Astrolux MF04 vs Astrolux MF04s ?
54 posts / 0 new
Coman
Last seen: 3 weeks 2 days ago
MF04
44% (16 votes)
MF04S
56% (20 votes)
Total votes: 36
Coman
Hello.
I want to buy a flashlight.
A friend has an Olight thrower that sees a 1km (xpl-hi 1100lm). I have a thorfrie s70s that sees 600m, sees much stronger but I would like to see it more distant than his. It has a very concentrated beam of light. The stronger light is on me, but she does not see that far.
What do you recommend me to choose? Both are $ 175.
I am very indecisive. I want to have a strong point of light but have many lumens. On youtube I saw that MF04S has a light point but it’s wider, I do not know how concentrated it is to the one with xhp35.
Excuse my weak English.
Thank you. Big Smile
Coman
Please argue. Any advice helps me. Thank you. Thumbs Up
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 33 min ago
The one with the XHP35HI is extremely concentrated, and can throw extremely far, 2km+ in perfect conditions.
The XHP70.2 version still throws extremely far, but less than the XHP35HI version.
However, due to the sheer power of the light, it still does throw far, but in a wider range, making it more impressive in general.
They are still both superior
to the Olight thrower.
I would go with the NW XHP35HI version however just because it throws farther still, has a better beam, and can still be used for very good throw at low levels.
Coman
Why NW ? I prefer CW (6000-6500k) Smile
Others opinion ? Thumbs Up Thank you !
Brainsick67
Brainsick67's picture
Last seen: 17 hours 31 min ago
MF04 throws farther but less lumens, MF04S still throws far, but more Lumens.
I'm ThatCrazyFlashaholic 67
Coman
Yes, I know Smile But I do not know what to choose.
Brainsick67
Thats how you choose more throw, or less throw? More light, or less light, personally i like MF04S better.
BlueSwordM
NW is better since it is less prone to light refraction in the air, meaning it will throw farther and will have better detail at long distances.
Using CW, it will wash out the targets more, meaning you will see them less.
AlexGT
AlexGT's picture
Last seen: 10 hours 31 min ago
Do you prefer a laser like beam or a bigger hotspot, do you want to see what is around the target you are pointing at or just the target?
If you prefer a laser like beam that throws really far go with XHP 35 if you like a bigger hotspot that still goes far (not as far as XHP35) but you can also see everything in the path of the beam towards the target, then get XHP 70
What is going to be the intended use for the light?
Re-reading your post, seems to me that you want a FAR thrower that throws farther than your friend’s Wink , then I would suggest you go with the XHP35
Coman
So for a longer distance, NW would have recommended.
BlueSwordM
Yes, that is it.
Coman
They want to see at a distance and wide. I do not really know how the differences will be. My friend’s SR52-UT Olight has a very focused point, he sees much stronger than my Thorphire. I think Olight has 1100lm and it’s ok, and MF04 is 2700lm, so he’ll see even stronger and much bigger distance.
AlexGT
AlexGT's picture
Seeing that you already have a XHP-70 led flashlight in that Thorfire, then get a XHP-35 so get the MF04 in neutral white to reach farther, or if you want to see the laser like beam in the air then the cool white would be best, what tint beam does your friend has? do you like the way his beam looks?
nokoff
nokoff's picture
Last seen: 5 hours 39 min ago
Sounds like you got yourself in lot a longest d/(& contest.
If you buy the MF04S now and they then buy the MF04 to beat you, how would you feel then?
With either choice, they can always say you bought a torch the size of a toaster oven just to beat them, how would you feel then?
If you’re indecisive it’s cuz you know you don’t really want or need either. Put the same exact money into a Reylight TI LAN Winter Frost with 16 trits and you can take that mofo anywhere and it’ll make your buddy jealous too. Win win.
Nokoff..still Made in China 山寨主義
Coman
Olight have 5500k (not CW not NW) Big Smile
NW it’s better for long distance ? But i like CW (i prefer white-blue), but I would choose what is stronger on a larger distance (NW). Smile
Coman
@nokooff: Yes, It’s kind of a championship. I want to be better as my friends Smile
AgentWhiteBread
Last seen: 1 week 13 hours ago
I have both the MF04 and the MF04s, MF04 all of the way. The hotspot just isn’t large enough at a distance to make a huge difference (for me) and I appreciate the more concentrated beam. On top of that it uses less power so you have longer run time, and it takes longer to heat up so you can comfortably run it on turbo even longer.
Really though it depends on the distances you plan on using it. At close distances 1000 feet, the increased beam intensity means the target will end up brighter with the MF04 anyways so while the MF04S will have a bigger hotspot, it won’t be illuminated as brightly.
adam7027
Last seen: 5 hours 45 min ago
If throw is at biggest priority, I think MF04 is better, because it uses significantly less power for the same throw distance.
