I found these available locally. They are mounted on a similar PCB as the ones used with the CFT 90. They are used in moving head stage lights. The specs on the stage lights only list them as a 60 watt emitter.
I would like to find out what it is and if possible, drive current and voltage requirements.
Oh well was worth a shot. To my knowledge Luminus does’t have anything else with comparable surface brightness so it’s probably not worth the effort then.
