How trustworthy are Sofirn batteries?
147 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 5 min 31 sec ago
JasonWW wrote:
Funtastic, have you measured any Of the “better” 26650 cells like Liitokala cyan or black or maybe the Keeppower 6000/Shockli 5500? (I like the Aspire 4300) I’m curious how it would compare to the Sofirn cells on your test equipment. A real apples to apples comparison.
Unfortunately I haven’t got any other 26650’s that would compare.
I compared my 30Q 10A curve to Mooch’s and it’s exactly the same.
Texas Ace Lumen Tube calibrated with maukka lights
d_t_a
Last seen: 18 min 12 sec ago
These are my own observations of a few Sofirn batteries:
Sofirn "5500mAh" 26650:
- there are at least 2 types (bought them bundled with Sofirn flashlights, at different times).
- their wrapping are similar, but the top look slightly different (will upload pictures next time)
- I used SkyRC MC3000 to charge to 4.20v, then run a discharge at 1.0A discharge current, down to 2.50v cut-off voltage:
- 1) Sofirn 26650 with a somewhat "raised flat-top" has these result:
- around 50mOhms (MC3000 DC IR reading), and capacity test yields around 5300-5400mAh capacity (MC3000 1A discharge current from 4.20v to 2.50v)
- using the YR1030 battery resistance tester will give around 42mOhms AC IR
- testing on some high-drain flashlights and measuring the tailcap current, gives lower current than many of my various 26650 cells, indicating this is like a lower-drain battery
- 2) Sofirn 26650 with a more "flat" flat-top has these test result:
- around 30mOhms (MC3000 DC IR reading), and capacity test gets around 5000mAh capacity (MC3000 1A discharge current from 4.20v to 2.50v)
- using YR1030 battery resistance tester will give around 14mOhms AC IR (very good - better than many of my various 26650 cells, indicating this seems to be a high-drain cell, maybe not as high-drain as the Golisi or iJoy 26650, but quite good, possibily matching or better than the Lii-50A 26650)
- testing on some high-drain flashlights and measuring the tailcap current, gives higher or similar current reading compared to my other 26650 cells
- I failed to note which of the Sofirn "5500mAh" 26650 are from earlier batch or later batch, because I got them both fairly recently (like a few months ago, and I only did more in-depth comparison capacity test recently)
(the one I refer to as "raised flat-top" 26650 is the right-most 26650.
(the one I refer to as "flatter flat-top" 26650 is the second from the right 26650.
(the left-most 26650 is the so-called Sofirn HD 26650 -- I haven't done much testing on it yet)
(the second-from the left 26650 is another Sofirn 26650, also similar low IR as the "flatter flat-top" Sofirn 26650; I haven't finished testing it yet)
Sofirn 3000mAh button-top 18650:
- again, there are at least 2 types of this 18650 (possibly more); again I can only purchase Sofirn batteries when bundled with Sofirn flashlights
- I think the earlier batch has the lower capacity test reading, while the later batch gives a higher capacity test reading.
- physically, the 2 types look the practically exactly the same, I only noted they had to be different due to the YR1030 AC IR reading being different -- the YR1030 battery resistance tester generally gives very consistent readings
(button-top have some contact resistance, and my MC3000 gives inconsistent reading, so I have to keep on reseating them a few times and get the lower relatively consistent IR reading for my "test")
1) "older" Sofirn button-top "3000mAh" 18650:
  - YR1030 battery resistance tester gives AC IR reading of around 24mOhms AC IR
 - MC3000 DC IR reading is around 50+ to 70+ mOhms (again button-top now has some "issues" with my MC3000 slider...)
 - capacity test (0.50A discharge current from 4.20v to 2.50v), gets around 2700-2800mAh capacity reading
 - I wonder what actual battery is used (maybe it's the "pink" battery mentioned elsewhere in this thread?)
2) "newer" Sofirn button-top "3000mAh" 18650:
- using YR1030 battery resistance test, the readings are around 31-32mOhms AC IR
- MC3000 DC IR reading is around 70-90mOhms DC IR (again, button-top batteries give somewhat erratic reading on my heavily used MC3000, since the slider spring on my MC3000 is quite loose now...)
- capacity test (using 0.50A discharge current, from 4.20v to 2.50v), I get capacity test reading of around 3000-3100mAh capacity.
- though I didn't try tearing off the wrapper yet, I believe this is quite similar to the white DLG(H) 3200mAh battery (I have gotten the flat-top white DLG(H) 3200mAh 18650 from a local source and these have very closely related AC IR reading and capacity test reading), as these also give similar capacity test reading
Funtastic
Funtastic's picture
Thanks for your detailed write up.
If you look on an angle at the 18650 cells you should see what colour the OEM wrap is on the negative end.
