Vapcell INR20700 3000mAh (Purple) 2018
Official specifications:
Model: INR20700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2850Ah (0.2C discharge)
Weight: Max:60g
Internal resistance: Max:12mOhm
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
A high current cell in the new 20700 format.
The discharge curves tracks fairly well and the cells can handle 30A nicely.
But they do get warm at 30A
Conclusion
These cells are at the low end of capacity for 20700 cells, but instead they have a fairly good high current performance.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
