Test/review of Power supply frontend DPH5005-USB 50V/5A with Bluetooth and USB interface
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 6 min ago
DSC_2615
This device is the front end for a power supply, it must be supplied with low voltage DC power (Up to 50V).
Official specifications:
  • Input voltage range: 6.00-50.00V
  • Output voltage range: 0V-50.00V
  • Output current: 0-5.00A
  • Output power range: 0-250W
  • Product Weight: about 222g
  • Display module size: 79*43*38(mm) (L*W*H)
  • Cutout size: 71mm*39mm
  • Power module size: 93*71*41(mm) (L*W*H)
  • Length of connecting line: 200mm
  • Fixed hole center distance: 86mm, 64mm
  • Output voltage resolution: 0.01V
  • Output current resolution: 0.001A
  • Output Voltage accuracy: ± (0.5% + 2 digit)
  • Output Current accuracy: ± (0.5% + 3 digits)
  • Max allowable input current: 10A
  • Output ripple: 100mVpp
I got it from aliexpress store: RD official store
DSC_2580 DSC_2582
DSC_2581
DSC_2583
DSC_2584
It arrived in a styrofoam box together with some other stuff, inside the box was the plastic box with the electronic.
DSC_2586
There is a control unit, a power unit, two flat cables, the usb interface, the Bluetooth interface, cable for usb/bluetooth and a manual in English and Chinese.
DSC_2605
The control unit has a display, four buttons and a encoded that can be pressed.
The V and A buttons will enable adjustment of voltage and current with the encoder, press the encoder to select digit, when finished press V or A again.
Holding down V/A/SET will recall a preset, with V and A it is preset 1 and 2, with SET any of the 9 presets can be selected.
DSC_2740DSC_2741
Display while off and on, set point is shown at the top of the screen and input voltage at the bottom.
DSC_2742DSC_2743
On the settings screen it is possible to define a couple of parameters: Voltage, current, over voltage, over current, over power, display brightness. The “over” settings will turn output off if they are reached.
The device has 9 preset memories. To save a preset adjust the parameters, move the marker to M0, adjust the encoded to desired preset number and hold down the SET button.
DSC_2744
There is a hidden communication menu, hold down the “V” button while powering on the supply to activate it (Default is fine for most applications).
DSC_2603 DSC_2604
The front panel is made to be pushed into a rectangular cut-out
DSC_2747DSC_2748
The two flat cables from the power unit is connected at the back.
DSC_2749
The Bluetooth and USB modules are small circuit boards and a wire to connect one of them (It is only possible to connect either Bluetooth or USB module to the power module).
DSC_2588
Wires connected, ready to test.
Measurements
I did a huge amount of test on this unit and will only show a few of the charts here, I have posted more in another article.
Load%20sweep%206V%20out%204V
Running at low input and output voltage, the output looks stable and the fan starts at 3.5A.
Load%20sweep%206V%20out%209V
Increasing both input and output voltage, this time the fan starts earlier, probably due to a temperature sensor. The power lost in the unit is higher, but efficiency is better.
Load%20sweep%208V%20out%2050V
Input voltage is too low for maximum output, due to limit on input current and the supply stops at 50V 2A, this also means about 20W is wasted as heat.
Load%20sweep%2024V%20out%2050V
With 24V input it can maintain 50V 5A output, there is still 17.5W heat.
Load%20sweep%2050V%20out%2050V
And with 50V input the heat is down to about 10W.
Voltage%20sweep%200.1A%20out%204V%20input%20current
With very low output current and voltage it can maintain output voltage down to about 6V input.
Voltage%20sweep%200.1A%20out%2050V%20input%20current
High output voltage is also possible with low input voltage.
Voltage%20sweep%205A%20out%204V%20input%20current
With this low output voltage it can easily maintain output at 5A with any input voltage.
Voltage%20sweep%203A%20out%2050V%20input%20current
It can handle 3A output with down to about 11V input, but this is a bit outside specifications, they say maximum input current is 10A and for that 16V input is needed. Output is stable until it cuts out.
Voltage%20sweep%205A%20out%2050V%20input%20current
To maintain full output current at 50V it needs about 22V input.
No%20load%20voltage%20sweep%20out%204V
No%20load%20voltage%20sweep%20out%2050V
Current consumption depends on select output voltage and input voltage, but it is fairly low, even though it has to drive the display and the converts. With high output voltage it will use a bit more current to maintain the voltage.
Voltage%20sweep%20current%20out%200.1A
The power supply will go into constant current mode when overloaded, here I shorted the output and measured the current at 0.1A (The noise is probably due to the current resolution on my power supply).
Voltage%20sweep%20current%20out%205.1A
Here as a 5.1A constant current generator.
PowerOn50V5V0A1
When power is connected a small transient occurs on the output.
OutputOn25V50V0A
The output turns on without any spikes.
OutputOn25V50A5A
When loaded the output are slower to turn on and there will be some noise.
LoadOn25V50V5A
Changing the load from 0A to 5A shows a significant temporary voltage drops.
