Jerommel's Hand Job 2018 - 6th annual BLF / Old Lumen Scratch Made Light Contest
74 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 week 6 hours ago
Hi all,
2nd time i entry this yearly contest.
Main goal: Finishing a working light. Party
Previous attempt (2014) kind of failed due to running out of time, so i thought i’d keep it straight and simple.
So here are the parts:
It’s gonna be a copper 20700 triple with Osram Oslon Square high CRI warm white with a lovely tint and a bunch of real red.
These LEDs are no power houses, so i’ll run them on 1 Ampere each, using a 3 Ampere FET CC driver.
It will be USB rechargeable too.
I’ll use Kaidomain LED board and optics.
Little Omten reverse clicky side switch.
Basically the light wil be built on / around the 20700 battery, which will not be removable.
…at least, not easily…
Trying to make it as compact as possible.
2Q19
Edited by: Jerommel on 11/01/2018 - 22:27
raccoon city
raccoon city's picture
Last seen: 13 hours 31 min ago
You gotta be careful with those Handy J's...
You don't want to end up like CRX:
crx
Jerommel
Jerommel's picture
So i started this afternoon, it is now 3:28 AM here..
Pictures!
Without the wrapper it nearly slides in the tube, if both were perfectly round, which they’re not…
The Osrams are 3030 LEDs, which had to be reflowed onto the triple 3535 board.
Took some time, effort and cusses to get them all positioned decent enough.
Need a shelf for the LED board to sit on inside the tube.
20 × 20 × 1.5 mm heat spreader to make the shelf.
Must be soldered in place.
Needs holes for wires and 2 tiny screws.
Can you see the damage on the business end of the tube?
I dropped it on the concrete floor… Facepalm
I’ll address it later. Maybe need some extra ring around there to make it a little more impact resistant..
Time to do the electrical bits.
These charger boards are quite okay.
I won’t need the protection circuit though.
battery connections.
Cut down board goes on top.
Epoxied, soldered, works !
Switch gets glued to bottom of driver.
And that gets glued on top of the charger board.
Tested and working. Thumbs Up
More epoxy for strength.
CONTINUED HERE
2Q19
DavidEF
DavidEF's picture
Last seen: 4 hours 18 min ago
Well, you did say it would be compact… Shocked
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 min 43 sec ago
Looks good mate!
Why take the wrapper of? why not just use a 18650?
pinkpanda3310
pinkpanda3310's picture
Last seen: 7 hours 43 min ago
Great start Star looking good Thumbs Up
Agro
Last seen: 16 hours 9 sec ago
Interesting!
Jerommel
Jerommel's picture
everydaysurvivalgear wrote:
Looks good mate!
Well, i bought 2 of those 20700’s almost a year ago now, but i haven’t got anything to use them in..
And then i found that, with a little persuasion, it can fit inside a 22mm diameter copper pipe when you remove the wrapper.
Triple board and optic also fit snugly in this size tube.
2Q19
FmC
FmC's picture
Last seen: 3 days 8 hours ago
Great start to your build Thumbs Up
I have a couple of those charging circuits for my build – Interesting to see how you cut them down like that.
CRX
CRX's picture
Last seen: 21 min 59 sec ago
Cool Thumbs Up
Flashy Mike
Flashy Mike's picture
Last seen: 7 hours 20 min ago
Looks interesting! Pretty compact indeed.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 1 min ago
Nice Wink
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
djozz
djozz's picture
Last seen: 4 hours 26 min ago
Very nice with a couple of cool new concepts! Thumbs UpThumbs Up
Jerommel
Jerommel's picture
Thanks for the encouraging comments!
I could have used the Convoy S9 e-switch driver with USB charging port, but i didn’t like the idea of parasitic drain, so i used a reverse clicky set up in stead.
This takes up more space though, and it will be a bit more of a challenge to sort out the switch button.
And that will be the next part of the build:
Holes for the USB port, charging LED light and switch button.
Also have to widen the copper tube a tad to get the assembly in without too much force.
Lining the lot up properly will be a bit of a challenge too..
2Q19
MtnDon
MtnDon's picture
Last seen: 2 hours 48 min ago
Very cool, very nice, Jerommel. Thumbs Up
gchart
gchart's picture
Last seen: 46 min 25 sec ago
Looking great, Jerommel! Very cool setup so far, I like how you’ve got everything stacked tight and epoxied in place (JB Weld?). Interesting how you’ve trimmed down the charging circuit. Are the eliminated bits just for over/under voltage protection?
djozz
djozz's picture
The battery does not have its vent holes anymore btw, whatever the implication is of that.
DavidEF
DavidEF's picture
Pipe Bomb! Evil
-Ayn Rand
Jerommel
Jerommel's picture
Yeah, maybe i’ll send it to some globalists.. Big SmileParty
But it’s true, it’s gonna have a harder time venting.
