). I need better solder paste too, this stuff leaves a sticky gooey around the solder blob.
Edit: you make me think: I use the 25W solder iron for most things nowadays (and a 80W one for brutal stuff), but I do still have my old 18W iron around in a box, I should keep that one at hand too for fine stuff.
djozz
djozz's picture
hank wrote:
Bravo!
DealeXtreme
It is out of stock at dx, as it is everywhere.
A quite different flashlight but with the same lens is the Ultrafire UF-10. CRX got comparable numbers with this led in a (severely modded) UF-10: http://budgetlightforum.com/comment/1404881#comment-1404881
Gea2427
Last seen: 4 months 1 week ago
Awesome write up!!
Got any beam shots of this bad boy?
djozz
djozz's picture
Gea2427 wrote:
Awesome write up!!
You are right of course, I will try some!
MascaratumB
djozz, is there any possibility to show this light zoomed in to see the distance it reaches (more or less, of course) in external environment?
I don’t know this led but I am thinking about modding a zoomie with Led4Power LD-A4 3A driver (eventually 4A? Or would it be too much for a 16340 cell?) and wanted to check if it is much better than a XPL-HI 1A led in terms of beam and throw/distance!!
Any clue on these options is also much appreciated!!
Thank you in advance Thumbs Up
 MY GIVEAWAY (FW3A)
