Solder question?
73 posts / 0 new
Funner
Solder question?
I bought a soldering iron that came with wire from Walmart. Good enough for soldering wire to a star?
Or do I need to have special soldering wire? Thanks
Edited by: Funner on 11/19/2018 - 13:44
duramax
Last seen: 4 days 11 hours ago
Personally, I like to have solder with lead in my tool kit. it just flows better when I work with it as an advanced hobbyist (still learning).
The Walmart solder is lead-free, I presume?
It should be workable for what you are trying to do.
moderator007
moderator007's picture
Last seen: 1 hour 45 min ago
How many watts was the iron? What is the make up of the solder?
I used a 30 watt pencil style iron for years, Its doable but they are reasonable better tools for cheap now.
It depends on how much soldering you plan to do. If its a quite a bit, then step on up in the 30 to $50 range and gets something that makes life easier on you and will make you feel like a pro at soldering. There’s several threads on this site about soldering, try the search feature on the top left of this page.
Its a combination of the quality of the tool and the skill of the user. A skilled solderer can make good connections with a cheap iron or A novice can make good connections with a high quality soldering station.
With these newer copper type boards it takes a lot more heat than the older aluminum type. So general speaking around 50 watts or more is needed to work with the copper. Using lots of good flux will help with a low powered iron.
neBstress
neBstress's picture
Last seen: 4 hours 36 min ago
You want some 60/40 Tin/Lead Rosin (flux) Core Solder.
As duramax mentioned, solder with lead in flows better and at lower temperature, it is much easier to work with and gives better results.
JasonWW
JasonWW's picture
Last seen: 3 min 31 sec ago
Do you have a link or picture of what you bought?
Funner
Hangzhou Greatstar Industrial Co. Model: 5133 30w.
Walmart like $5.
I did one mod with it, I used up half the wire and burnt up half the soldering tip.
Not sure on the wire it came with, somewhere in the stuff.
I will do a mod and see how it does, last time it just did not seem to get hot.
Really, I’m a first time modder. No soldering experience except, making 2 wires stick to 2 battery contacts.
Thanks
Funner
While I’m thinking of it.
As a kid and recently I would ask my Grandpa about his “hobby” of soldering.
A little later he tells and shows me the plaques, etc. that he soldered the circuit boards on the Saturn Rockets for NASA. He’s about 90, I’m 34. Every time I go visit him he’s out soldering something on his condo balcony in South Daytona. I need to get down there and see him.
Thanks for the input fellas. Good Night
JasonWW
JasonWW's picture
I see an orange handle 5133 30w at Walmart. It doesn’t say it comes with solder through. I assume yours is rosin core leaded type like used in electronics. That might work, might not. Give the iron a good 2-3 minutes to fully heat up before using it. Without a seperate source for flux, you have to use what’s in the solder wire. It burns off quickly so touch the iron tip to solder wire seconds before putting the iron on whatever your soldering. Feed more solder if needed. Sometimes you end up with a solder blob. Thus is why it’s good to get seperate flux. It really improves your solder joints.
To get decent results you should step up your soldering game. If you have a Frys Electronics near by you can get this Velleman for $25. I used it for years. It has serious power. You can pick up some rosin core/flux core 60/40 or 63/37 leaded solder and a no-clean flux pen. That makes a good starter kit. It can also handle the big 30mm copper stars and solder blobbing batteries that most smaller irons can not.
Those cheap pencil type irons are just weak and usually get weaker the more you use them. Their cheap tips also wear out making them perform worse.
eas
eas's picture
Last seen: 1 month 1 week ago
Your grandpa is probably quite familiar with this.
Cereal_killer
Cereal_killer's picture
Last seen: 1 hour 15 min ago
eas wrote:
Your grandpa is probably quite familiar with “this”:https://workmanship.nasa.gov/lib/insp/2%20books/frameset.html.
Edit: for some reason clicking your link gives a 404 but when I quoted your link and click it that works.
mattheww1950
Last seen: 1 week 6 hours ago
Actually if you can afford it (and that is a significant if), you might be better off with an Indium based solder. Indium based solders have none of the hazards of lead, and melt at an even lower temperature, about 320F. They flow well and turn out to be especially attractive in cryogenic applications because they do not ever become brittle.
Funner
I’m going to reshape my current tip to a point, clean it and give it a go on a mod before I invest much money. I need to pick up more wire, probably from MTN E..
Thanks for the advice.
nottawhackjob
Last seen: 1 min 40 sec ago
To get decent results you should step up your soldering game. If you have a Frys Electronics near by you can get this for $25. I used it for years. It has serious power. You can pick up some rosin core/flux core 60/40 or 63/37 leaded solder and a no-clean flux pen. That makes a good starter kit. It can also handle the big 30mm copper stars and solder blobbing batteries that most smaller irons can not.
Yup. Great little iron. Cheap, reliable, and replacement tips are at Fry’s too. I have 3 of them. Cool
Key things regardless of the iron: Flux, flux, flux. 63:37 solder (also at Fry’s by MG Chemicals along with their nice size flux bottle). Keep cleaning the tip with the solder tip cleaner “Brillo Pad” – Hakko brand @ Fry’s. Always, ALWAYS, keep your tip tinned. Especially before you put the iron away. It should be nice and silver bright. Tips will last you a long time if you do this. Oxidation is a tip’s worst enemy. Keeping it tinned is paramount.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
JasonWW
JasonWW's picture
Solder iron tips should be coated with a special metal. You don’t want to be scraping on it.