XHP70.2 is not the best, because for a good throw, it uses too much power, so the flashlight host gets hot in a relatively short time, then the driver will step back, and thus, throw will be reduced as well with the output.
For people, who want more light output, but still great throw, XHP50.2 could be considered as well.
Regarding color temperature, a neutral white around 4000K will throw much better over longer distances, as violet/blue/cyan/green light gets scattered significantly more in the air, than yellow/orange/red (based on a few physics facts). So the NW flashlight will actually illuminate the target better, instead of making a ‘laser beam’.
I think, for long distance throwers, high CRI 3500K or 3000K CCT emitters could be even better (for me, the sweet spot could be at 3500K).
EDIT: as DB Custom says, I told falsely, that NW/WW emitters will throw better. NW/WW emitters have usually slightly lower performance bin. I still think/experience, that perceived contrast can be noticeably better, when air conditions are suboptimal.
HONDARIDER
HONDARIDER's picture
Last seen: 2 hours 28 min ago
I will tell you I have both. I like both but the MS04S was awesome. Given the distance the human eye can actually make out an object is less than what these lights are capable of. The MF04S would be the one I would pick (Personal preference/opinion). A neutral white will not wash out the objects as much either. You will not be disappointed with whichever you choose.
Brainsick67
Agreeed..
wstrachan
Last seen: 3 days 6 hours ago
I have both versions in Cool White and both are very impressive. If you want specialized throw, the XHP35 is awesome. If you want great throw with awesome output and generally just a wider area lit up at range, get the 04S.
Of course this is important: The 04 in XHP35 lasts much longer on Turbo and the other run times as well.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
DB Custom
DB Custom's picture
Last seen: 1 hour 26 min ago
It is argued that the Warm White is better for less diffraction in humidity, I personally do not follow that argument as I have photographed lights hitting subjects at almost 2 miles and the Cool White light worked better even in a light rain. I even had my wife run the two lights and I traveled closer to the subject, took the photo’s from a few hundred yards away and off the line of light… the Cool White visibly put more light on the target. In spite of a light rain. So I know from personal experience that the folks shouting hurrah’s for the warmer tints are just opinionated. Smile
Cool White makes more lumens, throws farther, glad to have resolved that debate for you. Big Smile
Carry on.
Edit: Oh, yeah, you probably want to see for yourself… The lights were 1.9 miles from this tower, shining in from my left about 60-70 yds away from me (the beam line was that far to my left) I was about 300 yds from the water tower taking these pictures.
justanotherguy
Last seen: 1 hour 55 min ago
these are a …bit throwier than the GT/GT70..?
anyone in NE ILLinois into get togethers?
Brainsick67
YES…they have to be, as the reflector is bigger and deeper then BLF GT..
Brainsick67
BOMBAY
Last seen: 6 hours 17 min ago
It’s strange that mf04 has a larger hotspot and gives more range
Newlumen
Newlumen's picture
Last seen: 1 day 8 hours ago
I would go with mf04.. mf04s xhp70.2 have a bit green tint.
As a matter of fact, my mf04s died.. i think its the driver, carrier, or led.. all of them..
adam7027
Carry on.
The photographs you show for comparison were made during a clear night (there are stars in the sky background of the picture). If same models were used for comparison just with emitter CCT differences, these photos are truly convincing for clear sky/air conditions.
However, you could show photographs showing these beams hitting targets through light to moderate fog as well.
My personal experience, that when I use flashlights in mist/light to moderate fog, cooler CCT flashlights are casting a more disturbing beam into the air, making unnecessary glare, and reducing perceived contrast at the illuminated target.
Probably I need to experience with this topic for myself more, but I do find warmer tints useful in those cases. (I edited/corrected my previous post)
Carry on.
With maximum respect to your knowledge and experience, I feel these above a little bit offensive and unnecessarily arrogant.
nokoff
nokoff's picture
Pretty sure he was just using hyperbole and speaking anecdotally there. It’s common for people in the states to have an acerbic, satirical, sarcastic wit however they usually mean nothing offensive by it. Just see it for what it is.
Newlumen
Newlumen's picture
klrman wrote:
Newlumen wrote:
I would go with mf04.. mf04s xhp70.2 have a bit green tint. As a matter of fact, my mf04s died.. i think its the driver, carrier, or led.. all of them..
Did BG help with a replacement?
I havent email yet.. i sent two email about my broken imalent ms12.. ( with the video proof ). i never got any email…
I am sending email to banggood about the mf04s now.