I decided it was not that important.
2Q19
Geuzzz
Geuzzz's picture
Last seen: 7 hours 3 min ago
Nice work Jeroen. Looking forward seeing the end result.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 11 min ago
Big SmileThumbs Up
KB1428 “Live Life WOT”
Jerommel
Jerommel's picture
Well, let’s hope not that it will end like that.. ^
I will update this evening / night with pics.
Had a bit of a set back, but that’s what you get when you build hastily and without proper planning up front..
2Q19
Jerommel
Jerommel's picture
Me too ! Beer
2Q19
Jerommel
Jerommel's picture
Pics from yesterday and today with (quite a lot of) text:
So, the copper tube was too narrow to get the battery in, or rather, to get it out again.
I originally planned to hammer the tube over the internal assembly (battery, charger PCB, switch and driver), but this didn’t seem wise, so after looking for anything to ream the tube out, this was the only thing i could use:
Subtle tool..
This SDS drill is just over 20mm across the chisel point, and i used some household scrubbing fluid along with it.
This did the job, but the outside of the tube got a little wider too, and not evenly, so…
…the outside had to be sanded back to (near) perfection.
Drilled the switch button hole too.
Also drastically enlarged the centre hole in the shelf, because…
…this is how close the driver board will be to the shelf, so i needed to make some room for the slightly thick wires (22 AWG)…
This doesn’t look beneficial for the thermal path from LED’s to the shelf, but i figured it would still be good enough.
The LEDs are mounted on a DTP copper LED board, and although it’s a thin LED board, i think it will still conduct the heat pretty well to the shelf.
…but i did enlarge that hole more than necessary…
O well..
Switch button hole.
The tube is not 1 mm too long, as it turns out…
Not yet sure how to finish the tail.
Size comparison with 2 compact 18650 lights:
(Yes, the DQG is empty..)
_______________
_______________
And then, i noticed some problems in my plan…
It was the lack of a plan, i guess..
The USB port sat pretty deep, so it could only be charged with a long micro USB plug, and then it still didn’t go in far enough to snap in place..
The charging indicator LEDs didn’t line up nicely either with the side (at 90° of the USB port / switch.
Conclusion: the charger board should move a little towards the wall of the tube to solve these things.
But i used epoxy… No way i can move it..
Additionally, trying some switch boots, the switch was sitting a bit deeper than i would have liked.
And another problem with the switch itself occurred !?
Probably too much heat when soldering, but it had some problems every 8 clicks (full rotation of the inner parts every 8 clicks, or, i think it’s 8, could be 12 too..)
It could be traces of super glue too that crept in too..
Injecting WD40 with a syringe did help, and possibly it will improve further with use.
SOLUTION:
I have plenty of those charging boards (ordered 10 of them at the time).
I have another 20700.
I have a bunch of small Omtens.
I have another LD25 driver.
…so i make another assembly… Facepalm
That’s a lot better.
It cost me a PCB trace though (that’s why the 1st attempt ended up so deep), so i had to lead the + to the indicator LEDs with a wire (yellow).
The switch has to be glued on top of the the charger IC again, but both go more towards the outside.
Need something on the back of the switch to glue it to the charger IC.
A bit of cotton from a cotton tip swab drenched with super glue will do.
Driver on top etcetera, and compared to the first assembly:
Goals met for now.
Bit of a waste of parts on the first assembly though..
No idea what to do with it or the parts it consists of..
All epoxied…
O well, who cares. Beer
CONTINUED HERE
2Q19
MtnDon
MtnDon's picture
That is Prototype #1. Wink Seeing far enough ahead to avoid all part fitment issues can be quite difficult, especially when working with such a compact size. Good going though!!
FmC
FmC's picture
Nice progress. Part of the fun is overcoming issues that pop up, when building by the seat of your pants OopsBeer
gchart
gchart's picture
Whew, that stinks (having to rebuild). But at least there was time to do so and you had the parts around. Other than the waste of parts, building a prototype certainly helps you figure out how not to do things! Big Smile
DavidEF
DavidEF's picture
Is it the top of the 20700 cell casing that stops the USB plug from being inserted all the way, or the opening in the copper tube? If it’s the latter, then maybe the first build isn’t completely hopeless. You could make your contest light using build number two, to get the best results, but still continue to make number one into a less-than-perfect version with a larger opening for the charge port and a small metal or plastic extension for the button on the switch that’s too far back.
-Ayn Rand
Jerommel
Jerommel's picture
Yeah, the copper pipe is in the way with #1
The mechanical electrical problem with the switch kinda sucks too..
We’ll see. Smile
2Q19
NeutralFan
NeutralFan's picture
Looking good Jerommel! Keep up the good work. Thumbs Up
I’d rather use my flashlight around the house than turn on the lights.
RotorHead64
RotorHead64's picture
Last seen: 1 month 6 days ago
Nice work!