Contrary to what said earlier, using the brass shaving style tip cleaner is soft in comparison to the tip. It should not damagr the tip coating. Also, these types of tip cleaners do not suck a lot of heat out compared to a sponge cleaner. When I used a pencil iron with a sponge it would clean the tip well, but it also sucked out a lot of heat which took a while for the iron to replenish.
Going from a sponge cleaner to a brass shaving cleaner can definitely help.
High end irons have lots of power and can heat up in seconds and those seem to work fine with a sponge.
JasonWW
JasonWW's picture
Here’s some helpful videos on soldering in general.
1 of 3 if you want to check out the rest.
https://youtu.be/J5Sb21qbpEQ
What makes the above Hakko 888 iron so good? A lot of it is because of the high quality tips. A helpful hint is that you can use cheaper irons, but still the genuine Hakko tips (about $7 each) and it will make a cheap iron perform really well. I have some videos of my own showing why the cheap tips don’t work well.
Part 2 which is actual soldering.
https://youtu.be/fYz5nIHH0iY
Part 3.
https://youtu.be/b9FC9fAlfQE
Why use flux? Here is a really nice video on why flux is important. It’s pretty to watch as well.
https://youtu.be/tfIwHuGzUEk
I’ve used flux pens, but they can be thin and runny. I’ve used the hypodermic needle style applicators, but it’s very hard to control the amount that comes out. I definitely prefer the tubs of flux that you can scoop out with a toothpick. You can apply just the right amount. This is what you see in the last video.
Amazon is a great source for flux, solder, tip cleaners, etc…
Agro
Last seen: 11 hours 25 min ago
Thanks Jason, that’s very interesting.
clemence
clemence's picture
Last seen: 1 hour 23 min ago
Once you reshape the tip, it will become useless without nickel re-plating. Check below video:
http://budgetlightforum.com/node/59515
- Clemence
Funner
Thanks for all the advice.
I picked up some 60/40 Rosin Flux Core from ACE Hardware today. Made by: Alpha Fry, product # 31605. .032” diameter. Melts at 374F. Its a spool of 4oz. $9.99
I will give this a go. Thanks again.
Funner
Soldering a Xhp35 in my Ultrafire F13 went good. It’s pretty cool one could turn a dinky light into a small light throwing MONSTER.
Thanks for all the help.
Funner
So after doing a couple of flashlight driver and led upgrades I had to break down a buy a better iron. My Walmart cheapo iron wasn’t cutting it, it would go from working okay to dead cold, then warm.
I bought a Weller WLC100 and a 5 pack of conical pointed tips from Amazon. It has to be better than what I have been using.
Jerommel
Jerommel's picture
Last seen: 1 month 6 days ago
Lead free solder totally sucks.
It refuses to flow nicely, even when you add a lot of flux.
(but maybe you need dedicated flux for lead free solder?)
Melting point is higher too.
I really hate lead free solder.
2Q19
Jerommel
Jerommel's picture
A small spade bit (shaped like a flat head screw driver, more or less) can be very useful for soldering wires to the LED board.
It has a bigger surface area at the tip, so it will go faster.
You can push down the wire with it too.
But a pointed tip is more versatile.
Sometimes i put on a sharp pointed tip for SMD parts (on drivers for example).
Weller is good stuff, but it’s expensive.
2Q19
Funner
The Weller WLC100 5-40w was $39 from Amazon. The 5 Pack of Weller tips were $8.
I’m using 60/40 wire.
Now I need to look into this flux stuff you all talk about and see if it will help me.
JasonWW
JasonWW's picture
Nobody here is using lead free.
Are you just sharing your opinion on it?
I think we all agree it sucks and should be avoided.
JasonWW
JasonWW's picture
Conical are not very useful due to their small mass and small contact points. If they don’t perform well enough, you might buy some chisel tips. They have larger mass at the tip and can make better contact.
JasonWW
JasonWW's picture
The wire you have has flux inside it. It burns away quickly so you want to feed the solder/flux into the joint. Having extra flux makes everything flow better and gives nicer performance. The videos I posted explain it.
Funner
My satellite internet is to slow for vids. Next time I’m in town I will check them out.
Thank You Jason
JasonWW
JasonWW's picture
Thank You Jason
I’m having déjà vu. Wierd
Anyway, something you might try when you get wifi access is to download all the videos from YouTube using www.keepvid.work
I use it all the time to download 720p resolution videos to watch when I’m away from wifi. You get a popup junk page once per video, but it’s no big deal to me.
atbglenn
atbglenn's picture
Last seen: 2 weeks 10 hours ago
I’ve been using Kester 44 since the late 60’s. At first, I was using 60/40. Then in the 70’s I switched over SN63 (63/37). SN63 gives a brighter finish than 60/40 from my experience. That being said, I wouldn’t be caught dead using lead-free solder. It sucks big time.
Funner
Well, my new Weller will be here Monday directly from The Amazon.com. I will give an update on how it does.
I’m debating on unsoldering a couple of the mods I have done in the past week, I’m a perfectionist and the solders are on the ugly side.
Thank You to all and I really appreciate all the great advice.
moderator007
Adding additional flux will help with that.