I received the 5500mAh cells with the very recent purchase of my Sofirn SP33’s and they have a flat top that only just makes contact in series. I’d guess this would be the 2nd 26650 you tested. I’m yet to do a 1A (0.2C) capacity test as they take awhile to complete.
RapidLux
RapidLux's picture
Last seen: 7 hours 48 min ago
JasonWW wrote:
Maybe they buy in bulk from some lesser name provider
This thread is about Sofirn.
Funtastic
Funtastic's picture
That’s real mature. Jason’s comment is 100% relevant to this thread
RapidLux
RapidLux's picture
It was a joke for Jason, as he responded that way to my post suggesting exactly those batteries.
JasonWW
JasonWW's picture
Last seen: 15 min 6 sec ago
You suggested buying those batteries as if someone where asking what battery to buy. This thread is about Sofirn cells specifically.
I’m suggesting a comparison of the Sofirn cells to those other batteries. I want to have a frame of reference. See how they stack up against each other. This will reveal more info about the Sofirn cells.
HONDARIDER
HONDARIDER's picture
Last seen: 1 week 4 days ago
I just took the wrapping off of 2 2800 MAH Sofirn 18650 batteries and what would lead you to believe is a protection circuit is just an extension. No circuitry at all. They did register 2637 and 2619 mah for the 2 cells. IR was pretty respectful at 23 and 25. Think it was in the 50’s or 60’s with the fake circuit added. Not sure if they are claimed to be that way or not (Protected). Got these out of the headlamp (D25S) I believe. They seem to be a good battery after all. I did leave the button on them. So the IR may actually be lower if it were removed. Not sure though. I wanted to keep it on.
pennzy
pennzy's picture
Last seen: 8 hours 52 min ago
Today I had a 2800 mah Sofirn18650 with protection circuit stop working. It was never used much, just stored in a locked out S2+ in the car. Waiting in the car, I tried to turn it on and nothing. Took it home and peeled off the protection circuit and seems to be fine. Mine did have a real protection circuit on the negative end. It looks very similar to a 30Q but has no markings and a larger positive terminal.
HONDARIDER
Mine just had a plastic spacer with a metal cap. The cap had a metal strip which leads to the positive end of the battery. Wish I had kept them to show pics. In the end after rewrapping it, seems to be a very good battery. Was it one of the blue and silver versions?
pennzy
pennzy's picture
No, it was a black one. Mine just came off the charger and is ok. Did yours have a black plastic spacer then the metal cap on the negative end? The reason I ask is that inside that black plastic spacer was a circuit.
d_t_a
Earlier (as in maybe last year or a bit more than that), Sofirn sometimes bundled 2800mAh protected 18650s instead of their 3000mAh unprotected 18650s.
I have a couple of these Sofirn 2800mAh protected 18650s, and I did get around 2700-2800mAh capacity reading (using MC3000, discharge from 4.20v to 2.50v at 0.50A discharge current). The protection circuit appeared to trip at around 6 Amps. (testing this protected 2800mAh 18650 on the Astrolux S41 with quad-Nichia, will trip/shut-off when advancing the brightness to Turbo mode).
I’m not sure if they changed the 2800mAh since that time though. (I seem to recall they included the protected 2800mAh on the Sofirn SP32A v1, at least during the early batch..)
JasonWW
JasonWW's picture
You can’t really go by looks. It will say on the wrapper if it’s got a protection circuit. If there is no mention, you have to assume it’s not protected.
Funtastic
Funtastic's picture
I’m thinking the added button top on the 26650 HD cells are adding a lot of resistance. I wonder if Sofirn tested the cell before adding the BT.
I’ve just tested a different variant of the Sofirn 26650 and it beats the HD cell at 10A & 15A. I haven’t yet tested higher current
Chakthi
2100 wrote:
ChrisGarrett wrote:
Where do you live? Is buying cells made by the Big 5: Sony, Panasonic, Sanyo, LG and Samsung, such a financial hardship for you, wherever you live, that you'd take some no name brand over them? Things can't be that bad, can they? To confess, I just bought my first TrustFire cells from FastTech, but they're the newish red/gold 16340s that Henrik has tested on his site, so I felt better going in. Generally two issues--the first being a safety issue and the *second just being one of longevity*. Most anything will work for a few dozen cycles. Chris
I have about 10+ Trustfire flame batteries still working, from year 2010/2011. Smile I use them for my lasers, XP-Gs and XM-Ls. They need to be legit Trustfure cells though.
Is there really anything "legit" about a Trustfire battery?  The only cells that I trust that aren't LG, Samsung, Sanyo, Sony, or Panasonic are AW IMR 18350 cells and, of course, those too have to be legit, because there are a lot of fakes floating around out there.  As a matter of fact, there are more fakes than genuine AWs.  My experience with Trustfire has been that they're all crap cells.  With lithium cells, I truly believe that you get what you pay for applies...
