Vapcell INR18350 1100mAh retested by Mooch: shenanigans again
24 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 4 min 44 sec ago
Smells like another bait and switch thing sort of like this one: Vapcell Gold 30A 3100mAh 20700 Testing Update @ E-CigaretteForum
Vapcell has changed what cell they use for their 10A 1100mAh 18350, without a wrap change @ E-CigaretteForum
Thanks a lot to Mooch.
In my opinion bad product consistency renders consumer mistrust. At least it does for me.
As an amateur battery pack builder I wouldn't lose my time with this stuff at all, though I can understand Vapcell does not aim for battery pack assemblers with their overpriced in this regard cells.
Cheers Party
adam7027
Last seen: 6 hours 48 min ago
Looking at this, vapcell probably now started to use the same cell, which is available with keeppower wrapping. It is known to be with around 100mAh less capacity, than old vapcell ones, and the voltage sag seems also to be similar. Now there is absolutely no reason to buy the vapcell ones.
EDIT: Sorry, it seems, that the keeppower wrapped cell is still a bit worse, than this ‘new’ cell (according to mooch’s test, keeppower cells lose not 100mAh, but around 300mAh, when discharge tested @ 10A to 2.8V). But… that sag on the start of the discharge is still not good to look at.
adam7027
From a view of a customer, this is a very bad practice, I mean:
1. making good cells, and getting them tested to let people see, that it is good stuff
2. changing cells under the same wrap
3. telling nothing about this to the customers, just letting them discover that, only if they are extremely aware (e.g. Mooch or HKJ)
4. differences only unveiled later, when ‘accidentally’ a re-testing happens
5. customer feels himself/herself fooled
Barkuti
Barkuti's picture
I concur adam7027, this is about speaking truth ethics and honesty. Vapcell is discrediting itself this way.
Vapcell does not manufacture cells, this stuff is namely about this fact. A renowned battery/cell OEM does not sell different cells under the same wrap. Never. An authentic OEM wrap is something I usually choose when given the choice.
Cheers Party
Barkuti
Barkuti's picture
Thanks for chiming in vapcell Dennis. The original development of this cell was because of Aspire, if I'm not mistaken, and manufactured by (?) Shenzen Yongde Lixin Energy.
Maybe some other player(s) are now manufacturing imitations?
I understand the cell could still be rated 10A, but I cannot endorse this attitude with products. Showing customers a good product and once the deal is made skimping on manufacturing costs and lowering product quality is being dishonest and disrespectful. Do you have problems with cell manufacturers committing to make a consistent cell? If I were you I would warn them of frequent and random bench tests done to their cells on every shipment, to the point of filing lawsuits against offenders. A cell is not mere capacity and amperage ratings, it is much more and this also means how much energy can it deliver and the shape of its discharge curves. Get serious if you would like to be taken seriously.
It may be a good idea to find some small electrical appliance manufacturer(s) willing to use cells like this one in their stuff: hair clippers, electric shavers, etc. It would help with achieving product consistency and manufacturing volumes, I think.
Cheers Party
Agro
Agro's picture
Last seen: 11 hours 39 min ago
I see that at times you may have troubles sourcing the best cells available.
But the only right way to handle such case is to change the wrapper, clearly notifying the customers that this is a different product.
Silent switch like this one seriously undermines the trust we can put in the Vapcell products that we buy. And in a volatile market like the one you’re in – trust is a huge factor when making purchases.
Barkuti
Barkuti's picture
This is how I “sort of” see the progressive regression of these cells, from the 1st and the best to the latest and worst ones. Hope they already stopped cutting corners because there are no corners left to be cut LoL: Aspire INR18350 1300/1100mAh, KeepPower UH1835P 18350 1200mAh and Vapcell INR18350 1100mAh, and in last position but still what seems a little bit better than Mooch's Vapcell INR18350 retest is the hyperbolically rated and funnily named BestFire IMR18350 1500mAh:
Between top and bottom the difference is huge already. The BestFire's discharge curves are of a different shape, maybe the chemistry and/or the OEM is different.
Cheers Party
nottawhackjob
Last seen: 3 weeks 3 days ago
I just received a pair of the same 18350’s from Liion Wholesale. They’re the new version Mooch tested.
Should I let Liion know?
“In many things in order to truly understand the small picture you have to understand the big picture first.”
nick779
nick779's picture
Last seen: 11 hours 48 min ago
Mtn has the new versions too. I let Randy know. He’s going to check with his vapcell rep.
Hugh Johnson
Hugh Johnson's picture
Last seen: 2 hours 42 min ago
Thanks for this. I bought these 6 months ago, which is right after the change. Not sure yet which revision I got.
nick779
nick779's picture
Look at the bottom of the cell, its the easiest way to distinguish it. I bought mine a few weeks ago from MTN and I have V2.
