Well…its 25 degrees here .i went out…after 45mim a turned on the light, it kept steeping down in 5 sec from Turbo,everything was correct with the batteries…got home…then work after 15min after i got home…then i left it outside for 25min…brought back in…it did the same.so it seems it doesnt like the cold…this shouldnt happen with this light…
On that driver the heat sensor is inside the Atmel microcontroller. Mayba that controller’s sensing part can be faulty too. Try to blink out temperature when light cold and making the problem and blink out temp when it works fine. Maybe this give some clue.
Narsil can tell you the temperature what the driver thinks it is measuring. If it give you a high number when cold then it measuring badly. Triple click from Off then it blinks battery voltage. And make a doubble click from battery check. Then it blinks out temperature in celsius. First tens then singles. Count led blinks. 24 looks like 2 blinks pause and 4 blinks bigger pause and repeat.
That is 35C or 53 if you read the two numbers wrong order which is about human body temperature. Do you feel lightly warm or the light was completely cold? Or 53C if you read the two numbers wrong order but that feels hot What it blinks out inside when warming up?
