LiitoKala Engineer Lii-500 D E A D
8 posts / 0 new
timbo114
timbo114's picture
Last seen: 40 min ago
My LiitoKala Engineer Lii-500 LCD screen has just died after only 7 total charge cycles of 18650 cells.
When I plug in the power cord, the screen blinks once and dies.
Anyone else have this issue?
atbglenn
atbglenn's picture
Last seen: 9 hours 2 min ago
Mine has been reliable for over 2 years now. Defects do happen with any brand.
gisewhcs
Last seen: 39 min 20 sec ago
Defective, or to small designed (amperage wise) PSU?
If you have another suitable PSU, this would be my first thought.
2 DOGS
Last seen: 8 hours 49 min ago
My first Lii-500 only charges to about 3.95v.
Tom Top was absolutely no help, I left a 1 star review and ordered another one from a different vendor.
My second one works fine. Question
d_t_a
Last seen: 1 hour 25 min ago
Most likely the power adapter. The Lii-500 charger unit is very likely still OK.
Try getting a 12v power adapter to test (eg. those from wifi routers, external hard drive, that have a power adapter labeled DC12v), but don’t use them to charge, just to test if your Lii-500 will still power up.
Reason I mentioned this is that I’ve encountered a Lii-500 from someone else who let me check his unit. His Lii-500 was not functioning. Tested a good power adapter on his Lii-500 and it worked, so it must be his power adapter that developed the problem. When I tested the voltage of the power adapter, I notice the voltage is fluctuating, something like 10v-16v, I’m not sure how to fix the power adapter but advised him to get a new power adapter and I think that worked..
2100
Or you can measure whether there is any voltage output from the power adapter.
atbglenn
atbglenn's picture
BTW, mine came without a power supply. I use my own self-built 5 amp unit. Works great.
Here it is with an afterthought with 4 charger ports on top. It’s a prototype. I’m going to make one with all the ports in the same box in the near future. I have all the parts ready along with a new 15 amp PS module. I just need to get off my butt and build it.
timbo114
timbo114's picture
I’ve tested the power supply/adapter on 3 other chargers … no issues there.
And tried 3 other power supplies on the Liito …. dead Liito.
  • This isn’t my 1st issue with a charger.
    My Opus BT-C3100 has been operating with a dead slot #3 for 2 years now.