Funtastic
Funtastic's picture
I’ve had a few Trustfire 14500’s for about 3 years and they still have a genuine capacity of 800mAh. I wouldn’t trust them though
JasonWW
JasonWW's picture
Chakthi wrote:
2100 wrote:
ChrisGarrett wrote:
Where do you live? Is buying cells made by the Big 5: Sony, Panasonic, Sanyo, LG and Samsung, such a financial hardship for you, wherever you live, that you’d take some no name brand over them? Things can’t be that bad, can they? To confess, I just bought my first TrustFire cells from FastTech, but they’re the newish red/gold 16340s that Henrik has tested on his site, so I felt better going in. Generally two issues—the first being a safety issue and the second just being one of longevity. Most anything will work for a few dozen cycles. Chris
Is there really anything “legit” about a Trustfire battery?  The only cells that I trust that aren’t LG, Samsung, Sanyo, Sony, or Panasonic are AW IMR 18350 cells and, of course, those too have to be legit, because there are a lot of fakes floating around out there.  As a matter of fact, there are more fakes than genuine AWs.  My experience with Trustfire has been that they’re all crap cells.  With lithium cells, I truly believe that you get what you pay for applies…
Any brand battery can be faked since it’s basically a wrapper that identifies it. More than just the brand of battery, you also have to buy from trusted sources. Shops that don’t buy fakes and verify that they receive the genuine article.
It’s unfortunate that the Big 5 you mention don’t make 18350, 14500, 26650, etc… This means your forced to buy from a smaller company, but there are still good quality cells out there.
If you look at some common USA battery stores like MTN, Illumn, IMR Battery, Liion Wholesale, you’ll see that none of them carry Trustfire (afaik). About the only exception I can think of is if a particular Trustfire cell is tested and it actually performs pretty good as in it has about the rated capacity, etc… Then that shop might carry it. It probably will never be the best choice in it’s size, though.
Funtastic
Funtastic's picture
Sanyo do have a 14500 which is the UR14500P. I’ve seen a Sony 14500 but can’t recall the name
JasonWW
JasonWW's picture
That is a good start.
You also have to watch out for fake versions. I think there was a Sony 26650 on the market a few years ago, but it was not actually from them.
smithmal
Last seen: 6 months 1 week ago
What are some legit sites to get decent deals on AW IMR 18650 batteries?
Funtastic
Funtastic's picture
This is a thread for Sofirn batteries.
Moleyman69
Hi,
Does anyone have any comments regarding the Sofirn High Drain 21700 Battery 4800mah 48A cells? Do we know who makes the cell under the wrapper?
Thinking of picking up 6 tomorrow (11.11) if they are any good.
Want to use them in Astrolux EC01, Sofirn C8G and a C8F lights and wondered if they are up to the job of driving these lights to their maximum? If not, can anyone recommend which high-capacity 21700 cells to buy?
Many thanks,
Moley
Funtastic
Funtastic's picture
I know that the 4000mAh 21700 cells are very decent but no idea about the 4800.
Generally high capacity cells can’t handle high current. There’s the Samsung INR21700-50E 5000mAh and it can only run continuous at 9.8A.
For the C8G you might be okay but not the C8F. You ideally need low resistance and the least amount of voltage sag on load for the most lumens.
Moleyman69
Thank you for taking the time to reply, Funtastic – especially on a weekend; I appreciate it!
For the lights I mentioned, would I be better off with the original Sofirn 21700 4000mAh then? Or, what about Sony VTC6 with a 21700 adapter sleeve as I have lots of VTC6s? Obviously, the capacity would be way down with the VTC6 but what about sheer lumen output with the Sonys Smile
Thanks again,
Moley
JasonWW
JasonWW's picture
Moleyman69 wrote:
Hi,
The 4800mah one is strange one. Some people measure 3700-3800mah, while others measure 4800-5000mah. You can read about it starting here.
BTW, you may not want to drive the C8F to the maximum simply because it builds heat quicker and gives you less turbo runtime. I think you’d be okay using a high capacity battery so as to limit turbo output. If you really want to max it out, try a high drain.
The cells under the wrapper are local chinese brands and usually kept secret.
Probably the highest quality, highest performing cells are the ones from LG, Panasonic/Sanyo, Sony/Murata, Samsung and Molicel.
Funtastic
Funtastic's picture
Thanks again,
Moley
You’d be better off with the Sofirn 4000mAh 21700 for the Sofirn lights.
The real lumen rating of the Sofirn’s are
C8G – 1700
C8F – 2850 to 2950
The C8F draws up to 10A on Turbo. The EC01 draws up to 15A so I have no idea what the Sofirn 21700 can achieve as no one has reported tests on more demanding lights.
I’d recommend something like the Samsung 40T for best performance of the EC01.