LoadOff25V50V5A
Changing the current from 5A to 0A do not show any voltage spikes.
Noise25V5V0A
Noise25V5V5A
Both at low and high current there is some noise from the switcher on the output.
Spectrum50V35V5A
The switcher is running at about 53kHz.
Load%20test%205.0A%20out%2050V
It was no problem running at full output power for one hour.
After about 45 minutes I took the temperature photos below.
Temp6036
M1: 69.3°C, HS1: 87.5°C
Temp6037
M1: 64.7°C, M2: 60.9°C, HS1: 77.1°C
InputMeterOutputMeterCurrentMeter
The display is precise and there is very little change with load.
Specifications says the unit can be used as a charger, lets take a look at that:
Output%20voltage%20sweep%20output%20off
Power supply has input power, but output is off. A battery will be discharged with about 2.5mA, this is acceptable.
Output%20voltage%20sweep%20charging
Power supply is supplying 5V output, if the battery voltage is higher than the selected voltage it will drain the battery, again with about 2.5mA.
The charge current is not shown in this chart, it is below the 0 line.
Output%20voltage%20sweep%20not%20powered
Power supply do not have input power, it will drain the battery with less than 1mA.
All in all it looks fine for charging.
Android application
  • Application will show an ad for another RD product when started.
  • Application is not on Google.
  • RD uses a file download service that opens ads in minimized windows.
  • Protocol is documented.
Screenshot_20181008-133930s
The application is basically one screen. To connect use the Bluetooth symbol, in my case I could not see the power supply and had to use the normal Android discover dialog (I did use “Scan for devices), after that it worked perfectly.
Screenshot_20181008-134024s Screenshot_20181008-134713s
Here I am connected and can adjust voltage and current.
Screenshot_20181008-134257s
The wheel is used to adjust voltage and current with, but only two digits at a time. Touch the U_SET/I_SET and digits to select what two digits to adjust.
Screenshot_20181008-134054s
The control panel is locked while using the phone and it is not possible to unlock it. I would have preferred that at least on/off worked.
Screenshot_20181008-134129s
There is not many languages in the current version of the application.
DPH5005
Using the file folder will save a Excel file on the phone with a fixed name, i.e. it is only possible to save one log.
PC application
  • Application is a 230MB download
  • Inside the archive is installation files
  • Application is very slow to install if it has to install the National Instruments part.
  • The screen is a fixed size (1062 × 619 pixels), there is no resize options.
1s
The package uses a National Instruments library, this is large and slow to install. This installation will not install the supplied font, it has to be installed manually. The letters are a bit to large without that font.
2s
Program started, but not connected yet.
3s
When connected the actual values and curves are added. The dials can be changed with a mouse or new values can be typed in the numeric fields.
4s
The advanced tab where the presets can be configured and 3 types of automatic sequences can be defined and used.
5s
Here I have configured and started a “Voltage scan”.
6s
This can be viewed on the chart screen.
Scan0-45V
And here with a oscilloscope.
A closer look at the electronic
DSC_2592
This side of the circuit board is only soldering, screws and some standoffs.
DSC_2589
All electronic is on this side. At the input is a 20A smd fuse (F3) and a high power mosfet (Q5). The buck switcher is a TL594. The microcontroller is a 32F100. The board do also have a internal switching power supply (U03: XL7005A) and some linear regulators. The output also has a 20A fuse (F1).
DSC_2591
The boost regulator (U3: LTC1871) is on a small circuit board
DSC_2593
DSC_2594 DSC_2596
DSC_2595
Front panel
DSC_2606
The front panel uses four clips to keep the circuit board in the box.
DSC_2607
DSC_2608
DSC_2609
DSC_2610 DSC_2611
The circuit board has mechanical switches, a encoded and the display.
DSC_2613
DSC_2614
There is nothing hidden under the display.
USB module
DSC_2597
The usb module uses a CH340 chip and two optocouplers.
DSC_2598
DSC_2599
Bluetooth module
DSC_2600
The Bluetooth module is a Bluetooth module and a led.
DSC_2601
DSC_2602
Conclusion
This module can deliver output voltage both below and above the input voltage, this makes is very flexible for input supply, but it need some power to deliver full output. The noise is a bit high and it has problem maintaining output voltage when load increase fast. The PC option may not be very nice looking, but it has some interesting functions on the advanced tab and I like the protocol is documented. The phone app has a very nice graphing and logging function, but adjustment of voltage and current is not that good.
This module is very useful to build a cheap bench power supply with. Add a cheap switching power supply, a box (RD sells one), some binding posts and some work.
Compared to professional units it is missing a lot: Lower noise, both numeric keypad and encoded, 4 terminal connections, larger display. But for the price it is very good and works fine.
Notes
The power supply was supplied by RD for review.
Other RD supplies I have reviewed:
Power supply frontend DPS5020-USB 50V/20A with Bluetooth and USB interface
Power supply frontend DPH3205 32V/5A with buck/boost converter
Power supply frontend DPS5015 50V/15A