Hugh Johnson
Just checked mine. I have one of the gen 1 cells.
heatwaves
Last seen: 1 week 2 days ago
This is a fascinating (and disappointing) thread. I often use 18350 cells in my Emisar D4 “shorty” tube while jogging at night. Wanting to maximize the potential, I switched from Efest Purple 700mAh to Vapcell 1100mAh. I didn’t notice any differences with max brightness between the two cells (which was no big deal), but I was shocked that the Vapcell seemed to have greatly less capacity. After just a couple of runs, my D4 was blinking a battery warning. This never happened with the Efest Purple. I was so puzzled, that I started checking online and found Mooch’s original FB post on this, then this thread.
Is there any realiable high-drain 18350 cell with 1000mAh anymore? I’ve read that Shockli’s 1150mAh 18350 cell is promising but doesn’t seem to have a distributor.
Hoop
Hoop's picture
Last seen: 1 day 45 min ago
You can still get Aspire 18350s before they become sold out.
heatwaves
Where? I thought I did a pretty thorough search, but couldn’t find any.
Petr J.
Petr J.'s picture
Last seen: 3 days 13 hours ago
Shockli 18 350 can be bought at Aliexpress.
https://www.aliexpress.com/item/4pcs-lot-Shockli-IMR18350-lithium-batter...
Hoop
Hoop's picture
Ok, maybe the Aspires are gone by now.
tm07
tm07's picture
Last seen: 2 hours 11 min ago
18350 Keeppower IMR18350 1200mAh High Discharge Flat Top https://www.illumn.com/batteries-chargers-and-powerpax-carriers/batterie...
Hoop
Hoop's picture
The KeepPowers appear to be more of a gamble with multiple cells using the same labels.
The Shocklis in the photos on Ali seem to use the new style can, so may also be the same “new” cell.
The difference of the cells in Mooch’s test is not so dramatic really but of course it’s not great to see a performance decline. This is probably beyond the control of VapCell, KeepPower, Shockli etc. They get what they get from the factory.
Jerommel
Jerommel's picture
Last seen: 2 weeks 1 day ago
The good old bait and switch…
Or should we call it “quality fade” ?
The effect is the same..
2Q19
Petr J.
Petr J.'s picture
They are not exactly the same. The top is different. I have Bestfire and Shockli.
I made a small comparison. Shockli, Bestfire 1 500mAh, Bestfire 1 300mAh.
Shockli
Bestfire 1500mAh
Bestfire 1300mAh
heatwaves
It turns out that a lesser performance of Vapcell 1100mAh compared to my Efect Purple 700mAh, must have been my imagination. I performed a Nor Test on my Liitokala charger and the Vapcells seem to get just shy of the specs they were intended to have.
Vapcell 1100mAh (Battery #1)
Tested at 1034mAh
43mR
4:05 hour test time
charged to 4.19
Vapcell 1100mAh (Battery #2)
Tested at 1048mAh
35mR
4:08 hour test time
charged to 4.20
Efest Purple 700mAh
Tested at 708mAh
59mR
2:47 hour test time
charged to 4.19
I was still quite impressed where the Efest tested after almost 14 months of use. The Vapcells are brand new with only about a week or two use.
Windsurf
Windsurf's picture
Last seen: 1 day 7 min ago
Interesting thread. Just wanted to post some info. I had been looking for some additional batteries in case the US/China Tariff dispute raises prices very high. So in another thread someone recommended Illumn as a vendor and I found these higher discharge higher capacity 16340s and 18350s. So I bought a few to test.
The Vapcell (purple wrapper) INR18350 1100 batteries except on the wrapper it says max discharge rate is 9A not 10A. I tested capacity on my Liitokala-500 at a 500Ah rate and the two tested at 1097 and 1115 respectively.
I also tested 2 Keeppower IMR18350 (black label) 1200 with a max discharge rate of 10A again at the 500Ah rate and they two tested at 1156 and 1152 respectively. I think the capacity may have been larger if I tested at the lower 300Ah rate.
I may buy a couple of the Shockli’s from AliExpress but I think they are the same cell as the Keeppower 1200’s.
On a side note I went to the Vapcell site to check the security code on the batteries I bought from Illumn (yes they passed as real) but I was surprised to see on the top of the Vapcell site the words “Approved by Mooch and HKJ”. made me laugh I guess you guys truly are Internationally famous.
Barkuti
Barkuti's picture
Windsurf wrote:
… I had been looking for some additional batteries in case the US/China Tariff dispute raises prices very high. …
No idea what the issue is, I completely avoid news broadcasts or papers of any class. But let me say, at times I wonder why does people expect sheesh to go bad (it's in their minds, mind you). Mind stuff is a challenging discipline, but if you do not want stuff to go bad it is wise to mentally instruct yourselves (mind programming) for stuff to remain good or for an alternative and constructive solution of benefit for everyone.
This still is a too common problem for humanity as a whole. People needs to awaken, imho.
