Miboxer C4-Plus Released on Amazon, BLF members enjoy 30%
Miboxer New model C4-Plus is available on Amazon.de now.
Miboxer Das neue Modell C4-Plus ist ab sofort bei Amazon.de erhältlich.
The features:
  1. 4 slots with large LCD screen can charge different type batteries together;
  2. Max output current: for Li-ion batteries:(2.5A*2/2A*3 /1.5A*4)for Ni-MH/Ni-Cd: 1A*4 MAX
  3. The slot length up to 78mm, can charge 20700/21700 battery with protect board.
  4. Manaul current setting range:Li-ion(4.20V / 4.35V):
    (0.1A / 0.2A / 0.3A / 0.5A / 0.8A /
    1.0A / 1.2A / 1.5A / 2.0A / 2.5A /
    Default current )
    Ni-MH / Ni-Cd:
    (0.1A / 0.2A / 0.3A / 0.4A / 0.5A /
    0.6A / 0.7A / 0.8A / 0.9A / 1.0A)
  5. Can set up the battery type(only effective for li-ion batteries)and charging current of 4 slots through one time,this function only effective for the slots with batteries;
  6. Automatically stop charging when fully charged;
  7. With the LifePO4 memory funtion.
Coupon Code:4OGKP4KN
Purchase link:
Amazon.de
The code not working for US AMAZON! Do you have code for US Amazon.com?? I’ve been waiting C4-PLUS for a while.
That looks like a great charger.
The fact that it’s available in EU for a reasonable price is also a huge plus.
6 hours later, there will have an promotion activity of C4-plus on follow links https://www.amazon.com/dp/B07JB3RZLS
Code was fine, thank you :wink: :beer:
Thanks, I really appreciate it!
I have a c4-12. What is differnt/better about this one? Also will this link automatically apply the discount?
The C4-12 is not (yet) capable to handle protected 20700/21700 batteries. MiBoxer has extended the length of those charging bays on the C4 and C4+. FWIW, I assume the (new) C4+ can handle 4x 26650 while the (new) C4 cannot.
So, your C4-12 is still up to date apart from the length of the charging bays. ;-)
I just got it today and it says it will accept 21700’s and it looks to be large enough to handle 4 26650’s. This thing is huge compared to my lii 500. I guess a protected cell could be close (21700). I just measured it and the length of the bay is 76mm.
Is it possible to list this on the Australian Amazon website? Australians are not able to buy from US or any other Amazon countries. Maybe official Aliexpress store with the same discount code?
If you have AU adapter, you can still purchase from our Amazon.de, some customers from you country also have purchased from our Amazon shop.
The other place without this discount code.
Due to new tax laws, Australians cannot buy from ANY Amazon online websites, does not matter which country. You should list it on Aliexpress. Australians can buy from there because they charge the GST, you will sell a lot, big market.
Thank you. Order placed with coupon.
Do you have any plans to release a charger with micro USB for INPUT?
the charger works internally with a higher voltage like 12V as the C4-12
5V USB cant handle the power consumtion this one has
What I really would appreciate would be a proper USB type C input with 12V coding and cable
newer USB with high voltage supplies can support often 25-40W up to 15V which should work
Maybe you can find an adapter USB to 12V plus or make one
Yea I realize this charger is unable to but I already have high power USB hubs so I prefer chargers which I dont have to worry about power supply and cable. Just plug in to any port on my 5-6 slot USB hub.
USB C with power delivery spec or otherwise would be much better I agree but I think maybe one or none exist so far by any brand.
yes chargers have not USB C output, but the higher voltage and like 2.4A should be possible one side USB A and other type C to deliver enough power for this charger
even its not that powerful than the C4-12 it does not have the brick of external PSU which I do not like on the C4-12 and C2-6000 model
at least Dual input like Nitecore has for an external 12-15V PSU would be nice so it can be used in a car
The C4 Plus can also handle LiFePO4 cells as well as Li-Ion 4.35V cells.
Ordered, Amazon.de Thank you for the code Miboxer :+1:
Ordered from Germany but do you plan to sell it on Amazon UK?
